Question about Frigidaire Refrigerators
Frigidaire M -FRS6LR5EW3 S/N 4863814836. Unit only gets 50degree in the freezer side. Ice accumlates in area of DFT about the size of a small fist. The compressor was cycling on and off, changed relay, compressor working, still not cooling. changed control board, still not cooling. Seems as if refrigerant is low or compressor has bad valves. Need help.
  • Frigidaire Master
  • 4,302 Answers
It hardly matters what the electronics or thermostat is doing - if the compressor is running, if it is in good order and properly gassed one connecting pipe rapidly becomes warm and the other cool.
The idea of refrigeration is circulating gas/liquid to move heat out of the cabinet and disperse it to atmosphere and the heat removed from the cabinet causes the condenser to become quite warm. Feeling the inside of the cabinet and wondering if it is cooling can be confusing. Feeling the heat from the condenser is a much more reliable guide to the efficiency and correct operation of a fridge.
Posted on Oct 02, 2017
  • Vernon Taylor Oct 02, 2017
    I meant to say, if the condenser is quite warm but the inside of the cabinet isn't particularly cold, it is possible the auto defrost heater is operating continuously.
  • 410 Answers
SOURCE: Kenmore Elite refrigerator stops cooling - Relay keeps cycling
the relay on the compressor is most likely the culprit part# 8201786 you can buy it at the local sears parts and repair center it is very easy to replace it. your refrig compartment will start warming up soon. to prevent damage to your compressor probably a good idea to unplug the refrig until you get the part replaced..
Posted on Dec 18, 2007
  • 410 Answers
SOURCE: Kenmore Elite stops cooling - Relay keeps cycling
tech master
  • 120 Answers
SOURCE: frigidaire frs26zrf
Posted on Nov 10, 2008
  • 462 Answers
SOURCE: Problems with Frigidaire Refrigerator not cooling
In turning it off you may have only closed the air damper. Set it to 1/2 way.
If ice or frost in the air damper area on refrigerator side you may not be defrosting the freezer coil.
Inspect from bottom looking up with a mirror and flashlight. You should have no Ice buildup frost that is even and white is normal. Feel Check the back wall mid way down to 1/4 way to bottom. Push on the wall slightly. Crunching like frost or snow behind wall is not normal. I suspect non defrosting here.
Next eliminate the inside fan motor. It has to run to push air all over the freezer and refrigerator. If this fan doesn't run the results will be only the area with the refrigeration evaporator coil will cool and it may get too cold and resemble a non defrosting situation where the air is not able to circulate because of frost build up.
Next eliminate the Ice maker and light as a source of heat. Unscrew and unplug them
Next eliminate the door gaskets from not sealing. A piece of paper set tween the door and frame and pulled across it and you feel resistance all the way and the gaskets are smooth and not warped they are OK
Next inspect the condenser fan and coil by the compressor underneath. A dirty coil here will cause diminished heat removal and possible for a partial cooling of some of the freezer.
Only after inspecting all these items and determining they are OK should you proceed with refrigerant checking. Also a person with out the ability to measure the actual amount of refrigerant being put in should be shown the door. Even with topping off (adding some) refrigerant I use a scale to determine that I do not put in too much. So if you have a friend that does this and no way to tell how much is too much.... well with all due respect your getting what you pay for.
If this helps you understand your problem and need more information please post back, I will follow up. If it helped you determine your trouble please rate me as high as you can. Thank You for using fixya and good luck.
Posted on Mar 22, 2009
  • 22 Answers
SOURCE: frigidaire refrigerator compressor buzzes but won't start.
The compressor is seized it needs to be replaced log on to and find a local service provider if you purchased prior to the end of 06 and if less than 5 years old it has warranty coverage on sealed system repairs. check your manual to be sure. you can try what it is called a hard start might work for a while it uses a larger capacitor to give a bigger kick upon start up.
Posted on Apr 06, 2009
Frigidaire commercial upright freezer
Empty everything into a few boxes, cover them with lots of blankets. If the unit is in an area that has a drain in the floor, then just hose it down with warm water. If it is a moveable unit, hand truck it out side and do the water thing out there.
When your done, reload the unit and from now on, do not leave the door open so much, ice will build up much slower. I generally do mine every 3-4 years. I also keep a few one gallon jugs full of water near the freezer and when I take something about the same size out, I replace it with the number of gallon jugs needed to fill that vacancy.
What all that does it, it reduces the amount of MOIST AIR that can rush into the unit when it is opened, and the ice will accumulate much much slower, plus a side benefit is, if you have a power outage, your have a freezer full of product and frozen water. Great for parties. If you do have that power outage, cover the freezer with a ton of blankets and it will stay as hard as a rock for several days. DO NOT OPEN THE DOOR EXCEPT IN A EMERGENCY. PRESERVE YOUR SEALED AIR CHAMBER YOU HAVE CREATED INSIDE OF YOUR REFER/FREEZER.
Jan 10, 2014 | Freezers
Unthawing the water dispenser in the freezer door
If the icemaker is loaded with ice or certain areas of the freezer are perhaps overloaded redirecting cold air toward the water output it can freeze. Also if the ICE shoot has ice cubes obscuring it's closure that area gets cold enough to freeze the water. Check after dispensing ice that the round flap is closed.
