Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My rca tv wont turn on the light turns on and off three times
  • BIG PIG Mar 01, 2008
    switch light flaches 3 times as if it is trying too come on.There was only twice it came on. Wonce it turn on and warm up, you can turn it off and on with no problems. After it is off and gets cold, the problem starts over again. What do I need too replace?
  • billieh Mar 01, 2008
    I have the same TV and the exact same problem. I turned the TV completely off last night (usually just shut down the cable) and now it won't come on. It blinks 3 times and then nothing. At this moment, I have unplugged everything and am waiting to try to plug it in again.
    Genius:
  • 1,030 Answers
Rca d52w20 is a ict222 chasis i see this set all the time at the shop. The first thing to try on these set is to unplug them for 30 mins ( i dont think i ever have seen this work) What you need to know about these set is that the processor shuts this set down for any safety issues. it can be for many as 20 different issues. the processor stores this in a log which a technician with special computer interface can read. It will not be a main fuse because you can get the flashing light witch means the processor is getting power. So this is where the troubleshooting begins... these set are about 800 new. on average about 300 to 400 to repair. Notice any sounds or smells. What was it doing when the set died. did it ever run these will help whoever you get to work on it.
Posted on Feb 28, 2008
  • 3 Answers
What seems to be the most likely of the possible problems? when I hold down the power button for a few seconds, I get a blink code of "9 blinks, then a pause , then 1 blink". It repeats this a few times, then goes blank again.
Has anyone actually fixed this problem yet. Also, is there a way to bypass the safety checks??
Posted on Mar 04, 2008
5 Suggested Answers
  • 1030 Answers
SOURCE: RCA Projection TV won't turn on
Ok you got you a Rca ITC222 I See ALOT of these things. To start the troubleshooting.. UNPLUG the set for a min of 30 min the plug back up. ( I have never seen this work) If the set stil fails to come on then you have a processor lockup. The first thing you can conclude if the light flashes is it is NOT a FUSE. THe sets processor has determined that a safety condition has occured and shuts it down to prevent further damage and fire. THe top cause of this include Horizontal output trasistor, flyback transformer and high voltage splitter. but There is about 25 different failures that can drive it into shut down. technicains have interface equipment that can read errors codes much like a car.
typical repairs on this set run 150 to 350... if you have to replace tubes...250 per tube +labor which runs 250 ... these set new cost 800 so unless under warrenty.. you got to determine if it is worth it.
Posted on May 12, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA 65 inch HDTV TV
yes what your describing is possibly a flyback which is very inexspensive and easy to fix. But I will need the model number of your RCA to be positive and tell you which flyback you need. So please respond to this same post with the model number and I will provide the proper info so you can repair the set without alot of exspense.
Posted on Jul 04, 2008
SOURCE: 52 inch rca rear projection tv wont turn on
I have the same problem. I had someone come look at it and he showed me the problem but a terrible price, so i didnt have it fixed. The reason the light blinks is there is a problem and the safety mech is kicked in which shuts the TV off. If you take the back of the TV off, about 15 screws, you will see right in the front on the left side a part shaped like the letter "C". The number on top of mine is S5 19 2. That is the part that needs to be replaced. Now to find the part on the internet and figure out how to change it out. any suggestions?
Posted on Nov 05, 2008
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
Power button on my rca tv wont turn on sometimes
A number of possible reasons for this---failing part in set or even bad connections on main board in the set----model listed is prone to going dead with high pitched squeel etc.
Oct 31, 2012 | RCA TruFlat 27F520T 27" TV
I turned on my tv this morning and the power light is flashing and tv wont turn on
if the power indicator flashes three times then goes out and stays out then its usually the power caps which are CP150, CP120 and CP114 capacitors. You can get the RCA repair kit by that same name from www.tvrepairworld.com which has the capacitors and the repair instructions on CD
Aug 08, 2011 | RCA R52WH76 Television
Tv wont turn on just the green light comes on 3 times
Ur tv DM power supply board have dead leakages capacitors.U have tools,solders and soldering iron?U know how to do soldering.Tries websites like Tvrepairworld.com,Tvrepairkits.com buy a capacitors kit to replaced dead leakage capacitors to the DM power supply board.
Jul 05, 2010 | RCA P61940 61" Rear Projection Television
Have a hard time turning on my TV, have a RCA big
there are caps in the smps board that require replacment cp 150 cp 120 cp114 and check solder connections at clo32
Oct 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
1995 rca 52 inch tv...
Please post the model number of your RCA as usually its a bad flyback and start up capacitor when you get a 3 blink error code . But I can help you better if I have the model number of your set.
Oct 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on
Thats the classic sign that your flyback need sreplacing, very easy repair . You need flyback number 259296 you can get a replacement with free step by step instructions on how to replace it yourself at the following link.
http://servicemanuals.vstore.ca/
Aug 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv wont turn on
my tv wont turn on and i dont have no sound or no picture it flask on and off
Feb 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca model d52w19
blinking light indcate a processor shutdown.. the processor has detected a problem in safety circuits and shut down the set. common problem are flyback and horizotal ouptut transistor. the processor has a error log file. technicians can plug a specail computer and read those to determine problem
Oct 28, 2007 | RCA D52W19 52" Rear Projection Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
537 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
