SanDisk Sansa e250 MP3 Player
Problem for SanDisk Sansa e250 MP3 Player
Sansa e250 wont turn on, help
By INEEDHELP313 on Feb 27, 2008
my sansa e250 will not turn on the screen stays black and the blue bar is responding when i spin it (lights up.) I can turn it on and it off so it does not light up and it lights up when I hit the power button to turn it on but not off
HELP
Comments:
Mar 06, 2008
- That did not work.
I need help
Clarification Request
Posted by bugutl on May 17, 2009
Solution link . . .
http://www.Sansae250MP3Player.com
Same Problem
Mar 23, 2008
-   My Sansa e250 was working perfectly, I turned it off, and tried to turn it again but it won't turn on. I tried plugging it into the charger and it won't charge.-   Zaq Z
Mar 07, 2008
-   Well, since my last posting...I have figured out that my solution was very temporary. I was able to get my Sansa working for exactly 2 (yes two!) start-ups and shutdowns, then back to the same problem. I have done the same procedure 4 times...each time with the same result. (I believe that the term for this is "insane"). I purchased mine as a REFURB from Buy.com. Actually, I bought one for each of my two kids. One works fine, the other is a waste of time. How many hours can I waste looking to fix a $30 piece of junk. By the way, switching out batteries didn't work.-   imhorto
Feb 28, 2008
-   Yes even i have got the same problem.Please HELP if anybody knows the solution-   Guest
Feb 28, 2008
-   Hey, if it makes you feel any better...that is my exact problem too.-   imhorto
Best Solution
posted on Mar 24, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hey if u r mp3 player doesn't go on,then press the power botton for 20-30 sec. and if that doesn't also works then connect it on u r computer and press it for 30 sec. I had that problem many times and it works.
Solution #2
posted on Aug 14, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
This product is a pice of **** - I bought this today and have the same issue - Just trash it, and hope god saves the sandisk.
Solution #3
posted on Feb 28, 2008
Somewhat Helpful)
imhorto
Rank: Apprentice
Rating: 70%, 3 votes
I found the solution to our problem!! and it is very easy. Take the 4 screws off the back. Remove the battery. Press the on/off switch and all the others on the front. Replace the battery and the screws.
Mine needed to be plugged in again, but the computer could read the Sansa and I can see the screen again. Now it is charging and I think that the problem is fixed.
Comments:
Mar 07, 2008
- Well, my thought was, clear out any "stuck" electricity. In the past I have taken batteries out of electronic items that were not responding correctly, pressed the on/off switch and presto...problem solved. The first time I tried this on the Sansa it seemed to work, but as earlier posted, this was just a temporary solution. Maybe reinstall Sansa software and then redo this procedure? More time wasted...
Was this helpful?
Yes
No
Solution #4
posted on Mar 07, 2008
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Could you elaborate please? Do I press all buttons at once or one at a time and for how long?
Solution #5
posted on May 17, 2009
Not Rated)
brncas
Rank: Master
Rating: 75%, 4 votes
Try this link . . . http://www.sansa.com/e250MP3player
To find your best solution.
14
Was this helpful?
Yes
No
Popular Solutions for SanDisk Sansa e250 MP3 Player
Questions and Unsolved Problems for SanDisk Sansa e250 MP3 Player
Do you recommend SanDisk Sansa e250 MP3 Player?
Answer
Answer
installation software of sansa 250 v2
Answer
I've lost my charger for my sansa sandisk mp3 player. It's an e250 model. Can I buy another one?
Answer
I unplug it from the computer and the refresh database only partialy loads how do I get it to fully... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and Digital... Experts
Top Audio & Video Equipment Repairmen
in , OH
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
