Question about Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television
Panasonic PT53TW53G doesn't shut off
Hi
When I turn off my TV, it doesn't shut off, it's still on, unless we unplug it.
    Novelist:
    Scholar:
  • 96 Answers
Sound like your relay is stuck or the cpu turn on line is not working, or you have a short somewere, like a jumper
Would open the back and tap on the relay first to see what happen's, first time I see this.
Meanwhile the force is with you.
What About Bob
Timmins, Ontario
Posted on Feb 29, 2008
I have a Panasonic LCD tv, model# TC-32LX70, S/N MY71420839, manufactured May 2007. The tv wouldn't turn on unless the power cord was unplugged and plugged back in for about 2 years. Then it
Fault with the main power supply regulator section circuit board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 20, 2014 | Televison & Video
Why does my panasonic tc p50st30 tv menu not work, tv will turn on but can not shut it off unless I unplug tv.
I would believe this to be a problem with the lvds cable that goes from your logic board to the main board. If your tv does not have a logic board, then it would have to be incorporated into the main board. A lot of times the connection gets loose on the main to logic board. If you reseat it, it may fix itself. If nothing else, you can pick up a logic board on ebay for around 25 dollars with shipping. It is usually very easy to replace. Most of the time, it's hidden behind the A board known as the Main board. It would probably take less than an hour to put in for someone not familar with the internals of a tv. Just MAKE SURE the tv is NOT plugged into the AC line.
Regards,
Joe Van Buren
Aug 06, 2014 | Panasonic VIERA TC-P50ST30 50-Inch 1080p...
Hi, my Panasonic PT47WX49E rear projection tv suddenly shut itself off. It won't turn back on at all unless I unplug it and plug it back in. However, when I do that, the power light comes on but nothing...
Either give me a yahoo or note if light on front of set blinks--count the blinks if it does.
most common is 3 blinks, pause 3 or 5 blinks etc.
Let me know if I can assist you.
SD TECH
Sep 14, 2010 | Panasonic PT-47WX49 47" Rear Projection...
32 LCD, Shuts off, power light flashes 7 times. Never stops. Will not turn back on unless I unplug. Works for a few mins and shuts off again.
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 22, 2010 | Panasonic Viera TX-32LX70 32 in. LCD TV
TV cuts out
Loose connections on power supply and vertical IC.Resolder
Aug 04, 2009 | Panasonic CT-32D12D 32" TV
TV won't stay on for more than 2 seconds
TV turns on for 2 seconds then shuts off. Sleep/timer blinks. Won't go back on unless unplugged and plugged back in
Nov 16, 2008 | Televison & Video
Panasonic projection tv (shuts down)
check r517 on the power supply board if it is burnt or damaged replace it with a + or - 5% 10K 1/4 watt resistor this has been a problem in other units.
Oct 03, 2008 | Panasonic PT-47WX51 47" Rear Projection...
Panasonic Viera TH-42PV7HS Plasma keeps shutting down
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Burnt spot on lower portion of tv screen
try to pin point which crt is at fault if it is image burd ,by covering eash crt and viewing the sereen
Sep 01, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Open Questions:
Has anyone had problems with connecting an 'HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input,HDMI+ Audio output)' to a Panasonic PT-53TW53? I have a TiVo Premiere hooked up to my Panasonic PT-53TW53. I use the HDMI out, and RCA R+L outputs on the TiVo, and hook up to the digital in connections on the TV. The conversion of the HDMI out is via an HDMI to DVI cable. This has worked perfectly for years, but recently I wanted to disconnect the TiVo and replace with my Roku or Amazon Fire TV. Both have a single HDMI output. So I purchased an AGPtek HDMI to HDMI + SPDIF + RCA L / R Audio Extractor Converter (HDMI input, HDMI+ Audio output) box, hooking up the HDMI output from the Roku or Fire TV to the input on the extractor/converter, and simply disconnecting the HDMI to DVI and RCA R+L outputs from the TiVo, and plugging them into the outputs on the converter/extractor. The converter/extractor has a 3 position switch: PASS, 2CH audio, or 5.1CH (via and SPDIF or Toslink cable). I have had 2 of these converter/extractors, and with both the Roku and Fire TV I got the same results with both converter/extractors: With the switch on 2CH, which is where I understand I should get HDMI video and 2CH RCA audio, all I get is the RCA audio. No video. If I switch to PASS I get video with no audio. Of course on the 5.1 setting I get nothing, since the TV does not support SPDIF. Yet I see reviews all over Amazon indicating folks are using this converter/extractor for this very purpose, and it is working fine. I can't possibly imagine that it is some sort of incompatibility issue with the TV, since the TiVo has worked (and continues to) fine for years. Any ideas?
Feb 28, 2017 | Panasonic PT-53TW53 53" Rear Projection...
See all Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Questions
Panasonic PT-53TW53 53" Rear Projection HDTV-Ready Television Logo
63 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
