Question about Mitsubishi VS-50707 50" Rear Projection Television
Mitsubishi TV My large screen Mitsubishi TV is making sounds like a freight train; the picture goes on and off. Thanks for any help you can give me.
Run from it bring to shop you would not sit in front of atrain blowing its horn
Posted on Mar 08, 2008
I have a vs-60609 60"
Sounds like a Picture in Picture screen popping up, but if you do not have a signal from another tuner, it will be blank.
Try hitting the PIP button on your remote to see if it turns it off and on.
Plus go into the tv menu and find the PIP settings.
Apr 15, 2011 | Mitsubishi VS-60609 60" Rear Projection...
I have sound but no picture screen is black 19inch screen
I cannot say enough about this model. There is a bad capacitor or two in this set. You should be looking for a buldged cap at maybe 25 or 35 volts at 2200Mfs. Replace this and the next one near would be a 35 volt at 1200 Mfs. I have a question for you, if the model number is 42 MF, the screen is large. And yet you say it has a 19 inch screen. I'm not sure if you have the large TV or the small TV. The answer I give you is for the large screen. Hope this helps you! Thanks for asking and show a few hands of support!
Oct 07, 2010 | Philips Magnavox 42MF521D/37 Television
I have no picture. The screen will not come on. When I attempt to turn it on, the TV makes a sputtering sound coming from the bottom right (if you are facing the tv) speaker area. It sounds as though it's...
SOUNDS LIKE YOUR LAMP IS OUT. AS FAR AS WHAT MITSUBISHI IS DOING THEIR NEWER DLP'S THEY REDUCED THE COST OF THE LAMPS TO $99. BUT ON THESE OLDER ONES THEY ARE DOING NOTHING.
Aug 17, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsu vs-5042 Works then picture goes out. Thumping works sometim
If you occasionally have a picture then you stand a good chance of repairing this tv. There are bad grounds on the deflection board. Start with the board that has the flyback. I do not know the year of your tv. Sometimes the same model may have an option improvement than one couple of months earlier. The first suspected problem would be the vertical IC. In some cases this ic is located on the convergence board and in others the flyback board. It has seven pins and is the TDA version. Located on a large heatsink. Resolder this and any other grounds on both board. Some will tell you the P I P board is bad. This is a free standing board that can be removed and replaced. But please do the earlier option first.
Jun 28, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Screen goes black after unit is turned on.
Contacted Mitsubishi directly and found out that QV9 on the remote control resets to factory defaults, clearing the Parental lock out someone had put in place. The TV is in a Retirement Home and some of the folks are sneaky about wanting to control the TV in their own fashion. We will be watching the remote a bit closer now!
May 01, 2008 | Mitsubishi VS-50802 50 in. Rear Projection...
Mitsubishi big screen TV
Sounds like something in the deflection or audio circuits. Wish I could help more. I will post a link where you can get the service manual.
http://servicemanuals.vstore.ca/
Feb 28, 2008 | Mitsubishi VS-50707 50" Rear Projection...
No picture
When I first turn the tv on the picture comes on for a few seconds then the screen goes to green but I still have perfect sound
Oct 11, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-50707 50" Rear Projection Television Logo
65 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
