Question about Dryers
Fitting a dryer belt
How do i fit a new belt cant find where to get in to the motor
  • ricky mack May 11, 2010
    the top of the dryer has to come up . the front of the the dryer must be removed .then you can see the drum and motor
  • 156 Answers
Depends on dryer but remove are lift the top up remove front panel slide new belt over drum with rib part belt toward drumaround motor and pulley
Posted on Feb 28, 2008
How do I replace a belt on a tricity bendix TM221W tumble dryer - a video of this would help. thanks.
no video
unplug it
you have to take the top and back panel off
take photos of how the belt is fitted before removal
see what holds the belt on or stops it from coming off
undo what is required and fit the new belt
then reverse all the take apart steps till it is fitted
Tricity Bendix TM221W 91609308601 Tumble Dryer Functional parts Spare...
Dec 26, 2014 | Tricity Bendix Dryers
How to fit belt on Creda Reversair 37643 Tumble dryer
New belt is very tight, so you have to use more strength. Put it on motor and all other on "drum". Spin it easily and slowly but with strength until its done.
Be carefully, use gloves.
Apr 13, 2013 | Indesit Hotpoint Creda Tumble Dryer Belt...
Normally you loosen the bolts to the motor after fitting the belt around the drum. DON'T try to streach the belt to fit over the motor pullery.
Dec 19, 2011 | Dryers
How do I fit the new belt
You give no information on your machine, but normally you need to obtain access to the complete circumference of the drum to fit the belt. Depending on your machine you can either remove the front of the dryer, or release the rear bearing support so that you can slide the new belt over the drum. The belt then just slips over the motor pulley and you need to check on the belt tension, usually done by adjusting the motor.
Feb 26, 2011 | Dryers
Simpson Maxidry Tumble dryer (Cloths dryer) How
Hi there, There is a switch at the bottom of the dryer. It has a groove for the spring to fit around. Then the spring goes through the metal tag with the holes in the pulley. The pulleys 2 prongs then fits into the slot near the motor. The belt goes through the pulley and around the motor wheel. When fitting the drum, tape the belt at three points on the drum with the machine door facing down making installation easier. Once installed remove the tape. The dryer now works like a dream. See the attached photo. Good Luck!8e72e75.jpg
Jun 21, 2010 | Dryers
Is60v belt replacement. The replacement belt seems difficult to fit.size/ belt number checked against old one & details are the same. What is the method of replacing / refitting the belt?
The belts do appear to be undersize, this is because they are a stretch belt, and this makes them very difficult to fit.
Remove the top cover and right hand side panel of dryer, this will give you access to the belt.
Move the front panel forward to fit the new belt on the drum, and then you really have to pull hard down on the belt to get it round the motor pulley.
It is very difficult.
Good luck.
Jan 16, 2010 | Dryers
Fit new drive belt to tumble dryer
I need to know more. like how to instal belt or how to find what belt fits your dryer . need more info like mod # there 5 different belts for hotpoint . and several different ways to install them so model # ______________ needed . **** . pls .
Jan 02, 2010 | Dryers
I need to fit a new belt to a Creda Tumble Dryer
There should be some kind of tensioner around the motor or one of the pully's. The other problem could be that the belt you bought is the wrong one for your model. If you still have the old belt, measure the new belt against the old one and the new belt should be slightly smaller. I hope this info helps.
Nov 29, 2008 | Dryers
Cant get new drive belt to fit washing machine. right one but cant get it to stretch enough to fit from drum wheel to motor
this is a common problem as nowadays stretchy belts are used in order to avoid motor adjustment.
fitting requires some brute force. the way i do it is to put the belt on the motor pulley then start it as much as i can on the drum pulley. turn the drum pulley keeping force sideways to push the belt on and as you turn, the belt will go on
Oct 21, 2008 | Hoover Washing Machines
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
246 people viewed this question
Top Dryers Experts
