Question about Roadmaster (VR500CSBT)
Vr500csbt audio noise high pitched on most radio stations
I have a noise that is present on mmost local stations here in the Dallas/FT.Worth area and is more noticeable as the volumn passes "25" on the volumn scale. Does not matter if truck is running or not as long as key is on . Ihave a Commander XM radio that I ca'nt use because it gets worse when it is turned on. I used a factory connector adapter to wire straight to the connector from the VR3 radio that was purchased from Crutchfield. I am an ASE auto tech. with much experience but have never come across this until now. Thank You, Alan
  • 30 Answers
First of all what kind of truck is it? Where is it grounded? Is the radio mounted directly to the car's chassis or is it suspended in a dash kit? What other aftermarket products are installed in the truck?
You can test for radiated noise too...turn on the ignition and bring a portable radio into the car, see if it has the same interference.
Posted on Feb 28, 2008
I am trying to re tune to my local radio station radio Merseyside on dab but it says station not available or goes to another station ?
Have you checked the frequency of that Station?
Also check your aerial.
I have also found this:
Listeners to DAB digital radio in the Merseyside area will need to retune on Wednesday 20th April following a frequency change that will affect local radio stations.
The local DAB multiplex carrying BBC Merseyside, Radio City 1-3 and Capital Liverpool among others will be moving to a new frequency in order to allow better reception over a wider area. The current frequency will be turned off late on Tuesday 19th April. The new frequency will go live from 6am on Wednesday 20th April, after which listeners will need to rescan their DAB radios in order to continue listening.
May 26, 2016 | Audio Players & Recorders
I have an Avanti 1.7 cu ft superconducting mini-refrigerator. it was accidentally unplugged all night, and this morning it keeps emanating a recurring low volume high pitched "beep." It's almost inaudible...
some thing caused a failure of the compressor area, loud noise is air or freon blown out through small hole in the service lines, i do not know if they are worth fixing because they around 100 dollars
Feb 20, 2015 | Avanti Refrigerators
I may not be in right area for my question, and perhaps you could redirect me. For years we've listened to our local station 104.9, and now the transmission to that station has totally failed, and another...
Improve the aerial on the device you are listening to it on, or move it slightly if it is portable. You can also listen to it online.
If that doesn't fix it, you can complain to your local radio telecommunication authority as the new station may be a pirate and not registered.
You can also phone the 104.9 and tell them.
local station 104 9 Google Search
Mar 05, 2018 | Delphi Roady XT XM Radio Receiver
I dropped my pentax optio 60 digital camera.
i think some radio shacks help out with that stuff, and you can always look online for local repair shops. i actually have a lens problem myself. good luck
Apr 02, 2009 | Pentax Optio 60 Digital Camera
"High Pitch Squealing" from my tv.
this most likely a coil or transformer that is doing this
And yes this is worth fixing , shouldn't be to bad on the cost of the repair
Dec 01, 2008 | Sony Televison & Video
Humming noise
If this is like my unit it is a high pitched squeal. I received my unit as a gift for Christmas 2007 and I thought it was defective. I contacted Homedics and they sent me a replacement but the problem persisted. As licensed amateur radio operator I am versed in electronics so I decided to track down the source of the noise. It turns out that the 16VDC power adapter is the source of the noise. It is what is called a "switching power supply" and is unfortunately not well filtered causing the high pitched squeal. I was able to get rid of the noise by modifying the power adapter and adding a 2200 microfarad capacitor in parallel with the output. This filters out the high frequency ripple and gets rid of the squeal. An alternative solution would be to search the Internet for a better 16VDC power adapter. It must supply 2 amps of power and have a 5.5mm OD/2.1mm ID center positive power connector.
Nov 09, 2008 | Homedics iSoundSpa Max Clock Radio with...
Loss of XM signal
The problem is amazingly simple.
The red wire goes to your ignition so it turns the radio off when you power down your car so as not to discharge the battery.
The YELLOW wire is usually your memory and it connects to the power side of your fuse box (anywhere will do as long as it's powered when the car is off completely). Occasionally this wire is blue but it's rare.
This wire draws a tiny little bit of power so your stereo doesn't 'forget' your station settings etc.
BTW Pioneer is one of my favourites :)
Apr 16, 2017 | XM Radio (XMP6000)
Roadmaster (VR500CSBT) Logo
142 people viewed this question
Top Roadmaster Car Audio & Video Experts
xxxxxx xxx
Are you a Roadmaster Car Audio and Video Expert? Answer questions, earn points and help others
