Question about Microsoft Xbox 360 Console
Turns on error 68 comes up - Microsoft Xbox 360 Console
  • Anonymous Jan 22, 2009
    when the harddrive is added thats when the e 68 comes up
    Genius:
  • 1,019 Answers
Error 68 Is A Voltage Error. This can be caused by several Things. If you,ve recently Added any extra devices To the 360 ( Such as An External Fan et,c ) remove them and try to re-start.
Also if its a Premium, ( with Hard-Drive ) remove The Hard-Drive And see if this causing The Problem.
Mike @ compurepair.
Posted on Feb 27, 2008
Hp lj2420 errcode 68.2
The printer permanent storage is
full. Some settings might have
been reset to the factory defaults.
1. Press the SELECT ( ) button
to continue.
2. For 68 errors, turn the
printer off, and then turn the
printer on again.
3. If a 68 error persists,
initialize NVRAM. See the
caution and note in To
initialize NVRAM.
4. If this error message persists,
replace the formatter (see
Formatter).
Apr 04, 2011 | HP LaserJet 2420 Printer
We have an error 68
Error 68 usually means that there is a hard drive failure.
  1. Try taking off the hard drive and starting the xbox.
  2. If the gray screen still comes up then it's a hardware failure in the xbox.
  3. You have 2 options, send it into microsoft or buy a new hard drive.
Feb 19, 2011 | Microsoft Xbox 360 Console
I have one printer lj 2420 68.0 permanant storage full error
Error 68 is simm memory problem.
68 Error / Service / Cold Reset
All printers
  1. Temporary error. Cycle power to printer
  2. Bad formatter PCB
LJ4, 4+, 4P
  1. NVRAM not initialized.
68 Memory
IIISi, 4Si, 4V
  1. Bad SIMM memory. Check and replace SIMM's
Feb 05, 2011 | HP LaserJet 2420n Printer
System error e 68
E 68 is a hard drive error, try removing the hard drive and turning the system on. If that works, turn off your system and reconnect the hard drive, then turn it back on, if it still works YAY!! If not, you may need a new hard drive....
Nov 21, 2010 | Video Game Consoles & Games
When i turn on the kenwood radiocar, hf error 68 appears. What does it mean? What should i do?
Error 68 means it is trying to connect to a bluetooth enabled cell phone. You Need to turn off the blue tooth pairing options in your radio options. Just go through the menu and you will find it.
Sep 21, 2010 | Car Audio & Video
Error 68 came on my xbox after 3 attempts it started working will error 68 come up again?
The hard-drive in your Xbox may have some bad sectors. What were you doing when you received the error?
Apr 04, 2010 | Microsoft Xbox 360 Console
Error e 68 pops up and dryer turns off. Doe sthis
Hi
Thanks for using FixYa. E 68 error means that there is a leakage of current to the ground on heater or fuse opened. Also check the resistance of the NTC which should be around 50K ohms. If not then you need to replace the water inlet valve assembly.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2009 | Frigidaire Dryers
I get error code e-68
there's a possible hard drive issue on this.
try the ff:
-turn off your xbox
-remove your hdd from the xbox
-turn on the xbox while the hdd is removed
-if you're still getting the sme error code, your xbox needs to be repaired/replaced
-=hope that your xbox is still under warranty=- ^^
Jan 19, 2009 | Microsoft Xbox 360 Console
System error 1 light code E 68
error 68 means that the xbox has insufficient power to operate. make sure it is directly plugged into the wall. try removing accessories on your xbox like intercoolers and USB devices.
Aug 24, 2008 | Microsoft Xbox 360 Console
Error 68 message
Your hard drive is broken. For more information, go here.
Jan 06, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
123 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
