Question about HP Compaq FP5315 15" LCD Monitor
Problem with my keyboard
When i press any key it takes about two seconds before it displays any typing on the monitor
    Problem Solver:
  • 11 Answers
This is usually a problem with the computer and not the keyboard. Causes could be a few things. First is the program you are using is too big for your computer to handle. (most likely not the case though if you are only using Microsoft Word or similar apps.) Make sure that you dont have a lot of programs running. Even with a fast computer, if you have a dozen programs running, it will slow down. Try going to Start on windows, then Run, then type msconfig. Take off the applications you dont need to start when you boot up your comptuter. This way, you don't have a 15 minute boot time, and you can also see some of the things that are running in the background that you don't know about. I know it's kind of like a long solution. I hope it helps, let me know what happens
Posted on Feb 28, 2008
  • 1,226 Answers
You problem is so many application programs run in services of the system, these are cause by virus attack, system specification is low. memory damage and harddrive mulfunction.
It is good if only the system is the problem you can reinstall the windows, however if the memory or the hard disk, you should replace that.
In this case , first , scan your system sith potent antivirus,
you can click this
or try replacing the keyboard, memory. and the last is the hard disk.
If it is new hard drive then you should install the operating system on it.
best reagards, melnavz
Why is my laptop screen black during startup?
I recommend you to connect an external monitor and check if there is display on it. Press 'Windows' + 'P' on the key board to get display on the external monitor.
I also suggest you to run diagnostics on display. To test the display shut the system down, next press and hold the letter 'D' on the keyboard and press the power button. This will initiate diagnostics on the display. Please check if the colors are displayed across the screen without a problem.
You may also try this step that is shut the system down, remove the battery and disconnect the ac adapter, press and hold the power button for 20 to 30 seconds. Now connect only the ac adapter and wait for 30 seconds , press and hold the Fn key on the keyboard and power on the system. This will run diagnostics on the hardware components and also the display.
check also:
Please let me know if there is any light on the keys shows below:
if any of these are flashing in a sequence
please reply back with results
Jun 08, 2014 | Dell Latitude E5500 Laptop
Hello i have a problem i have a epson ex30 projector and i cant make it work with mt toshiba labtop
When connecting a projector or second display to your laptop, you may need to tell the laptop to "clone" or "duplicate" your display onto the second device. This can be done one of two ways:
  1. A key combination on your keyboard.
    A. While holding the Function or Fn button on your keyboard, press the
    Function key that shows a picture of a monitor or a computer and a
    monitor. On my Toshiba laptop, this is F5.
    B. You may have to press the Function key multiple times. If this doesn't
    work, proceed to option 2.
  2. The video card driver's settings.
    A. Navigate to Start>Control Panel>Display
    B. In Windows 7: On the left-hand side of the window, choose "Connect to a
    projector". A dialog box will popup. Choose "Duplicate".
Mar 06, 2011 | Computers & Internet
Hi, I have a Dell Latitude D830. The display was off. I can connect extrenal monitor for current work. Please advise if I need replace display or motherboard ? Thanks Alex
Before replacing anything verify that your laptops display type didn't get changed to VGA out only.
look at your function keys (usually top one or two rows ) and look for the key that has a pc/monitor icon. with the machine powered up and connected to the external monitor press the function (FN button lower left of keyboard) and the video/monitor button at the same time. most laptops have 3 settings:
laptop display only, external display only and laptop and external display. Press the FN/Display button at lease 3 times waiting 3-5 seconds between keystrokes. I have seen this many times where the FN/display button keys are hit inadvertently.
Typically if the motherboard or video card fail the external monitor would not work either.
Jan 04, 2011 | Dell Latitude D830 Notebook
My compaq laptop turned on after few seconds turned off it is (no display observed). laptop starts or its power light starts after pressing F10 button but no display on screen ocurs
Hi Bonde Ramipr,
It is possible that you have a faulty display, can you connect your notebook to an external monitor?
you will need a Monitor and a VGA cable (the same cable you use to connect a normal PC to a monitor).
after you conect the notebood to the monitor start your notebook. you should be able to see the boot process on the monitor, if not you may have to tell your notebook to use the external monitor. you can do this by pressing the "fn" key on your notebooks keyboard and at the same time pressing the key that cycles the display output. I will try to get a picture for you.
