Question about Dishwashers
Dishwasher door gasket replacement
Maytag WU1000
Serial 644419 PN
Door gasket was hardened with age. I removed the existing gasket which was firmly held in place by plastic lugs protruding from the gasket which snap into slots in the door panel. I have an identical Maytag door gasket 901403 and its lugs fit into the irregularly spaced door slots perfectly but I can't get the lugs to snap in so the gasket is held securely to the door. What is the secret? Is there a special tool or technique required?
  • AlanCello Feb 28, 2008
    Thanks for your prompt response. Do you take the door apart first and pull the tabs through the slots from the inside of the inner door skin or do you push them through from the outside of the door skin without taking the door apart?
    One of the slots at the botton is one sided due to rust I guess. I'll need to glue the last two inches of one end of the gasket. What kind of glue will do that and not poison us?
  • Anonymous Mar 28, 2014
    Plastic adjustable foot has snapped. I have a replacement, but cannot remove the broken stub. I can turn it, but it is held by something. Is it possible to remove the foot mounting bracket from the dishwasher? If so, how?
Hi alan, the tool that works for me is a pair of 90 degree curved needle nose pliers (mine are a sears product). also, i soak the gasket in hot water for five minutes to soften it up and sparingly apply soap dish detergent to the tabs to give them help in sliding through. sorry i dont have a pic of the tool for you.
Posted on Feb 28, 2008
Dishwasher leaks from the bottom of the door
Hi, if it is leaking around/under the door, it must be the seal around the door. Check to see if the seal needs to be pushed in somewhere or is damaged..
Try running the cycle with no dishes in the washer and see if it leaks, it sounds like a gasket in the door to me and you can also check hose by removing the front panel on floor and check there....
Inspect the door gasket. As it ages, the gasket can crack or become hard, preventing it from sealing completely.
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and re tighten the screw. Test the door and readjust the latch if necessary.
Replace the gasket if water continues to leak after you've tightened the latch. Most gaskets are held by compression in a groove on the door or on the dishwasher cabinet.
Jun 26, 2011 | GE Nautilus 24" Built-in Dishwasher
Tip
Hidden Gunk in Your Dishwasher
<span><span>You may be surprised to know you probably have "gunk" around the door seal and on the inside bottom of the door of your dishwasher. Using an old toothbrush or a soft cloth and some <a href="/#">white vinegar</a> or a mild cleaning product, rub around the door gasket and the edge of the door. You'll probably be amazed at the residue that you remove. You may have to wipe and wash several times to get off all the accumulation.<br />The reason this debris accumulates is that the water and <a href="/#">soil</a> seep under the seal but are not rinsed away. Because we can't see the <a href="/#">soil</a>, it hardens and the next time the machine is run, more soil is deposited. Eventually, the soil begins to spoil and an unpleasant odor develops. </span></span><br /> <span><span>Another trick is to GENTLY rub just under the gasket with a wooden toothpick. This will remove debris lodged under the gasket.</span></span><br /> <span><span>Cleaning the bottom and edges of the door will help to prevent unpleasant odors coming from your dishwasher.</span></span>
on Dec 02, 2010 | Dishwashers
Dishwasher keeps leaking from door
If the gasket appears solid, adjust the door latch so the door seals tightly. Loosen the screw that holds the door latch to the cabinet. Push the latch in slightly and retighten the screw. Test the door and readjust the latch if necessary.
Jun 22, 2011 | Bosch SHU9915UC Dishwasher
Water leaks out on the floor from the front left of the machine, not every time though. what's the most likely place to check? intake hose? drain hose? door edge?
Hello there:
If your dishwasher leaks, check these: Main tub seal Note... If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. Lower rack Spray arm Spray arm support
Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Sep 26, 2010 | Maytag PDB3600A Built-in Dishwasher
Maytag WU1000 Series 2 has no power, is there a fuse in the door or on the lower unit? Any other suggestion?
Do the following:
  1. Check the power from the wall outlet or the branch circuit itself.
  2. Check for a blown fuse or a tripped circuit breaker.
  3. Check the wiring connections of the dishwasher from the house wiring.
  4. Check the door switch. Remove the control panel cover or the interior liner of the door whenever it is applicable.
  5. Try by-passing the switch. If the unit powers on replace switch completely.
  6. Check the timer or selector switch. replace if defective.
Sep 03, 2009 | Maytag Dishwashers
Maytag Jet Clean leaking through right side of door during rinse
It is important to examine the leak to see where it probably originates.
If the water is leaking from the right hand side of the door on your dishwasher, it is time to replace the gasket that seals the door when the door is latched.
Aug 10, 2009 | Dishwashers
Dishwasher door leak
Hi
Also,The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
A Fixya rating would be appreciated if you have found this solution Helpful.
Thanks
Rylee
Feb 10, 2009 | Maytag 24 in. MDB6100A Built-in Dishwasher
Brand new dishwasher installed and water leaks out bottom of door
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal Note…If the main motor of your dishwasher is mounted vertically, beneath thecenter bottom of the dishwasher, the following instructions probablyapply to you. But if your motor is mounted horizontally, the pump isn'tserviceable--you need to replace the entire pump and motor assembly.
Themain tub seal is beneath the drain impeller. It prevents the water inthe dishwasher from leaking out near the shaft of the motor. To get tothe seal, which is inside the dishwasher, remove the:
  • Lower rack
  • Spray arm
  • Spray arm support
  • Wash/drain impellers
Door gasket or seal Overtime, door gaskets and seals harden and lose their ability to sealproperly. You can't repair the seals. You need to replace them ifthey've begun to leak.
Water-inlet valve Thewater-inlet valve, itself, seldom leaks. But, the water-supply linefrom the house and the rubber tube leading from the valve to the insideof the dishwasher may leak. Tighten or repair/replace these asnecessary.
The water-inlet valve could mechanically stick open.When that happens, the water continues to flow into the dishwasher,which then floods your kitchen. Turn off the water supply to thedishwasher, and replace the valve.
Hoses Behindthe lower access panel on your dishwasher are several rubber or plastichoses. If the leak appears at a connection, try a new clamp. If thatdoesn't work, replace the hose.
Dec 04, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwasher maytag 945 awq
Door gasket or sealOver time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Nov 08, 2008 | Maytag MDBH945AWW / MDBH945AWQ /...
Leaking dishwasher
hi there,
dishwasher leaking might be due to either of these causes, check these:
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from
leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher,
remove the:
* Lower rack
*Spray arm
* Spray arm support
* Wash/drain impellers
Then try the seal out of its housing and replace it.
Door gasket or seal
Water-inlet valve
Hoses
Oct 27, 2008 | Maytag 24 in. DWU7402 Built-in Dishwasher
Dishwashers Logo
670 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
