Question about InFocus Proxima UltraLight SP1 Multimedia Projector
Proxima Ultralight LS1 image problems
I have a new bulb in the projector and I am still getting ghost images/double images on the screen. The Lamp Replace light comes on and is green, is there something that I am doing or is this projector a lost cause?
Thanks,
tinamarie49
  • 34 Answers
SOURCE: Proxima Ultralight Projector 350x
The filters probably need cleaning. Also check and make sure none of the vents are being blocked.
Posted on Dec 05, 2007
SOURCE: InFocus Proxima UltraLight LS1 LCD Projector
needs a new bulb
Posted on Dec 21, 2007
dhiman
  • 115 Answers
SOURCE: NEC vt460 Projector have a ghost problem on the screen
Hello
Pls Service the LCD Panels of the Projector, Also check the Fly-Eye lens, just next to Lamp unit. This will solve your problem. if it's not then the only solution is Replacement of LCD Panels, But Must check or replace the external RGB Cable first befor doing all this exercise.
Posted on Feb 07, 2008
SOURCE: ask proxima m2+
lamp gets brighter & brighte within a minute & immidiately color wheel stops rotating & projector goes to standby mode. for 3 to 4 minutes again same symptom contimuously observed pls guide me which part is suspected
Posted on Feb 16, 2008
  • 17 Answers
There could be several reasons for this problem.
1. New lamp needed.
2. New lamp did not fix? Could be mirror tunnel behind the color wheel than can collapse causing "dim" light source or dark lines.
3. All items "greyed" out caused when the unit does not sense a source input, ie computer or tv tuner. After connecting to a source, you should be able to go and adjust contrast and/or brightness settings
Posted on Feb 19, 2008
Proxima Utralight LS1 does not display what is connected to it. The bulb is good, the projector displays its own menu, but it does not display anything from any computer connected to it.
make sure you're on the correct source on the projector. now i'm not sure if you're using a laptop, if you are, then you're gonna have to press FN and F5 (depending what type of laptop you have, sometimes it's F8) buttons on your laptop. this activates the computer port of your laptop.
May 27, 2011 | InFocus Proxima UltraLight LS1 Multimedia...
Bought a new Dell Vostro laptop with Windows 7. Does not pick up a Proxima dp2000x projecto. Any suggestions
the resolution doesn't match. the dp2000x is a relatively old projector that can't handle the laptop's signal.
Feb 08, 2010 | InFocus Proxima UltraLight LS1 Multimedia...
I just bought a Proxima Ultralight LX1 without a bulb on Ebay for the purpose of replacing the bulb with a cheap halogen bulb. Well I did just that and now when I turn it on, it displays the computer image...
if the image is black but the light is still on, it's having trouble holding on the the resolution. reset the settings to factory default and make sure the resolution matches. if the lamp goes out too, replace the ballast.
Jan 26, 2010 | InFocus Proxima UltraLight LX1 Multimedia...
Why is the 'lamp' button is lightning ?? but its work. are the lamp old ??
the lamp is only good for about 2000 hours (sometimes more, depending on the manufacturer's specs). the projector has a lamp timer to warn you when it get's close to the end of the lamp's life. i think it's time to change the lamp and reset the lamp timer. if you don't change it, it'll blow while it's on and possibly shatter.
Nov 05, 2009 | InFocus Proxima UltraLight LS1 Multimedia...
Have an old proxima, adjusted the focus and still the display is a little fuzz Is it new bulb time?
Phoned the Infocus people and they said, the len was out of place. Len repair in this case would be costly. Could buy a newer projection unit for the price of the repair with great amount of lumens than the current proxima unit. Yet if anyone, knows of a cheap fix, please post it.
May 07, 2009 | InFocus Proxima UltraLight LS1 Multimedia...
My Proxima Lx2 has a bulb issue
Hi there
You have to reset the lamp timer.
Should solve your problems.
Mar 31, 2008 | InFocus Proxima UltraLight LX2 Multimedia...
1. New lamp needed.
Oct 01, 2007 | InFocus X1 Multimedia Projector
InFocus Proxima UltraLight SP1 Multimedia Projector Logo
105 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
