Press the "Auto Clean" or "Precise Clean" button depending on the control type of your range. Then press start. The oven should lock and start the self-cleaning cycle. The cycle is usually 3 hours from start to finish and cannot be stopped once it has started heating. The range gets extremely hot and causes the inside of the oven to act like a catalyst to burn the grease. It will create smoke and odor depending on how dirty the inside of the oven is. Make sure to leave the exhaust fan on above the range to remove some of the heat. And definently do not do the cleaning cycle on a hot summer day!
SOURCE: Self cleaning MAytag Gemini GAS oven
A wonderful feature is that the ovens self-clean with the press of a few buttons. Only one oven can be programmed to self-clean at a time. Remove the oven racks. Turn off the oven light and close the door. Press the "Clean" button and then press "Auto Set" to automatically clean the oven for 3 hours. Press the "Auto Set" pad again to set the oven for a 4-hour clean cycle, or press the button one more time for a 2-hour cleaning. The oven locks when in cleaning mode. When the oven is finished cleaning, the word "Cleaned" will be displayed on the control panel, and the oven will remain locked until the oven has cooled, which takes about an hour. To cancel the self-clean cycle, just press the "Cancel" button. Simple!
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
SOURCE: maytag gemini self cleaning oven feature
Close door on lower oven (upper oven is not self clean). Press "Clean" pad. Press More pad or Less Pad. H is 4 hour clean, M is a 3 hour clean cycle and L is a 2 hour clean cycle. The door will lock and cleaning will begin. Good Luck!
SOURCE: whirlpool accubake oven will not heat after self clean cycle
I had the exact same thing...thermostat..
SOURCE: Whirlpool Accubake self cleaning oven problems
My Whirlpool Accubake oven just did the same thing. There may be a class action suit... contact Emge
Before you go working too hard to get
you oven to go into the self clean mode(self destruct)....check out
this tip...
Self
Cleaning Oven Problem
heatman101
Wish I had read this first. I never would have used the self cleaning
option. Thanks for the info!!
