Question about Garmin StreetPilot c340 GPS Receiver
Locating satelites i keep trying to test it out...and it just says ,,locating satellites...
  • Anonymous May 11, 2008
    is says acquiring satelites thats all it does brand new out of box
To change the preset home location on your street pilot follow the below instructions (at least it worked for me)
1. Select the "Where to?" icon & choose "My Locations" then "My Favorites" icon
2. Locate "Home" & select it, then touch "edit" on the bottom of the screen & choose the option "delete"
(If there is anything else in there saved delete those things as well)
3. Once the preset "home" has been deleted, go back to "Main Menu" select the "Where To?" icon & select the "go home" icon.
4. The device will now prompt you to enter the new location for "Home"
Posted on May 16, 2008
  • 52 Answers
Are you outside, exposed to the GPS signals?
If so, have you tried resetting the unit?
Remove the face cover (GENTLY pry it loose by using the fingernail groove directly under the GARMIN logo), press the RESET button, then re-attach front cover... this is covered in the owners manual, also available online at /support /downloads
Posted on May 04, 2008
My garmen Nuvi GPS takes a while to find the satelite when first plugged in
Try to connect it to your computer and update the satellites positions.
Mar 21, 2014 | Garmin nuvi 205W GPS Receiver
I have a ifinder hunt GPS, it will not locate any satellites, it then prompts me to stop searching or continue to search for satellites. I have been trying this device over the last 10 months, mostly on...
With a normal GPS device, when you first switch it on, it needs some time to locate enough satelites. Most of the time it needs at least 5 satelites. Some time should be like minutes and not hours. After the GPS device fond enough satelites, it knows where it is and can when it is switched on again work faster. When you try to let the GPS search for satelites indoors, or without a free view to the sky, it is possible the receiver never can find satelites at all.
I don't know if any test of the Lowrance iFINDER Hunt GPS was placed on the net, but that is where you can check how long it should take for the GPS to find enough satelites.
Oct 30, 2013 | Lowrance iFINDER Hunt GPS Receiver
Hi guys!my garmin turns on but keeps saying it's looking for satellites, what do i need to do to make it work. I'm outside with a clear view of the sky
Ok well every satellite dose that ones you turn it on after a while, I have a Garmin GPS my self and it always dose that like for a minute and until that I just drive, after like a minute it shows that satelites is found and will direct you to your location
Aug 28, 2013 | Garmin EDGE 705
My gps works up to the point that it cannot locate satellites. It asks if I have travelled 100 miles or more and whenI hit no, it goes back to searching for satellites with no luck. Is that a fixable...
Try answering yes. If the original location has been lost due to battery replacement etc, These devices go to a home location which may be anywhere to begin looking for the satelites. It could take 30 minutes or more to locate itself. Just turn it on and let it look for a long time.
Jun 03, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
Can i use existing satelite antena on my audi
The antenna should plug into the Stilleto car kit if your Audi is equipped with Sirius already. Otherwise you will have to use another Sirius antenna.
Mar 07, 2009 | Sirius Satellite Radio Receiver
Only one satellite is enough to find the GPS device location or more satellites are required?
To determine location at least 4 satelites are needed.
If you know one element( latitude,or height) than 3 are sufficient
Jan 15, 2009 | Garmin Forerunner 305 GPS Receiver
GPS Cannot locate satellites.
I had a similar problem. My neighborhood is in a heavily wooded area. I bought an external antenna, connected it and now locate sattelites with no problems
Dec 15, 2008 | Garmin StreetPilot C330 GPS Receiver
No signal
Dec 13, 2008 | Televison & Video
No signal
You will have to leave the unit out in the open so it can 'see' the satellites. It might need from 20-30 minutes to acclimatize itself to the new location. It is set at Kansas because that's where the manufacturer is, so that is the last recorded satellite signal.
Apr 16, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
142 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
