Question about HP OfficeJet 6110 All-In-One InkJet Printer
How to control/suppress transmission(fax) report in HP office jet 6110
  • Anonymous Mar 27, 2009
    Cannot set up fax machine to ring an automaticly answer faxes
  • 181 Answers
I assume that the fax report is printing on every fax and you don't wish to see it?
In your setup menu if you go to advanced fax setup and then the first option will be automatic reports setup. Hit the okay button and then you can choose when the report will print out. In your case you would scroll to the last option which is 'off'. The reports should no longer print. If you did want to see when there was an error you can set it to error only there as well.
Posted on Feb 28, 2008
Image on fax send report is set to off. Will not send fax
1> Press the wrench/tool mark (SETUP) button on the printer.
2> Go to 'Print Report'
3> Go to 'Image On Fax Send Report' and use the arrow key on the front panel to change it to ON and select/press OK tio save.
Jul 15, 2010 | HP J4680 Office Jet All-In-One Printer
HP6110 All in one
When the HP Office jet series all-in-one front panel screen displays Memory Full, the HP Office jet all-in-one is not able to send, receive or forward faxes. Copying will also not work. WORKAROUND: Though the memory buffer should clear itself automatically after proceeding with the next task, like receiving a fax or starting a copy job, these suggestions below may help you clearing the memory buffer by:
  • Add paper to the HP Officejet series paper tray
  • Clear a possible print jam and proceed printing the fax.
  • Reduce the copying or faxing resolution via the front panel's menu.
  • Use the HP Manager to send a (group) fax or making a copy. More memory is available this way, as the HP Manager utilizes the PC memory. When sending a group fax, the HP Officejet all-in-one's memory is filled to capacity. To copy in color is only possible from the HP Officejet Manager.
  • Press START to clear the message. If this message persists, unplug the power cord, and after at least 15 seconds plug the power cord in.
CAUSE: The HP Officejet series memory may be full due to: Copying on Photo quality or sending a group dial, which will use an extensive part of the internal memory's capacity. No paper in the paper supply tray, while receiving a fax. This may result that the data remains in the buffer. Print jam while receiving a fax or copying. The data is still stored in the buffer. System error displayed on the HP Officejet display window. SUMMARY: The HP Officejet series will not fax or copy without sufficient memory to store the data of the page in the buffer before printing the receiving fax or the copy.
May 22, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How do I fix an "error 442" on the fax part of my hp 6110 all-in-one
Per HP:
Definition
An error occurred during transmission after one or more partial pages were sent. The sending machine was unable to restart the control channel connection(handshake) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page. It can also be caused if the receiving fax is using a fax format incompatible with the HP fax (usually during color faxing).
Solution
Try the fax at a different time when telephone line conditions have improved.
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Where is the ink cartridge located on the HP office jet 6110 prin
if you are to lift the top part of your printer you will see the cartridges inside as shown below:
Lifting the scanner bed exposes the entire paper path and gives your hands plenty of space to replace ink or clear paper jams.
Apr 11, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Fax set up
You can download this for free directly from HP with no hassles or signups required:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=79477&lang=en&
Mar 18, 2009 | HP OfficeJet 6110 All-In-One InkJet...
My hp office jet 6110 all in one will not allow my hp pavilion dv 5000 to initiate a scan from the "director". I have reinstalled the drivers that came with the printer several times and of course...
Hi greggcowley, having two HP's connected or bouncing between either you need to change the default printer before using either. Open printer and faxes. You'll see only one device has a check mark on it. So before you go to use the 6110 left click on it once, than click File & set to default printer. Same for the DV 5000. Each time you'll need to open printer & faxes & change the default printer/scanner.
Enjoy greggcowley!
Thank you for using fixya.
Merry Xmass!
Mike
Dec 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner failure, while booting up, blocks all other functions.
no you can not disable your scanner
you ust have to repair your scanner
if you have any warranty then go for it
or visit any technical person who can check cables and scanning tube of your scanner
Nov 17, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Printer error
error message 345
The remote machine has failed to respond to a fax command from the local machine due to the connection being interrupted. These errors can occur if the phone lines in the area to be faxed are old or there is noise (static on the phone line). Other reasons can include power outages and other power related problems.
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Under rare conditions incompatibility between the two machines may cause the remote machine to simply abandon the call.
*Re-attempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
*Disable ECM. Errors may still occur, and may result in a degraded image quality on the received page. However, the ability to transmit the entire document will be improved.
*Try sending at a lower transmission speed.
Dec 05, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP 6110 not able to send or receive fax
I tried to find information on replacing the modem to no avail. Unfortunately most products of this nature do not allow for replacing the individual components.
However I did find the following info on HP's site for troubleshooting problems with faxing. http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpu02151&cc=us&lc=en&dlc=en&product=79477&dlc=en&lang=en#Not_working Hope this helps!
Nov 29, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
121 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