I open the freezer door and place three regular sized bed pillows placed into white trash bags into the opening being sure to DEPRESS the light latch with one of the pillow placements so it won't constantly sound a door ajar warning.
I then close the door as much as the pillows will allow and place a chair in front to keep the pillows in place for about 25 minutes. Usually this will do it and the water will begin to flow . I draw off enough to run it completely through the entire line . Sometimes a small piece of ice will come out. I had tried hair dryers and all manner of things and just gave this a shot one day and it works when it freezes for whatever reason it will use.
on Apr 26, 2015 | Frigidaire Gallery GHSC39ETJB 22.6 Cu. Ft....
Frigidaire side by side refrigerator and freezer not working
Hi on most cases if your freezer or fridge stop working correctly at some point by not cooling or freezing right. It my be backed up by ice in your unit. which will prevent your fridge from venting or draining on to the pan. I think the condensor or little look alike radiator will be frozen up. Most cases the drain area will be back up with ice preventing your freezer from working properly. Need to remove items from freezer and try to fix it by adding warm water to the drain area or call a profesional for help
Dec 04, 2013 | Frigidaire Refrigerators
Frigidaire refrigerator/freezer side by side--compressor keeps running
Most problems with side by sides frosting up is due to failure of the defrost heater in the bottom of the freezer section behind the panel inside.
Jun 16, 2012 | Refrigerators
Our freezer in not getting cold it is at 27 degrees. We unpluged it and left it off for about 5min as suggested by Sears Appliences man. It got a little cooler but did not get down to freezing. We then...
Check the evaporator at the rear of the freezer - if it covered with a blob of ice, the auto defrost mechanism is bogus - if so it could either be the heating element or the defrost timer.
Jun 20, 2017 | Frigidaire Professional Side By Side...
Ice forms in bottom of freezer on frigidaire
dependant on appliance you may have a small drain hose at the base of the appliance that drains the defrosted water away at regular intervals. Sometimes this blocks and the water that should drain away just starts to freeze over.
Mar 19, 2010 | Frigidaire Freezers
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
Aug 04, 2009 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a frigidaire FRS26ZPH side by side that leaks water about twice a day on the floor by the doors. Where are the drains located so I can see if they are blocked?
What is happening is that there is a drain at the back and bottom of the inside of the freezer area and that drain is clogged with ice (freezer set too cold?) from inside the freezer or dust (you do actually vacuume out those coils once a year right?) from the back of the frigidaire. To fix this issue...
(Total work time about 30 minutes. 60 minutes counting explaining what you are doing to your friend or significant other :)
1.  Unplug the frigidaire so you don't zap yourself.
2. take everything out of the freezer, remove the shelfs and un screw the maintenance access panel at the back of the freezer area.
3. You should see a drain area at the bottom of the coils, using a straw or something semi-flexible, snake out that drain from inside the freezer to see if the clog releases. If there is a lot of ice and you cannot even get to the clog, be patient and gently remove the ice - DO NOT DAMAGE the coils!
4. Remove the back access panel to the frigidaire. Viewed from the back, you are looking for the fat black hose coming from above and behind the right side the fan (this is why you unplugged remember?) into the drain tray under the fan. Gently lift up on the hose so it flexes up and toward you so you can snake the hose from this other end too.
*Hint: If you are REALLY nice to your friend or signifigant other, they will gladly pour another dixi cup of water in the drain from inside the freezer so you can see for yourself that the drain is now clear.
5. Now the drain is clear and all your ice cream is melting in your sink. Be sure to reposition that black hose back to where it was in the drain tray so it does not get chopped up by that fan at a later date. Next... reverse your removal of the back maintenance access panel on back of the frigidaire. Re-install the maintenance access panel on the inside of the freezer area. (Now is a good time to use a clean & warm washcloth to gently clean the inside of your freezer.) Reinstall all the shelfs. Place your ice cream and all other items back into the freezer.
*If you have an ice maker, be sure to dump all that half melted ice now - it will just refreeze into an iceberg later and break your ice machine so no cubes come out.
6. Plug the frigidaire back in. Tomorrow, check the bottom of the freezer for another sheet of ice accumulation, meaning something else is leaking inside of your freezer. (Could be your ice maker)
Jun 20, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Frigidaire leaking
the drain in the freezer compartment is frozen up you can remove all items from lower freezer and remove access panel on back of freezer compartment pick the ice out of the drain hole with a small screwdriver DO NOT USE SCREWDRIVER AROUND THE ALUMINUM COILS! once all ice is gone that you can see use hairdryer to blow into hole on medium heat. once it looks like it is gone take a small 1/4 plastic tubing and push down the hole to try to clear obstructions then run hot water down hole. if it still doesnt drain take rear access panel off of compressor area (back of refrig) look for drain hose and remove clamp take off and clean u might try this first. but you will have to remove ice from drain.
May 27, 2009 | Frigidaire 26.0 cu. ft. Side-By-Side...
Freezer not keeping ice cream cold
One thing you can do is clean out the area under the ice box where the condenser coils are located. Make sure the fan motor is blowing under there. Clean the kickplate. Get the air restrictions out of the fins and that may bring the freezer temp back up to par.
Nov 23, 2008 | Frigidaire FRS23KF7AB Side by Side...
Refrigerators Logo
176 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
