Question about Car Audio & Video
Renault clio 2003 1500cc expression dci 65
Ive run out of diesel in this car and after filling a container with £6 of diesel and putting it in the tank, I cant get the car started. will it need bleeding or do I just need to put more diesel in it
  • 2,039 Answers
Normally you fill the fuel filter with diesel its should start maybe you gonna have to do it a few time
thanks for using fixya
pierre
Posted on Feb 28, 2008
  • kikisahota Aug 29, 2011
    where is the fuel filter located
Hi, I started my Renault Meganne 1.5 dci diesel 2009 up this morning an turned the headlights on.
Check the relay box. If its like the clio the fumes from the battery corrode the fuse/relay box.
Oct 24, 2016 | Renault Megane Cars & Trucks
How do I replace rear bumper?
Un do the nuts & bolts remove the old one replace it with the new one and do up the nuts & bolts
Sep 12, 2012 | Renault Clio Cars & Trucks
How much gearbox oil do i need for renault clio 1.5 dci
gearbox oil capacity for a renault clio 1.5 dci 2002
Jun 02, 2012 | Cars & Trucks
My Renault Kangoo injector pump gave up and I had to get a new one fitted. Now a mechanic friend has told me that no matter how well I wash out the tank, the fiings will go through the system and wreck...
Well my friend from my Experience with Renault kangoo all i can say is they all have that problem with that injection pump and If i were you I would go to a junkyard and get one from a wrecked car because it will cost you lot of $$$$ to get that pump. and if you get a pump just put it in i dont think that would matter because it will fail when it suppose to just like your old one. Good luck
Dec 12, 2010 | 2007 Renault R18
I cannot locate screenwash bottle on clio dci 2003
bottle is at the back of the engine bay to the right as you look at it.
Feb 01, 2009 | 2003 Renault 181
Not starting.
Try asking the dealership if the TDC sensor needs replacing. The other issue is a loose wire connection on the solenoid....
Dec 23, 2008 | 2001 Renault Sportwagon
Starting problems
get the crank sensor (TDC sensor) replaced. It is a very common problem on Renaults. Join us on Renault Forums. Cheers
Nov 14, 2008 | 2001 Renault Sportwagon
Renault clio clutch adjust
If the problem is just a clutch cable (clio 55 plate should be cable, not hidraulic), you can adjust or replace the clutch cable quit easily.
If the problem concerns instead the clutch disk, then you will need to put a car up on a bridge, empty the oil and fluid, and remove the clutch that is attached on the engine, on the right lower side.
This is usually not a job for home repair.
Nov 14, 2008 | 2005 Renault 181
Renault megane 1.5dci injection fault
i have a 1.5 dci 2005 renault megane and it will not start it was running fine then injection fault came up on dash bored ive changed the injectors and the fuel filter what,
what could be the problem
Sep 25, 2008 | 2005 Renault 181
Car Audio & Video Logo
243 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
