Question about Panasonic DVD-RV32 DVD Player
Rv32 dvd panasonic
It plays in black and white only .
did check the wiring even changed them.
    Genius:
  • 1,019 Answers
Change The Region Settings.
It will play in Black and White If Its region 2. setup at Region 1 Or Vice Versa.
Mike @ Compurepair.
** Common Sense Comes as standard**
Posted on Feb 27, 2008
Panasonic dvd rv32 no colour
We had a similar problem - resetting the DVD to factory settings seemed to work for ours
Mar 17, 2012 | Panasonic Televison & Video
Our Panasonic DVD-RV32 player plays movies in blk & white even if the movie is a color movie....
this is a cableing issiue. I assume you are playing it through a SVHS cord. check to see which pins may be bent. If it is true and none of the pins are bent then you simply need a new cable.
wikipedia talks about these color and non color pins http://en.wikipedia.org/wiki/S-Video
If you are not using SVHS cables and instead are using the RGB or red green and blue RCA connectors then you may have them on the wrong color on either the DVD or the TV get a light to be certain the color you were trying to line up was the right one.
You may have a bad cable here as well. on the back of the unit it doesn't say RGB it says component Pb Pr and Y but just look at the colors of the RCA jacks. Side note here you can use a different cord to test them out, even one of the red, white and yellow cables, Just make sure that the jack goes green to green and so on you don't have to have a green cable in between it, it is helpful but not necessary.
also for reference here is the manual http://www.panasonic.com/consumer_electronics/live_manuals/media/pa029/pkg/manual/PA029_02.html
Mar 25, 2011 | Panasonic DVD-RV32 DVD Player
I am unable to play DVD's and receive error message HD7. How can I fix this? I own Panasonic DVD-RV32 player.
I think you mean H07 - this means the traverse unit (which contains the spindle motor and the laser in one assembly) has failed. The spindle motor is the most likely problem; unfortunately this is not repairable at consumer level, it would need to go to an authorised service workshop where the whole unit would be replaced in the player, which would include a brand new laser. The other snag is the cost - a new traverse unit can cost around $200 + labour (including alignment and firmware upgrades)!
Save yourself the agony, and simply replace the whole player - cheaper than repairs. The RV32 was not Panasonic's best DVD player model.
Mar 01, 2011 | Panasonic DVD-RV32 DVD Player
How do I connect my dvd to my tv???
connect component{red, green, blue} cables to corresponding color on back of tv or yellow, red, white cable to back or front of tv and select input on remote. May be component labeled or video 1, 2 and etc...Make sure dvd player is turned on first.
Aug 04, 2009 | Panasonic DVD-RV32 DVD Player
Panasonic dvd rv32 tv set at ch 00, play,sound only - no pic
you idealy need to use a scart lead from the dvd to the tv, then pick the "av" chanel it is plugged intoon the tv. You get a much better picture using a scart lead.
May 09, 2009 | Panasonic DVD-RV32 DVD Player
What formats will a Panasonic RV-32 read?
DVD only or mp3 or 4 but if you download a avi movie just get a converter avi to dvd.HOPE I WAS USEFULL PLZZZ RATE ME.
Dec 22, 2008 | Panasonic DVD-RV32 DVD Player
Panasonic DVD-RV32 DVD Player-No image on RCA output
Hi Obviously the unit is playing the disk because your audio is fine, and getting some kind of black & white picture out of the composite, means that the video processor is probably ok. The most likely things to check then is the yellow video cable, (just swap the red or white in place of the yellow on both the DVD and your tv to test), or possibly the yellow RCA jack on the back of your DVD has gotten loose. If you have not done so, try wiggling it gently to see if your video comes back. If it does, and you are handy with a soldering iron, you can probably repair it yourself. Other than that, it would be a problem for a repair shop. (and a strange one!) Hope this helps, and good luck!
May 17, 2007 | Panasonic DVD-RV32 DVD Player
Panasonic DVD-RV32 DVD Player Logo
216 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
