Question about Toshiba Satellite 1410-S173 Notebook
Toshiba 1410. Won't turn on
I have a Toshiba 1410 that won't turn on. No noise, no screen light. On mains power the "mains" led is green, but the battery is yellow. Yellow flashes briefly when "on" button is pressed. When battery is removed, still wont go. Should it?
I thought that perhaps the battery needs to be in, and if this is faulty then it may drag the power supply voltage down as well?
Any thoughts?
Thanks
Ron
  • 6 more comments
  • 2trp Feb 28, 2008
    Many thanks lenny297. Your comments are appreciated. I will try them both. 2TRP
  • shrlives Mar 14, 2008
    hi i have a laptop toshiba 1410...i connected a ethernet to the laptop...
    i heard a swish and now the laptop won't turn on...only a yellow blinking light..
    it was working perfect before...
  • Anonymous May 13, 2008
    won't turn on power light blinks battery light on but nothing happens
  • Venus47 May 14, 2008
    Hi My laptop Has the Green On light on when pressed but no other lights ,but when you pug power in you get power lihgt and power on light and battery light on but orange leave it on to charge makes no difference it won't start up the computor
  • gormz May 31, 2008
    hey, iv got a toshiba 1410 laptop and the it wont turn on properly, the "on" light turns on when i press the button but only a light click from the dvd drive and a flash on the "disk light" at the front and it just sits there, no fan, screen stays off, media buttons at the front wont work. and it dosent matter how the power is connected, it always does the same thing. battery(same thing) no battery /w power(same thing) battery and power same thing happens. however i have noticed that when i plug a network cable in the lights on the socket at the back turn on as normal. i have already taken the computer apart so that i could analysie everything, searching both sides of the motherboard for faults but still couldent find anything. Is it possible that this is a bios issue?
  • DigitalDHill Jun 15, 2008
    Similar problem here. When AC power adapter plugged in, I get green AC power light, and yellow battery light which flashes yellow at first, then comes on steady yellow for about a minute, then turns green (assume the battery is taking a charge and "topping off"). Computer does not turn on at all - pressing the power button causes nothing to happen. I did notice that wiggling the AC power adapter plug on the back of the computer caused the AC light to flicker - perhaps bad connection there, including connection to motherboard. Haven't taken it apart yet - was cruising around looking for ideas before going in. Appreciate any input anyone may have. It's an older notebook that was given to me to see if I could fix it. Because of its limited RAM capacity and processor speed I don't want to throw a lot of money at it, when you can get a pretty decent notebook for under $500 these days.
  • jordansson Oct 08, 2008
    i have the exact same problem. Mine started the day my cousin spilled his beer into it. I was told the mother board was blown due to the liquid but immediately when the beer was spilled i grabbed the comp. and turned it upside down to drain. I took my comp. apart expecting to find bad things but Dont think the liquid even went past the keys. Dont know what to do now, Dont want to spent the money for a new motherboard if thats not the problem. Someone please help!
  • 133 Answers
Sounds like a dead battery, You need to try it with an alternative battery, most laptops won't aeven switch of if the battery is damaged, also try ro pull out the motherboard and find for dry joints. i.e. any lose transistor or capacito and try to re-solder it, the put the laptop back together,
Posted on Feb 28, 2008
My toshiba 50L2200u won’t turn on
Excepting the obvious (you have power from plug CHECKED / you'd be surprised)
MANUALLY try power button / to be sure remote isn't faulty.
There should be some kind of indicator led that set has power.
IF NO lights/ indicator good chance the Power Supply has suffered .. maybe replacing
IF lights but still wont start
Likely the "main" board is bad. (other boards or panel can also be an issue)
I’m happy to help further over the phone at https://www.6ya.com/expert/mike_316638c836088218
Mar 30, 2018 | Toshiba Televison & Video
What is causing my LCD tv to turn off on my Toshiba 52hl167 tv.
. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Dec 13, 2016 | Toshiba Televison & Video
When i turn on my Dell Inspiron 2400 Desktop Computer why won`t it start.
Is the computer plugged in to a known good power source with a known good power cord? Also, make sure the power is fully seated on both ends. When you press the power button are you getting any indicator lights? The power button itself has an LED that will be either solid green, blinking green, solid amber, blinking amber, or off. Do you hear any beeps?
May 19, 2014 | Dell Inspiron 530s Desktop Computer...
Toshiba TV won't turn on
Toshiba? Suspect that if it uses a Lamp for brightness (a model number would help) it may have failed----customer replaceable and if remove look to see it is not shattered inside--2 year, 2000 hour life is normal.
Oct 29, 2012 | Sony Televison & Video
RC-3910 Toshiba television won't turn on, has flashing standby light?
Missing power supply rails from the main power regulator board to sub boards is the fault. Contact any experienced service technician to get this set repaired, since the work is skilled one.
Jul 11, 2012 | Toshiba Televison & Video
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
Notebook won't turn on
my nb500 netbook wont turn on i slamed it shut now wont turn on
Apr 23, 2012 | Toshiba NB500-12X
Won't Turn on, not even when connected to mains - LED lights on but no HDD drive light
The HDD can go at anytime without warning, does the Asus logo come up on the screen?
Apr 08, 2012 | ASUS Eee PC 1000HE Netbook
I have a toshiba laptop satellite L-300 that won't turn on. I tried unplugging AC and remove the battery and hold the power button for 30 sec. and plugged the AC back, i can see the green light at the...
THE BATTERY LIFE TIMED OUT.TRY IT ON NEW BATTERY FOR TURNING ON THE SYSTEM.THE CHARGING ADAPTER MAY BR ALSO A PROBLEM TRY TO CHECK IT AC VOLTAGE LEVELS .
Sep 03, 2011 | Computers & Internet
HDMI/ DVI inputs failed approx. one month after connection of Denon home theater receiver with HDMI pass-through feature "on." Gear successfully re-connected via component video...
hi welcome to fixya
i want to clarify first the problem sir so as of now the problem with your tv won't power on then you are using again the old main board is that right ? when you use the new replacement main board the tv is functioning will the only problem is that the HDMI / DVI inputs doesn't work. and now you encountered power supply problem like won't start up or something that cut the supply in which the stand by indicator is turn off so as my idea it has a problem with the old board. but before you come up with the board making sure all the connectors coming from the power supply is properly connected to the main board as will as flexible and lvds cable for the T-con board is properly inserted.just let me know if is that what you are asking for so i can give you additional solution thanks for consulting the fixya.
Aug 30, 2011 | Televison & Video
Toshiba Satellite 1410-S173 Notebook Logo
284 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
