I have a dvdr3355.It has a rewritable dvd in it thatI have been using and has recorded programmes on it.I am trying to remove it but the window just says blocked and I cannot find a way to release it.Could you please help me
  • 4,889 Answers
Most DVDRs have a small hole at front. You can try inserting a pin into the hole , repeatedly pressing the eject button.. Hope this helps. Good luck!
Posted on Feb 27, 2008
    Master:
  • 555 Answers
First, make sure the DVD Recorder is completely disconnected from the main power supply.
Turn it over and look at the base of the unit, (just underneath the front of the Disc Insert/Eject Tray). There is a small slot (approx 25mm x 8mm) in which you can see a small, white plastic lever, probably situated near the right-hand side of the slot.
Moved this white lever gently to the left, and the tray should open by itself.
Remove the disc, and the recorder will no longer be blocked.
  • Matt Jurach
    Matt Jurach Feb 29, 2008
    On this unit the manual "emergency eject" hole is not on the front; it is underneath as I described. Have you been able to access the white lever?
  • Matt Jurach
    Matt Jurach Mar 05, 2008
    I'm hoping you have recovered your disc by now. If you found a solution that worked, please rate it. Thanks!
    Scholar:
  • 110 Answers
If you cannot get the disk to eject, power the device off and insert a paper-clip into the emergency-eject hole in the front of the device. It should be located just under the disk tray.
When recorded that show its record but after some time its not paly in any player even my Sony DVD cam also
try to find a rewritable media that is compatible with your player, like it can read recorded dvd disc . some dvd plyer dont have capable of reading photo cd, recorded disc, burned disc etc. maybe your player is the one like that.
Feb 02, 2011 | Sony Mini DVD-RW 1.4GB 30 minute ( 8cm - 3...
Brought 5 maxell 1.2x rewritable 4.7 gb data dvd-rw tried to record a film keeps saying no disk what am i doing wrong? kind regards ken moore
if the other 4 dvds are still wrapped take it back (in exchange for 4x 4.7gb dvd-rw)...you picked up 1.2x your player maybe looking for higher speed..these recorders are very sensitive for the type of dvds it use..(i can only use maxell /panasonic + dynex (online))..cant use some of those on sale ones.....my recorder wont just eject it it rejects,,,,
hope this is your case, feel free to rate the help
Jun 16, 2010 | Maxell MAX635114 Rewritable Single-Sided...
The disc is block inside
Try unplugging and when you plug in again press stop at the same time.
Feb 25, 2010 | Philips DVDR 3355 DVD Recorder
Need A Users Manuel For My Dvd Recorder DVDR3355/37
To view your owner's manual in PDF format, click here: DVDR3355/37
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks.
Feb 06, 2010 | Audio Players & Recorders
Recording
sometimes this happens. now. the dvd you put in was it rewritable. a friend could not run his dvd recorder until i gave him a dvd+r rw disc in and lo, it worked.
some dvds have this function without telling you, perhaps it is in the instructions in small print.
also, try a straight dvd+r disc, not a rewrite. experiment with other discs because some will not see cheap discs but expensive ones.
i have dvd that does not even reconise a dvd, but when i wish to burn a dvd, i use that one because it is the best.
strange isnt it...
Oct 28, 2008 | GoVideo R6750 DVD Recorder
Recording problem - DMR-E55
Hi Steve
Please see my earlier answer to this common problem >HERE<
Best wishes..
Sep 20, 2008 | Panasonic DMR-E55 DVD Recorder
Dvd recorder funai
I have fixed mine with the same problem , all it needed was the lens cleaned , i used a laser lens cleaning disc from maplin for 6.99 and voila good as new.
May 09, 2008 | Funai PY90DG DVD Recorder
Recording problem
I have had two of these recorders, Using only Sony + discs or rewriteables is my solution, I will not use any thing else. It may work 1-3 times on others brands then start throwing coasters.
As to renaming, on my model I pull up the tiltle menu then select Try using rewriteables for the other problem as well My model is a little older and lets me take disc out without finalizing then when inserting select title, hit edit on remote and select rename. Maybe if you can skip the finalizing (as with rewritables it will help
Apr 01, 2008 | iLO DVDR05 DVD Recorder
Dvd wont reconize dvd +
Have you tried the rewriteables, they don't require to be finalized at all. ILO's are real picky, I returned two to Walmart before discovering to use ONLY SONY + or the rewriteables(brand doesn't seem to matter on the rewritables, don't know why.
Mar 26, 2008 | iLO DVDR05 DVD Recorder
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