Oct 21, 2010 | Compaq Presario C700T Notebook
I have an hp pavilion dv5. When I power it on the computer starts up but the monitor doesn't come on. And then it does this series of beeps. Beep beep beep. It does that series 5 times
Before you begin
Check the following items before using the steps in this document:
•If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
•Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
•If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
•Disconnect all connected devices except the mouse, keyboard and monitor. This includes thumb drives and camera-type memory cards from card reader slots.
With the devices disconnected, restart the computer. If the computer starts and the monitor now displays a picture, a device is preventing the computer from starting. Update the BIOS to resolve this issue.
Step 1: Connect the computer to another monitor
Connect another monitor to the computer to determine which device has the problem (the monitor or the computer). This step is very important to help you determine if the problem is coming from the computer or the monitor. If necessary, temporarily connect the computer to a friends monitor for troubleshooting purposes.
After the monitor is connected, turn on the computer and the monitor. What happens?
•If the newly attached monitor does not display anything , disconnect the cable and continue at Step 2: Is the video connection damaged?
•If the newly attached monitor displays the first startup screen(s) but then goes black, there is a problem with Windows starting. Skip to step 5 .
•If the new monitor works , the original monitor or its cables are faulty. Do the following:
1.Replace the monitor power cable.
1.Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
1.Replace the video cable.
1.If the monitor does not work after replacing the cables, replace or service the monitor.
Inspect the video cable and video connectors for damage. Check for sharp bends or breaks in the cable and bent or broken pins at the connectors. With the monitor and computer off, try to straighten bent pins with a small metal tube, like the tip of an empty mechanical pencil or the tip of a retracted pen.
Figure 1: Video connector
If you had to straighten any pins, reconnect the monitor making sure that the video cable is firmly connected and then turn on the computer and monitor. If the display is still blank, continue to the next step.
Step 3: Resetting and updating the BIOS
You can use these steps even though you will not be able to see anything on the monitor.
In case an item was changed in the BIOS, such as the primary display device setting, use the following steps to reset the BIOS back to its default configuration:
1.Turn on the computer and repeatedly press one of the following keyboard keys. Press the key about once every second for 5 seconds after turning the computer on.
◦For HP and Compaq computers that came with Windows 7 and Vista, press F10 .
◦For HP and Compaq computers that came with Windows XP, press F1 .
◦For Compaq Presario desktop computers built prior to 2002, press F10 .
1.Wait another 5 seconds.
1.Press the F5 key. This restores the default settings of the BIOS.
1.Press the Enter key. This accepts the changes.
1.Press the F10 key. This saves the changes.
1.Press the Enter key. This saves the changes and exits from the BIOS.
1.The monitor should display the first screens received from the computer (the logo screens). If not, find and download the latest BIOS update if one is available for your computer.
1.If a BIOS update was not available or the monitor is still blank, continue to the next step.
Jun 11, 2010 | Computers & Internet
I have a toshiba A100 with windows 7, 32 bit. i jsut got a s-video to VGA so i can watch movies and such on my tv. however, there is no picture on the tv, windows says everything is working but all i get...
PC Running Windows
Windows XP is used, but Windows 2000 should be similar, as is Windows ME -- but Windows 98 and 95 are different.
  1. Please connect your PC to an external monitor to try this out BEFORE coming up to speak. Have your VGA adapter cable ready as well if your Laptop needs one and bring it with you to the stage.
  2. Connect the external monitor to the PC
  3. On the Laptop display, RIGHT CLICK on the desktop and say Properties.
  4. Click on the SETTINGS tap (far right) If you want your displays Mirrored, (what is on the internal display is on the projector) you should make sure the box next to " Extend my Windows desktop into this monitor" is UNCHECKED. Some older systems have a “ mirroring” box, check that if you see it and want mirroring. If you do not want mirroring, skip the next section and continue with 5a below, then return to #8 of the section immediately below.
  5. NOTE: The following steps apply if you are running your PC in MIRROR mode only. If, however, you're running your PC in NON-MIRROR mode you need to continue with these special instructions instead.
  6. Drag the screen slider to 1024x768 (if your laptop will let you.) Typically, the external monitor MAY limit this setting. If your screen display is higher, it might not display on the projector, so you might want to test this before you are ready to speak. Drag the color quality to Highest (32 bit) if available, or Medium (16 bit) if the first is not available.
