HP Photosmart C5180 All-In-One InkJet Printer Logo
Posted on Feb 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When trying to scan or reprint a picture on my HP photosmart C5180, and I choose a 4x6 or 5x7 or8x10, it prints out a thumbnail picture. If I insert my card from my camera, it prints a beautiful 4x6 print. Why is it doing this and what is causing this. Also, if I want to just make a copy of something it prints out with tiny colored lines all over the page.
Anonymous
Level 2:
Novelist:
  • Expert 126 Answers
  • Posted on Feb 20, 2010
Anonymous
Expert
Level 2:
Novelist:
Answers
126
Questions
0
Helped
29678
Points
204
Please go ahead and right click on the printer icon and ytou will get an option that says printing preferences
fromthe printing prefercnces select photo printing select the right photo printing
select the size and the printing type
hope this should fix the problem for more details you can also foillow the instructions from hp
since the ocpy is not fine you can try and do these steps:
1.disconnect the power cable from the back of the printer
2.press and hold the power button of the printer for 20-30 seconds
3.restart the printer and see if it coipies fine
for more details please download the manual from te following URL ;
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?product=1153481&lc=en&cc=us&dlc=en&lang=en&cc=us
thanks
regards
Hamid
Can you just give me a link or quick advice on scanning with HP photosmart c5180? I would like to to scan and save to disk/save to laptop.
Scanning with HP Solution Center Software in Windows
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&cc=us&lc=en&dlc=en&product=1153481&tmp_track_link=ot_search#N43
FROM THE MANUAL ON PAGE 14 http://h10032.www1.hp.com/ctg/Manual/c00737535.pdf Scan an image You can start a scan from your computer or from the HP All-in-One. This section explains how to scan from the control panel of the HP All-in-One only. To use the scan features, the HP All-in-One and computer must be connected and turned on. The HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) must also be installed and running on your computer prior to scanning. ? On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running. Note Closing the HP Digital Imaging Monitor icon in the Windows system tray can cause the HP All-in-One to lose some of its scan functionality. If this happens, you can restore full functionality by restarting your computer or by starting the HP Photosmart Software. ? On a Mac, the software is always running. Tip You can use the HP Photosmart Software (Windows) or HP Photosmart Mac Software (Mac) to scan images, including panorama images. Using this software, you can also edit, print, and even share your scanned images. For more information, see the onscreen Help that came with the HP All-in-One. To save a scan to a memory card 1. Make sure your memory card is inserted into the appropriate slot on the HP All-in- One. 2. Load your original print side down in the right front corner of the glass. 3. Press the Scan Menu button. 4. Press to highlight Scan to Memory Card, and then press OK. The HP All-in-One scans the image and saves the file to the memory card in the JPEG format. To scan a photo and reprint it 1. Press Reprints. 2. When prompted, load your original photo print side down on the right front corner of the glass, and then do one of the following: To reprint your original photo using the default print settings ? Press Print Photos. To change print settings before reprinting your original photo a. Press OK. Basics Guide 13 HP All-in-One overview b. Press or to highlight a paper size, and then press OK. The paper size choices available vary depending on your country/region. Note Depending on the paper size you choose, you might be prompted to choose a layout for the photos on your pages. c. When the Fix Faded Original? prompt appears, highlight Yes or No as appropriate, and then press OK. The HP All-in-One scans your original and shows a preview of the photo on the display. d. Press OK to display the selection menu. Tip If you want to print more than one copy of the selected photo, press to highlight Copies, and then press OK. Use the arrows to increase or decrease the number of copies. If you want to edit the photo before printing, press to highlight Edit Photo, and then press OK. e. Press to highlight Done, and then press OK. The Print Summary screen appears. f. Press or to highlight one of the following options, and then press OK. Print Options Enables you to manually specify the type of paper on which you are printing and whether you want to print a date and time stamp on your photo. By default, the Paper Type is set to Automatic and the Date Stamp setting is set to Off. If you want, you can change the defaults of these settings with the Set New Defaults option. Print Preview Displays a preview of what your printed page will look like. This enables you to verify your settings before printing and wasting paper and ink on potential mistakes. Print Now Prints your photo with the size and layout you selected. To scan to a computer 1. Load your original print side down in the right front corner of the glass. 2. Press Scan Menu. 3. Press to highlight Scan to Computer, and then press OK. 4. If the HP All-in-One is connected to one or more computers on a network, do the following: a. Press OK to select Select Computer. A list of the computers connected to the HP All-in-One appears on the display. Note The Select Computer menu might list computers with a USB connection in addition to those connected through the network. Chapter 1 14 HP Photosmart C5100 All-in-One series HP All-in-One overview b. Press OK to select the default computer, or press to select a different computer, and then press OK. The Scan To menu appears on the display, listing the applications on the selected computer. If the HP All-in-One is connected directly to a computer with a USB cable, proceed to step 5. 5. Press OK to select the default application to receive the scan, or press to select a different application, and then press OK. A preview image of the scan appears on your computer, where you can edit it. 6. Make any edits to the preview image, and then click Accept when you are finished.
How is reprinting your item scanning it? That second option reprints my image. I used to be able to scan to microsoft word. What happened to that feature?
Have you tried installing a newer version of HP SW? If not, I would give that a try, I've seen this tactic work for a number of customers. Here's a link to a Photosmart product using a newer version -- v12. http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2100&lc=en&dlc=en&cc=us&lang=en&product=3575276
BTW, iIt doesn't matter that the SW is for a different product. Disconnect your product, go through the v12 install, and when it asks you to connect the PS C5580 choose the option that allows you to connect later. Once the SW is installed plug your product back into the PC and open Solution Center and try to scan.
good luck, and do rate the solution if helps
I was printing a downloaded document on my HP C5180 printer that contained 144 pages. The printer started at page 144 and stopped at page 44. How do I get it to print the remaining pages without reprinting...
You don't specify from which application are you printing, or even what operating system are we talking about.
If it's Windows, then you need to open your document, hit Ctrl+P or choose File->Print from the menu, and in the Print dialog that appears specify "1 - 44" in the Pages field. Finally confirm by clicking OK.
Please come back and leave a rating/testimonial if helped.
2answers
Can I scan pictures to my computer?
Yes ... your all-in-one can print, copy and scan.
Scan an image
● On a Windows computer, look for the HP Digital Imaging Monitor icon in the Windows system tray (at the lower right side of the screen, near the time) to verify the software is running.
● On a Mac, the software is always running.
1. Press Reprints.
➔ Press Print Photos.
a. Press OK.
Basics Guide 13
Defaults option.
2. Press Scan Menu.
1helpful
When i scan using my Hp photosmart c5180 all-in-one the picture comes in completely black.
check to see if your scan light is on the bulb may be burnt out try cleaning the glass hope this helps:)
Scanning
Right click on the card in My Computer.
Click Properties, Uncheck READ ONLY
Scanner problems
You need to have the full photosmart software loaded on the computer and to use this to scan to computer rather than using the buttons on the printer. This is a workaround rather than a fix but it should work
Fred
C5280 all in one printer
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00707174&lc=en&cc=us&dlc=en&product=1153481&rule=45790
k24674
Grand Canyon Tech
Grand Canyon Tech
