Question about Refrigerators
G.E. Profile Model# TPX24SPZCBS stopped making ice.
  • Nidop Feb 27, 2008
    How do I know if the solenoid is the problem? Also the flow from the water dispenser is slow.
    Could it be a filter problem causing weak water pressure?
    Master:
  • 555 Answers
Schematics and parts for your refrigerator can be found here:
GE TPX24SPZCBS
As you can see, replacing the actual ice maker part (ID#820, IM CRESCENT, $107) requires a lot of disassembly.
You may want to hire a local refrigerator technician to do the job, although that is a more expensive route.
Posted on Feb 27, 2008
  • Matt Jurach
    Matt Jurach Feb 27, 2008
    Check the water intake line for clogs (ID#269 TUBE WATER FILL I/M). If water is reaching the dispenser, we would assume that it is also reaching the ice freezer. Can you check to see if this is the case?
    If there is actually ice in the ice freezer, then it is instead a dispensing problem.
    Scholar:
  • 110 Answers
Check the overflow trigger that hangs over the bucket. If that's working correctly, check the water intake line for clogging, which can happen fairly easily because the line is small. You should be able to shut the line off where it connects to your water supply to test it.
GE Profile Refrig model PSC23SGRC ice maker stopped making ice. Water is ok, just stopped? Is this common? Its only 4 yrs old
Your model has an electronic ice maker part number Click Here=> WR30X10093 When the electronic ice maker fails you usually need to replace the complete ice maker. You can test the ice maker by filling the tray with tap water. If the water freezes aand then drops the ice then the water control on the back of your refrigerator is the reason. The water control valve is Click Here=> WR57X10032 Either way let me know your results, Thank You, Sea Breeze
Jan 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker not working
The solenoid on the back is not working or the ice maker is not calling for water.(check the solenoid first)
Jan 15, 2009 | GE Refrigerators
GE profile refrigerator model # TBX25PR
See if ice is jammed up in the tunnel the ice is pushed through.
Will the motor turn the auger with all the ice removed.
Jan 25, 2008 | Refrigerators
Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
Apr 29, 2007 | GE Profile PSS26NGS Side by Side...
Refrigerators Logo
66 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
