Hello, when ever i try to connect my anything using bluetooth on my satellite M40/M45 series i get a pop screen that said bluetooth is not ready. but i work on my laptop everyday using wi-fi
  • 55 Answers
You might need to check a driver for your bluetooth. Also Bluetooth and a WiFi are two different technologies, they are using different adapters.
Regards,
Posted on Feb 27, 2008
Realtek pcie
Reset? Can you clarify the question? Do you mean format?
May 26, 2013 | Toshiba Satellite M40 Series Satellite...
I have a toshiba l755d, how do you use the bluetooth
is your laptop Bluetooth ready or is it Bluetooth enabled?
To find out if it is Bluetooth ready go to control panel and see if you can see a Bluetooth icon anywhere if you have then just click the Bluetooth icon and it will take you through a setup wizard to connect to your phone or any Bluetooth device.
If it's not there then your laptop is most likely Bluetooth ready which means it can support Bluetooth, so you will have to buy a Bluetooth adapter which are fairly cheap.
hope this helps.
Jul 16, 2011 | Toshiba Satellite L500 Series Notebook
My toshiba lost its audio device
Click Here to download the latest version or sound drivers for toshiba satellite M45-S265.
Please let me know if you have any further questions or concerns.
Thanks.
May 05, 2010 | Toshiba Satellite M45-S265 Notebook
I accidentally erased my dvd driver for my toshiba satellite m40/m45 series laptop, and I cannot even use my recovery disc to reinstall it, because I cannot use my DVD player to use my recovery disc.
Option 1: Download the DVD drive from the Toshiba website for free and install it.
Option 2: If you could manage to a get a external DVD drive that can be connected by the USB and use your recovery disk to get a clean install.
The first option would help to fix the problem withouth going for a clean install. But in case you are going for Option 2, then I would recommend you to take necessary backup of all your data.
Mar 07, 2010 | Toshiba Satellite M45-S351 Notebook
Toshiba laptop power cable won't charge battery
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
Specifications:
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Apr 22, 2009 | Toshiba Satellite M35X-S149 Notebook
Laptop keep sticking/jumping
sounds like its not able to process everything make sure you dont have a virus taking up your memory
Feb 11, 2009 | Toshiba Satellite M45-S165 Notebook
Toshiba sattelite m40 motherboard?
This is a whole different motherboard not only does everything else have to match it and work properly with the motherboard but its very complicated to open a laptop. As not only will it might not fit but it will be very hard to do so. Sorry. Hope I Helped!
Jan 28, 2009 | Computers & Internet
Cd/dvd problem on toshiba m45-S165 laptop
Is you new hard drive lager than you old on and was the disk drive a factory replacement cause with those disks if you even change just that they will not work
Dec 09, 2008 | Toshiba Satellite A45-S250 Notebook
Toshiba Satellite M45-S351 BIOS password needs help!
BIOS passwords on Toshiba notebooks have to be reset by an authorized service technician who has the CD available to run the utility.  Their notebooks don't contain a battery reset to erase the password.  It was done as a safety feature to prevent theft from happening and it is a very good one.
If you take it into Best Buy or a computer dealer to get it done, you might have to prove that you are the new owner of the computer before it can happen.
Sep 23, 2008 | Toshiba Satellite M45-S351 Notebook
Pop up onto screen
well check first of all your startup program see if your are able to remove it from there ,oderwise type msconfig in start menu>>run box and check if that popup or program is listed there also check your screen saver settings !!i hope this works
Jan 31, 2008 | Intervideo WinDVD 5 for PC
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
