Too much ink being feed to machine
Could it be the toner sensor
Hi, dependant on what machine, some machines require the developer to be set up, others do not.
Andy
Posted on Feb 28, 2008
Machine says add toner see front cover
is the door closed tight , may have a dirty sensor
Nov 14, 2014 | Ricoh Aficio Mp 2500 With Feed, Fax, Bank,...
Tip
ERROR codes Canon 8570
Canon 8570 E000 Fuser problem. Temperature too low. Heat lamp, thermal fuse or thermoswitch, thermistor, triac etc E001 Fuser problem. Temperature too high. Probably triac E005 Fuser web finished E005 Fuser cleaner belt user up E010 Drive E010 Main drive problem E011 Drive problem. Could be main motor, scan motor, cleaning web motor or duplex motor E011 Main motor, scan motor, cleaner belt motor, duplex motor, toner motor, lens motor or driver bd. for any of these E020 Toner sensor problem or lack of toner feed. This occurs if toner feed signal is present for 3 min E020 Toner empty sensor sees no toner added for 3 min probably toner feed problem E050 Duplex problem E050 Duplex problem E203 Scan motor problem E203 Scan motor E210 Lens motor problem E210 Lens home sensor or lens won't leave home E240 DC controller board E240, E241, E242 Control board (main board) E241 DC controller board E242 DC controller board E243 Operation panel board E243 Operation panel E400 DC controller, ADF board or 24V E400 DC controller or document feed board E500 DC controller or sorter board E500 DC controller, sorter board or 24V E510 Finisher; feed motor, pulse sensor, finisher board E510 Finisher E520 Finisher; stack motor, stack tray sensor, finisher board E520 Finisher
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 8070
Canon 8070 E000 Fuser problem. Temperature too low. Heat lamp, thermal fuse or thermoswitch, thermistor, triac etc E001 Fuser problem. Temperature too high. Probably triac E005 Fuser web finished E005 Fuser cleaner belt user up E010 Drive E010 Main drive problem E011 Drive problem. Could be main motor, scan motor, cleaning web motor or duplex motor E011 Main motor, scan motor, cleaner belt motor, duplex motor, toner motor, lens motor or driver bd. for any of these E020 Toner sensor problem or lack of toner feed. This occurs if toner feed signal is present for 3 min E020 Toner empty sensor sees no toner added for 3 min probably toner feed problem E050 Duplex problem E050 Duplex problem E203 Scan motor problem E203 Scan motor E210 Lens motor problem E210 Lens home sensor or lens won't leave home E240 DC controller board E240, E241, E242 Control board (main board) E241 DC controller board E242 DC controller board E243 Operation panel board E243 Operation panel E400 DC controller, ADF board or 24V E400 DC controller or document feed board E500 DC controller or sorter board E500 DC controller, sorter board or 24V E510 Finisher; feed motor, pulse sensor, finisher board E510 Finisher E520 Finisher; stack motor, stack tray sensor, finisher board E520 Finisher
Why is it that am i getting a 585 and a 495 errors simultaneously on two of the same machines
You did not post the model number. I assume it is a larger machine such as a MP9000. The SC495 is a clogged toner hose from the cup to the toner sub-hopper. If the toner system is not clogged it is a bad toner pump, or sometimes it is a bad toner sensor on the sub-hopper or the cup on top of the auger from the toner bank. If the hose is not clogged and there is toner to the top of the sub-hopper then it is one of the sensors. They are identical.
Aug 11, 2014 | Ricoh Office Equipment & Supplies
Magicolor 7300 print window says Ink/toner waste bin full! but it's new
The clear section of the waste toner box where that goes inside the machine check that area sensor located there might have toner on it so the printer thinks the waste toner box is full
Apr 16, 2012 | Minolta magicolor 7300 Laser Printer
We have a Canon iR 2270 and get the the Error message E000024-0001. What might the problem be? How do i solve it?
if e000024-0001 is comming plz clean the toner box in which magnet roll is runing then try you machine is not give this e000024-0001 singnal.
Dec 28, 2010 | Canon IMAGERUNNER 2230 Copier
How can I tell may Xerox 5334 to feed toner?
Power the machine off. Press and hold the zero while you power the machine back on.
Then enter routent 9-05 and press start. that is the tone up procedure.
Jul 27, 2010 | Xerox Office Equipment & Supplies
We have a Sharp 1641CS copier will not feed or copy
Well one reason the Cartirdge is spilling is due to the cartridge backing up with toner everytime it tries to print, it misfeeds cause the paper feed tires need to be replaced,
May 29, 2009 | Sharp AL-1641CS Copier
When I try to print from computer, paper goes through with nothing printed
If it feeds fast, there may be dust or dirt on a sensor. Compressed air or a vaccuum might help.
If it feeds at a normal pace, you might be out of ink / ribbon / toner.
Sep 16, 2008 | Office Equipment & Supplies
Pagepro printer toner empty problem
1. It tries to pump toner into a reservoir. If it doesn't activate a full sensor for the reservoir, it shows toner low. 2. Take the toner out and shake it hard about 10 times, this will make any settled toner loose, and should solve this. The problem is normally caused by old toner (your supplier might have had it on their shelf for a year or two).
Aug 11, 2007 | NEC Nefax 655E Plain Paper Laser Fax
jasbo
jasbo
