Unplug the dryer and the first thing to do is check for the presence of
220 volts at the wall outlet. If you lost one leg of the 220 volts, it
is possible for your dryer to run but there will not be any heat. Once
you verified there is definitely 220 volts at the wall outlet, remove
the rear cover. On the lower right hand side you will see a silver
canister which contains the heating element. Remove the lower two wires
directly from the heating element and check this for continuity. If it
is good, on the left hand side of the same canister they often install a
thermal safety which may have tripped. Do the same test as with the
heating element. Remove the wires and test the thermal safety for
continuity. If this is good, move to the blower housing on the left
side of the exhaust vent and look for a white piece of plastic which has
two wires on it. Remove these two wires and check this item for
continuity.
you can follow this link below to find out how to test for individual components to find out what part is faulty...
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
You can also order for any replacement part from the following Websites
www.PartSelect.com
www.SearspartsDirect.com
If you found my solution of any help ... please do not forget to rate the solution
