Deep Fryers
Problem for Deep Fryers
Generic problem for all Deep Fryers
Rival Deep Fryer
By dan71 on Feb 27, 2008
In 12/07 I purchased a Rival Deep Fryer CZF725, I've used it once and now I can't get it to heat. I've checked the outlet, I reset the fryer and still nothing
Same Problem
Mar 31, 2009
-   used about 4 times now it will not heat up, red light does not go on
-   barbara-stre
Dec 09, 2008
-   I also have this same issue where it worked great for the first 3-4 times of usage and now it will not heat. Bummer-seems like a defective item.-   princesshovr
May 22, 2008
-   seem to have everything place and lined up but green power light wont go on.cord seems very loose but is plugged in . Is there some type of on off switch?-   hungrynow
Apr 27, 2008
-   There is supposed to be reset switch on the back of the control panel, but I can't find it-   Guest
Apr 13, 2008
-   I just purchased this same fryer and am having a problem with shutting the lid. It doesn't appear to be damaged in any way, but I have to slam the lid sometimes several times to get it to stay closed, and it seems especially hard to keep closed when I try to shut it during frying. I'm really bummed because other than that I love it. It fries like a dream and is so easy to clean! Has anyone else had this problem?-   haleighsnana
Best Solution
posted on Apr 14, 2008
Helpful)
thch91
Rank: Apprentice
Rating: 85%, 1 votes
about the Lid, make sure that you have the control panel firmly in the two grooves and the lid will stay shut. If it isn't in the right grooves, the lid will not shut. My husband had to point that out to me when I was having the same problem.
Was this helpful?
Yes
No
Solution #2
posted on Apr 10, 2008
Not Rated)
Mom of Twins
Rank: Apprentice
Rating: 0%, 0 votes
I received the same fryer in December as a gift, and never had any problem with it until the removable oild reservoir was dropped. Do you want to sell yours?
Was this helpful?
Yes
No
Solution #3
posted on Feb 28, 2008
Not Rated)
dan71
Rank: Apprentice
Rating: 0%, 0 votes
used the correct cord. have a Fry Daddy and the plugs a very similar but are not interchangeable. Thank you for the responce
dan71
Was this helpful?
Yes
No
Popular Solutions for Deep Fryers
Questions and Unsolved Problems for Deep Fryers
Answer
Can't turn the pilot knob? Any advise?
Answer
when you turn it on the light does not show and the reset button does not work
Answer
How do I change from C to F? How do I change themp.?
Answer
unit is plugged in and reset has not tripped, but i get no power
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Deep Fryers Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
