Question about KitchenAid 24 in. KUDP01IL Stainless Steel Free-standing Dishwasher
KUDP01IL Dishwasher heating element
The heating element on this dishwasher seems to be on all of the time. I just installed this unit that was given to me so no other info available. We unplugged the element when we installed it so we could use it
    President:
  • KitchenAid Master
  • 2,651 Answers
Element on allthe time sounds like a direct short of the wire leading to it, trace back the wire , it will lead directly to control board behind front panel. there should be a tech sheet behind the lower kick panel complete with wire diagram
Posted on Mar 04, 2008
Dishwasher will not go into Dry cycle. It was given to me and perhaps I did not install it properly.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Dec 13, 2010 | KitchenAid KUDI24SE Built-in Dishwasher
Not good cleaning, soap film baked on dishes
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Nov 20, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Hi, our dishwasher runs too long and smells bad. Seems to get stuck for along time during the heating period. The water coming in is hot enough but then after heating it for a long time seems to be more...
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
heatman101
Aug 27, 2010 | KitchenAid 24 in. KUDS01DLSS Built-in...
Dry cycle doesn't work
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 15, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Top shelf not cleaning
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
heatman101
qqqw
Jun 12, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
Our dishwasher is starting to run very long-2 hour cycle and not always the cleanest dishes
Check your heating element. possibly you have a reset button on the safety th/stat near or on the element.
May 15, 2010 | KitchenAid 24 in. KUDP01IL - Multiple...
My bosch dishwasher's heating element seems to have gone
heatman101
aerrafdb
May 04, 2009 | Audiovox Bosch 718 World Cellular Phone
Bleeping dishwasher
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
  • On some units, the pause is timed and the unit continues after the allotted time.
  • On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
  • Nov 03, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
    Wet dishes
    If the dry cycle has a problem, check these:
    Heating element
    Drying fan
    Thermostat
    Heating element Your dishwasher has an electrical heating element that helps to dry the dishes. If the element is burned out, the dishes won't dry properly, and you need to replace the element.
    Drying fan Many high-priced dishwashers have a small fan that blows air or heated air into the dishwasher to speed up the drying process. If the fan is defective, you need to replace it.
    Thermostat Some dishwashers have a thermostat that monitors the drying temperature. If the thermostat is defective, the heating element may not cycle on or off properly. If that's the problem, you need to replace the thermostat
    Jul 19, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
    KitchenAid 24 in. KUDP01IL Stainless Steel Free-standing Dishwasher Logo
    171 people viewed this question
    Top KitchenAid Dishwashers Experts
    Carmen Mikulic
    Mike
    Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
