Question about Sony Audio Players & Recorders
I have a sony digital audio/video control center cinema studio ex and i have no idea how to hook up the surround sound to the tv and dvd player. i have to instructions
I have a Sony digital audio video control center that has a block on it which i can not start my system it reads protecter on it, how do I get it started.
Posted on May 29, 2010
  • leigh elvin
    leigh elvin Sep 27, 2013
    not sure but try holding the power button on for 5-10 seconds, this resets mine, it may work with yours.
I received an I-HD901 surround system. How do I hook it up directly to my Sony tv and do I need to buy a receiver or an amplifier?
DON'T NEED A SEPERATE AMP THE SYSTEM HAS ONE IT IS PART OF THE CABINET THE DVD PLAYER IS IN, YOU CAN HOOK IT TO THE TV WITH A HDMI CABLE OR STANDARD VIDEO CABLE OR A PROGRESSIVE SCAN CABLE SETUP, FOR AUDIO U CAN USE STANDARD RCA CABLES, OR DIGITAL AUDIO, CHECK TO TO SEE WHAT OUTPUTS AND INPUTS THE TV G THE TV HAS ALSO CONSULT YOUR USER MANUAL FOR THE SURROUND SOUND. HERE ARE THE SPECS FOR THIS SYSTEM.
1000 WATT system total program power
5.1 Cube cinema HTS, 12 active drivers/magnetically shielded
I-Cube design satellite system
4 Multi-directional 2-way speakers()
center channel has 2-way with horn tweeter enclosure (200 WATTS)
Dual sub-woofers 400 WATTS; 2X6.5" aluminum poly-laminate cone
linked through digital custom crossover circuitry finished in: high-gloss piano and composite black w/silver brushed aluminum
complete 6 piece system (HTS surround speakers
Jan 08, 2010 | Sony DAV-S300 System
I have a Samsung 5.1Ch Home Cinema System. HT-Z320 and a SONY Integrated Digital TV DV3. Is there any way that i can set the surround up so that the tv can be played througt surround system and not just...
I just hooked up my HT-Z320 today. I had to use an optical audio cable to connect the audio output from my TV to the optical audio input in the samsung receiver (it's the only optical jack on the receiver). Then with your samsung remote in DVD/Receiver mode, click the Auxiliary button (near the top right of the remote). Hope this helps.
Nov 18, 2009 | Sony Televison & Video
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
I only get sound out of 2 front speakers with 5.1.
refer owner manual page 46-51, try different surrounding sound modes.
Apr 08, 2009 | Sony STR-DG510 Receiver
Help with connecting home cinema to xbox
if your tv supports this. go to ebay type in "hdmi" buy one for around $10.00 plug into xbox. set your tv to which port you have ,(if you have more then one). bingo,bango ,your done.
"no hdmi"? and you have com. on your tv. plug corrosponding color plugs for component ,L&R audio plugs .
change tv to comp.( not video) your done
Jan 30, 2009 | Audio Players & Recorders
Hooking up sony dav-hdx 475 with digital cable box and hdtv
Plug the digital cable box audio strait into the dvd player. Plug video from the digital box into your tv.
Thats what i did and it works perfectly.
Jan 04, 2009 | Sony DAV-HDX500 System
We have recently just bought a samsung htx250r home cinema. we have a 50 inch samsung plasma, the dvd player sound works using the hdmi cable but the surround sound does not work when we are watching...
Salutations ddog,
Really this is a question of sources. The reason your able to hear surround sound when connected to your DVD player is that is what is providing your audio and video source. When your watching television it would depend on how your getting your broadcasts. If you are either receiving an over-the-air broadcast or cable directly to your set, your television becomes the source. As your television is providing the signal, you would need it to loop back to your receiver to provide that surround sound.
Now for the good news, if you have a cable or satellite box these should have outputs to connect to your receiver to provide the audio source.
Also keep in mind not all broadcasts provide a version of surround sound. Most newer home theater systems will replicate surround sound artificially.
I hope this helps.
Jon
Go Ahead. Use Us.
Jul 05, 2008 | JBL SCS200.7 Home Cinema Package System
SETTING UP TJE PANASONIC DMR TO OTHER COMPONENTS
if studio audio facility in tv there [are] hence remaining to install just input channel of output but if there is no having to suround efec,thank.........
www.modifmax.com.
Feb 08, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
623 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