  7. Now, look at your keyboard. Typically, one of the function buttons will have the words CRT/LCD or perhaps a small picture of a monitor on it. Note this key for future use. On a Dell, it is typically F8. And I have seen it in F5 as well. Your machine's keys will vary, but it should be there. Holding the FUNCTION KEY (FN), Press the proper function button ONCE and wait. After a few seconds, the second display should come on. Be patient, this can take up to 5 seconds. On the projector, it may take up to 10 seconds for the projector to detect your system and switch. Note: a second press of this function will (usually) switch to EXTERNAL monitor only. A third press will go INTERNAL only, and around the circle for each press after that. Also note that some laptops may do this sequence in a different order, so learn your system so you can quickly switch to the mode you want.
  8. Click on the ADVANCED button. If "apply the new display settings without restarting" is not selected, select it. Under Screen Refresh Rate, select 60 Hz. Click APPLY and CONFIRM the choice. Click OK to close the ADVANCED dialog window. Close the Display Properties Dialog. You should now see a mirroring of your monitor on the second monitor
  9. Testing: As a test, disconnect the second monitor, put your laptop to sleep. Wake it up and let it fully come up (log-in if necessary), and then reconnect the external monitor. On some machines, it should quickly display the screen in the last known setting (you may need to wait up to 10 seconds.) If it does not display correctly, press the monitor switching function key ONCE. Again, note that it may take up to 10 seconds to display, so be patient. If only the projector now displays, a few presses of the switching function key should bring it around to both displays again. If you cannot get the projector to display, recheck all your connections and settings stated above.
  10. Note that when using the Projector, after pressing the Function key for the monitor change, it may take up to 10 seconds for the monitor to find and lock on to your machine. Just wait for it. Pressing the FUNCTION key again may simply mess up your settings or switch the projector off.
  11. When you arrive at the front of the room to speak, connect your monitor to the display cable (BRING YOUR ADAPTERS FOR YOUR LAPTOP TO VGA IF NEEDED.) When the monitor switch is switched to display your laptop on the projector, it should detect the display and just show up, but some systems will not automatically switch. Again, if this does not happen, you may need to press your display function key to switch on the external monitor.
  12. A few more notes on this: Not all laptops work the same way, and there are some differences in Windows OS releases on the order of the switching functions. You should learn how yours works BEFORE you get to the stage. Also, I noted a difference between computers put to sleep before connected, and systems which have not been put to sleep. If the computer was connected to an external display, disconnected and then reconnected with no sleep in-between, the external monitor should should come right on when connected. However, on most of the systems I tested this on, if the laptop went to sleep between connections, it required using the switching function key to get the screens back on UNLESS the display was connected before waking the unit. On two Dell’s, pressing this key brought back the projector, but not the internal display, requiring two more presses of the key to get both displays on. Chalk it up to different hardware and software releases.
  13. When done, disconnect the external monitor. From the display menu drop down, you can reselect your desired display resolution.
Dec 30, 2009 | Toshiba Satellite A60 Notebook
How do I change resolution on monitor?
that is easy
go to control panel
go to appearance and themes
go to display
go to settings
near bottom is screen resolution select the resolution supported by your video card.
Nov 18, 2009 | HP Compaq WF1907 Monitor
Pressing arrow keys on my Logitech keyboard flips view on monitor
problem might be with your key board...but you can disable rotation in monitor display properties
Oct 01, 2009 | Logitech Internet 350 USB Keyboard
Second monitor is connected but screen remains
Hi, Ronald.
If you look at the function keys (F1 through F12) on the top row of your keyboard, you should see a CRT/LCD label or symbol, typically on F4 or F8 (may be different for your laptop).
Press the Fn key (typically on the left bottom of your keyboard) with that function key and you would toggle through accessing your laptop display, your external monitor display and both displays (may not be in that order).
Hope this helps.
Sep 17, 2009 | Microsoft Windows Vista Home Premium with...
Acer aspire one second display monitor blue
Look onto your keyboard. There is a key that looks like 2 oval one shaded the other clear. Press FN and that key with the symbol on it. It will turn off your LCD and put it into the other. Then hit it again, both screens will have power, but slightly dim, press it once more to turn it off.
Good Luck
Jun 18, 2009 | Acer Computers & Internet
HP Compaq FP5315 15" LCD Monitor Logo
53 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
