Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Indesit d41 LS 08-BIT100 EMPTIED WATER ON FLOOR 1ST LIGHT FLASHING SOUNDS TO BE WORKING
  • Anonymous Mar 10, 2008
    water leaking on floor
  • 159 Answers
SOURCE: Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Posted on Aug 06, 2007
  • 209 Answers
SOURCE: indesit d41 dishwasher
try testing the door interlock, actually this is only a micro switch inside the door behind the plastic front panel, there could also be the possibility there is a broken wire behind the door skin just above the hinge part, take care when working on appliances do not force parts to remove them and always unplug at the mains hope i have helped, if so please rate me well
Posted on Sep 26, 2007
SOURCE: Indesit D41 lights 1 & 2 flashing
1, Tilt machine and remove base plate 6 screws.
2, fixed to the inner ring at the bottom of the machine is the water level control.
(brown, round with 3/4 wires attached.
3, remove it, lift and pull forward.
4, remove the attcahed clear plastic tube.
5, tip up and drain out any water in the unit, Should be none.
6, Blow throught the free hanging rubber tube, should be clear
refit.
Posted on Dec 22, 2008
SOURCE: Ist GREEN LIGHT FLASHES BUT WONT FILL WITH WATER
I also had this problem, it was the automatic anti-flood device, the upper spray arm water pie was leaking into base off unit which operated the anti-flood device.
Hope this is of some use to you and others
ipip32
Posted on Oct 03, 2009
  • 2501 Answers
SOURCE: D41 Model. Switch on, small beep, pump starts,
Check that the water is turned on. There may be a fitting with a screw driver slot in it. This slot shows the direct of the hole that lets the water through and therefore it should be lined up with the pipe direction.
If it isn't turn it through 90 degrees.
Posted on Feb 18, 2010
ipip32
Jul 20, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
D41 slimline dishwasher not filling
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 13, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
First two lights of four are flashing
when my ones lights flashed (lights 2 and 4) I thought it was def broken, i then discovered it was a knife in the top tray stopping the shower from spinning. worth a try- make sure its empty when you test it.
Feb 14, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit idl 40 2&3 lights flash
The problem is lack of water. Check that the water is turned on at the stop **** and make sure that the hose hasn't been traped if the dishwasher has been pulled out from it resess as happened to mine.
Jan 21, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
refit.
Dec 21, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
First flashing light.
I've just had this issue and managed to get it working again.
The problem is more than likely water sat in the bottom of the machine. Unload and unplug your machine. Tip it backwards by about 45 degrees, and you should notice about 1/2 pint of water leaking out of the back on to the floor (make sure you have some old towels handy).
After doing this my machine started to work again.
Nov 02, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit IDL40 Slim line
Pull the machine out and tip it carefully to one side, if water comes out from the base then the problem is the union on the upper feed pipe. Remove the top inner dish rack and twist the star shaped nut clockwise gently! Make sure you have got as much of the water out as possible, stand the unit back up and turn put it into cycle.
Apr 12, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher indesit DI62
green light 2 flashing sounds like machines doing something switched of at mains & back on to same flashing green light
Mar 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit dishwasher.
It sounds like the anti flood switch is activated, lean the dishwasher back at a 45 degree angle. If water comes out the back you have a leak. Stand it up and try it try dishwasher, if it works this comfirms leak, you will need to find where it is coming from.
Dec 03, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher
hello mate, i bought a brand new indesit d40. plumbed it in and the 1st light kept flashing, phoned the technical centre and they said its the anti flood mechanism kicking in and preventing it from working. although water was going in it was not going into the dishwasher but filling the base and the safety feature just shut it off. said to get back in touch with comet who i bought it off for a new one because its a manufacturing problem. put the new one in and theres no problem. wouldn't have a clue how to fix it myself though.
Apr 06, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
111 people viewed this question
Top Indesit Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Eric Taylor
Marvin
Marvin
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
