Question about Sewing Machines
Sewing machine not picking up bobbing stitch
Why want my sewing machine pick up bobbin siitch
  • 1 more comment
  • Slavica1961 Mar 20, 2008
    I have a same problem, my machine singer Futura 200 don''t pick the up bobbin stitches and I can't sew at all.
  • Jessicakes Nov 20, 2008
    It will pick up stitches and then stop and they won't lock at all, and then it will go back, so there's parts of the fabric where its obvious that its not sewn.
  • LizMan Dec 28, 2008
    my Simplicity machine will not pick up the bobbing thread, I have changed the needle and replaced the bobbing.
MY 132 Q SINGER FEATHERWEIGHT SEWING MACHINE,
WON'T PICKUP THE BOBBIN STITCH
Posted on Nov 27, 2010
Wont pickup bobbin thread when sewing.
Make sure you are using a brand new needle. Bent/damaged/dull needles frequently will fail to pick up the thread.
If it continues to skip stitches, it most likely has a needle/hook timing issue--the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
There are web sites and videos available that discuss sewing machine timing, or you can take it for service.
Sep 10, 2016 | Sewing Machines
Machine wont sew. Misses stitches
check for problems in the bobbin winding, ( in the wrong way so that the thread is not coming out correctly)
top thread tension too tight or too loose
vary the thread tension to see when it improves on a waste test sew
Aug 21, 2016 | Sewing Machines
The needle is not picking up the lower thread, I have cleaned the machine but the bobbin is not being picked up
Doesn't pick up bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Warped needle
8. Warped bobbin
9. Also could be a timing problem
Feb 10, 2016 | Sewing Machines
I can't get the machine to pick up the bobbin thread..How can I fix this problem?
Have you tried installing a brand new needle? The old one may be bent.
Remove all the thread and rethread from the beginning.
Jan 07, 2016 | Lil Sew & Sew 12 Stitch Electronic Desktop...
Sewing machine not stitching
SKIPPED STITCHES
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
it's also possible that the machine needs to be serviced
May 31, 2012 | Singer Sewing Machines
The bobbin thread will not pick up. The machine had jammed and I forced the wheel and can't get bobbin thread to pick up. When I thread manually, I only get holes, no stitches. Is it a timing belt?
check your needle to see if it's bent---roll on flat surface to see if it roll correctly
on some sewing machines when the thread comes off the thread take up lever it can cause the machine to jam
also if the bobbin thread becomes tangled it can jam
check the bobbin area for lint or loose threads
try having a top thread tail & bobbin thread tail of 3-4 inches
try holding the top thread tail & turn the handwheel on the right side on the machine manually & put the needle down into the bobbin area & see if the bobbin thread will pick up that way
Sep 24, 2010 | White Sewing 2037 Mechanical Sewing...
NEEDLE WON'T PICK UP BOBBIN THREAD
im not!
it needs a good service the timeing has sliped out a little, nothing more that that,,,see its not a lost cause just yet
Oct 24, 2009 | Singer Featherweight 140Q
Bobbing thread not picking
Make sure you have threaded the bobbin thread correctly. Also your top thread must be correctly threaded in order to pick up the bobbin thread.
Please let me know if I can help any further.
Best wishes,
Graemevm
May 01, 2009 | Janome 6019QC Mechanical Sewing Machine
Singer sewing machine model 6012 c
hi
i want to know how i put thread in the sewing machine
thank you
Dec 15, 2007 | Sewing Machines
Sewing Machines Logo
349 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
