I purchase a FreeAgent Go 160gb,getting started it does not do anything. the diolog window does not come up,unit just beeps...
    Genius:
  • 1,019 Answers
If this is an External USB Hard-Drive, your problem is insufficient power provided by the USB Port.
1:- Try Another USB Port If You Have One.
2:- If you have a 2 into 1 USB Cable, connect 2 into 2 individual USB Ports ( On Computer ) And 1 into Hard-drive Unit.
If none of this works, your drive is faulty.
Mike @ Compurepair.
** Please do not rate this, until your problem has been resolved ** Thankyou for using Fixya.
Posted on Feb 27, 2008
It fell whilst in operation and now just beeps and won't do anything more. I believe the technical term is buggered. Is there anything that can be done?
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismatle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues'
Thumbs up please if it's any use to you Thank you.
Aug 24, 2010 | Seagate Computers & Internet
Freeagent 500gb not responsive. No lights; just a beeping noise.
ok here goes, my neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not reconized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 hope this helps Ytee.
Good Luck
Aug 15, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate free agent external drive not getting detected
Aug 12, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Cannot read
It sounds almost like 2 things are happening,
1. The drive itself it going out or the board inside that is connected to the drive is bad.
2. or the drive is not getting enough power through the USB ports (or too much maybe?)
I have only encountered the beeping issue on my free agent 160GB when it was not getting enough power to spin up the platters.
If you still have warranty on it. I would HIGHLY recommend you call western digital about it.
Mar 20, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I have just purchased a Seagate 500GB Desktop hard drive
There is software preloaded on the disk. If you have AutoPlay turned off in your system, it won't start automatically when you connect the drive. Just go to MyComputer and open the drive and you will find a setup file there to install the backup software (I think it's called Launch.exe).
Oct 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Has been working fine since purchased, then, suddenly, started beeping and my laptop could no longer recognize it... Please tell me that it's not hosed...
Sorry but it probably is, go to windows explorer, right click my computer, go to manage and then look on disk management. If the disk does not appea there you are pretty much screwed.
I managed to get the cover up to plug it in to my sata port directly, and it still did not work.
Oct 16, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
160GB SEGATE freeagent external harddisk is not detecting in computer
it seems your hard drive is having problem, just ask your vendor from whom you have purchased the hard drive to help you.
Apr 21, 2009 | Computers & Internet
Seagate FreeAgent external hard drive 500GB not recognising directory tree
Its the rubbish software that Seagate have bundled with their drive which will not allow you to backup the system folders. Solution is to use another backup utility, a google search will quickly locate numerous FREE software products which will alow you to copy anything. Unfortunately when you start googling about this drive you may be quite distressed about your purchase, as i have been :( Problems lay ahead with this drive due to inadequate cooling.....
Jun 12, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Start up problems
I have little knowledge about the FreeAgent, but the beeps to me suggest power problems...
kat4 - Sound sliek your freeagent is working fine, and that it's the hub that's your problem. If it's a lower end brand you might consider getting a better one.
copper-top - Have you tried pluggin in the drive directly into a USB port built into your computer, and not through a usb hub, or other device?
CannonBooks - I have the same question for you as copper-top, but for you I suggest trying this drive without the printer plugged in, and see if it once again works. If it does, you might consider getting a good-quality powered USB hub and using that, or try pluggin the two devices into seperate hubs (if you are using hubs currently), or one/both directly into your computer.
Feb 06, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Computers & Internet Logo
85 people viewed this question
David Payne
David Payne
