Question about Olevia LT32HVE 32 in. LCD Television
HDMI is not working
This is my second one from olevia and the same problem is still happening. Talk to them and all they said was to upgrade the firmware so I did and still no HDMI signal. my buddy that lives next store to me brought over his sony HD and that worked fine with my Comcast cable box. please help!
  • Anonymous Mar 18, 2008
    olevia olv 232v HDMI not working
  • 113 Answers
Some Hdmi signals are not working with some tvs at this time. It is a fighting battle that tv techs are dealing withe everyday. At this point the tv manufactutre will tell us what I am about to tell you. Hook up the composite and wait for a firmware upgrade to fix this. A perfect way to see this is a problem between cable box and tv and not just your tv is to plug in a dvd player with hdmi out if it works firmware will need to be developed if not your tv needs to be exchanged or a new main board.
Josh
Posted on Feb 28, 2008
My husband accidentally erased the HDMI input option on our olevia 232 s13 how do I fix it?
go in to setting and find factory reset you will need to do a factory reset its usually in setting with a box, at the bottom when it reboots it will ask you to do somethings to get it going again. do these and then check to see if everything is there. other way is to turn power off for 10 min at mains and turn on holding down the power button for 3 seconds. it should rest. there seam to be a lot of problems with the hdmi ports on this make of tv, if you can i would recommend upgrading its firmware you can get the firmware update from manufacturers web site.
May 19, 2017 | Olevia Televison & Video
Hooking up my ps3 using HDMI cord to my olevia 232-S13 and it says invalid format
Setting up your HDMI cable on your PS3 games console
1: Turn on your TV and set its input to HDMI.
2: Make sure your PS3 is connected via a HDMI cable.
3: Power on your PS3 and press and hold the power button for approx. 5 seconds, you will hear the PS3 start to beep, release the power button after the second beep.
4: Your PS3 should automatically configure itself for HDMI video and Audio output.
Jun 28, 2015 | Olevia Televison & Video
On my Olevia 42'' LCD TV, the tuner option in source stopped working. I now have HDMI, Composite, etc but no tuner. How do I correct the problem so that I can access tuner. Firmware ends in 060608B....
A Converter hdtv box... is the SOOLUTION!!! try it..youll see!!!
I had the same scan-turner problem with my Olevia "digital" Olevia tv!!
Because I was curious i tried that to see what happen..and it worked!!
Olevia tv fixed!!!
Easy..your tv is not able to scan cahnnels...then, the solution is to plugging "a thing" that can do that: a converter box.
Dec 24, 2009 | Olevia LT42HVi 42 in. LCD Television
The HDMI port on my Olevia Model 337-B11 LCD tv quit working. Is there an easy fix?
Without replacing the main board, probably not. Did you try another HDMI source to verify the TV is at fault? If it is the cheapest fix is to use component only.
Sep 10, 2009 | Olevia Televison & Video
My olevia tv is not sensing the hdmi input right away.
HDMI has to be able to communicate with each other. In most cases the HDMI issue is with the device connected to the TV and not the TV itself. If you did firmware upgraded on the TV then the issue is with the laptop. Try the laptop on anther brand of TV and see what happens.
Jul 23, 2009 | Olevia LT32HVM 32 in. LCD Television
Says no signal when switched to hdmi when there is one.
Have the same problem with a 532H - but here is what I did to resolve the issue:
1) Click your Menu button on the TV remote.
2) Go to Screen (click the right button)
3) Go to Main Picture Source (click the right button)
4) Select HDMI (click the Menu button when done)
Aug 20, 2008 | Olevia LT27HVX 27 in. LCD Television
HDMI crap out
I got the solution. Contact Customer Service, ask for LEVEL II Tech, and ask them for the old firmware. It will take a lot of pressuring, but they will send it to you and then it will work fine!
Feb 02, 2008 | Televison & Video
Olevia LT32HVE 32 in. LCD Television Logo
749 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
