There is an easy way to setup this remote controllerl(RC). It called "Automatic Code Searching" which means that you don't have to even find the code. The controller will searching it for you. Just do the following steppes.
1. Turn on the "Device" to be remotely controlled, e.g. TV, VCR.
2. Point the RC right to the "Device" .
3. Press a device button on the RC represent the "Device", e.g. TV, VCR, DVD etc. You can see the indicator lid flash once.
4. Press the SET and than the POWER button on the RC. hold both buttons for 2 seconds or more, you will see the red lid on. then release both buttons simutenously. after that the indicator lid will be flashing, means the searching started.
5. Keep pointing the RC to the "Device" until it is shut down by the RC, Press any button in 1.5 second to finish the setting.
You can try the RC now. It should work. My one is working.
Try 571. If this doesn't work try setting the code via the automatic programming feature.
RM-810 Automatic Searching 1.Turn on the TV 2.Press the “TV” key (*, **, or **) you want to program on the remote. The light should flash once. 3.Press the “Set” and the “Power” button simultaneously for 2 seconds. The indicator light should stay on. 4.Release both buttons. The indicator light will flash constantly indicating the automatic search mode. 5.After the indicator light illuminates, release the two keys simultaneously. 6.If the controller can turn off the device during its auto programming, you can finish programming in 1.5 seconds by pressing any other button on the controller 7.Check whether operation of other buttons is at normal state. If so yor setting is successfully accomplished.
If you cannot control the functions, try steps 2 through 5 again. If you do not press any button, the auto search function will stop after 30 seconds and the indicator light will go out and you will have to restart the auto search.
Let me know if this works for you. Thanks.
