Question about Stanton C.304
Deck Resetting The problem happens during playback. After a period of playback time the deck will rapidly reset its self, any settings I had adjusted like removing the pitch lock and setting pitch to 8 will go back to the settings they were on when I first turned the unit on. Playback stops and the decks are useless. At first all was fine but after a while one started to go wrong then the other one did the same.
  • 1 more comment
  • esalsa Dec 05, 2008
    Please would someone URGENTLY post a solution to this frustrating problem, thank you... DJ esalsa
    Would someone please URGENTLY post a solution to this frustrating problem being experienced by Dazzafox, myself and a few other DJs?
    Thank you very much,
    DJ esalsa
  • DjPuca Apr 07, 2009
    I also have a problem with my decks resetting, they were fine at first but after a wile one side started resetting itself, it only seems to happen when they are being used for a wile, perhaps a heating problem???
    anyone know how to fix this???
I was correct in thinking that an over heating problem was causing my deck to reset.
I installed a fan in the deck and it solved the problem, it hasnt reset itself since and it has been used for hours on end.
I used a fan out of a desktop computer, these can be purchased in any computer shop, a relatively small one will do, i dont think the position is overly important(as long as it circulates the air inside the deck and through the vents)
I installed a seperate transformer to run the fan because i didn't want to overload any components of the original deck, this was the tricky part so u will need somebody that knows what they are doing.
Posted on May 18, 2009
  • 3 Answers
I KNOW THE SOLUTION EMAIL ME AT DJWOLFUK@HOTMAIL.CO.UK
Posted on Apr 25, 2008
How do you dub cassette to cassette
Hi
If you have a dual cassette deck, then one deck will only play cassettes,whilst the other will have a record facility as well.
Basically you need to place the original cassette in the play only deck and the target cassette in the record/play deck.
Start the playback in the play only deck and immediately press the record and play buttons together on the record deck. Some decks have high speed dubbing but this varies so much that you will need to consult your manual for this.
Cheers
Apr 09, 2015 | Audio Players & Recorders
Mower deck adjustment
you may have bent brackets in the front. These are the pieces that straddle front and back of the front axle beam. This happens when you hit things sticking up or on the side with the deck.
You also could have bent deck link bars (where you make height adjustment on the front).
Aug 12, 2014 | Craftsman Garden
Sony disc player just hissing not plalying
Hello, i just found one of these decks yesterday with the same problem. The deck loads a disc correctly, but cannot read the TOC (doesnt display the title or track number)
The hissing sound is actually the sound of the laser lens vibrating in a unfocussed manner
The solution: 1.Use a minidisc lens cleaner if available.2.If not, eject the minidisc and open the deck. Take a good look at the laser lens. Is it dusty or seems hazed over (cigarette fumes)? (Mine was)
If yes, clean the laser lens directly with a cotton swab to which you add a drop of isopropylene (100% alcohol) or (2nd best choice) window cleaner.
Take care to not bend of break the recording head (the white and copper arm just above the lens)
use a dry cotton swab to pick up any remaning humidity on the lens.
3. Try again to read a disc. any success? No? try, if available, a pre-recorded disc
any sucess then? Chances are it might work with a pre-recorded disc because of the better reflectivity of these discs.
No luck yet? Doest it read some discs, others not? well, it's time to re-adjust the deck. The service manual is available here: http://www.minidisc.org/manuals/sony/service/sony_MDS-JE520_service_manual.pdf for free. BTW the site www.Minidisc.org is an exellent source of all information available about minidisc.
First let the deck tell you what the problem is! Page 2 explains how to enter the self-diagnosis mode. Enter the Error DP (display) mode. Look at the error history. Most probably you will find the code E06 (as i did) which means Focus error.
The service manual explains how to enter Adjust mode.
Keep an eye on the C1 error 7350= doesnt read correctly 0-50=adjustment ok.
Do C(ontinous)-play checking: 5-6-5 MO error rate check (Page 38)
Perform focus bias adjust (page 41) (5-12) This is a manual adjustment Keep an eye on the C1 error 7350= doesnt read correctly 0-50=adjustment ok.
Keep in mind that you have to adust the setting "A" with the AMS button to obtain C1=220, and "B" turning the AMS button downwards (anti-clockwise) to obtain C1=220 the deck calculates automaticaly the adjustment "C".
Perform autogain control level output adjustment for MO discs
(page 42) (5-15-2)
If this doesn't work, reset the deck to initial settings / Initial setting of adustment settings (page 39).
Perform focus bias adjust (page 41) again (the deck displays the adress and C-1 and ADER errors)
Check if the adjustment is ok with C-play checking 5-6-5
(page 42) again (5-15-2)
MO-disc= recordable MD
Hopefully you can re-adjust your deck. You don't need any extra tools for this, the deck displays the error rate. In C-play mode, a pre-recorded disc shows nearly always 0 C-1 errors, a recorded disc should not show more than 50 C-1 errors and no ADER errrors.
Of course this is at your own risk. I can only say that i needed about 1 hour to find the setting which worked with different recorded discs.
There is also the Continuous recording mode to check that the error rater during recording stay within tolerance. If you use this mode bear in mind that the disc will be (partially) erased regardless if fully or partially recorded. In test mode there is no safeguard against accidentaly erasing, so use a new disc or one with a recording you don't care to loose.
Simply unplug the deck to exit the service mode.
Check if you can record after adjusting the focus. Check if you can enter a title to the disc. Is the title there when you eject and reload the disc? If yes, you succeded!
Hope this helps!
P.S. Yes, i once was working for Sony as a repair techncian...
Sep 23, 2011 | Sony MDS-JE520 Mini Disc Player
2010 Craftsman Lt 2000 deck height adjustment?
just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Jul 31, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Akai gx-625 reel to reel tape deck has no sound
This could be a head fault? Another possibilty is the preamp stage. You will need to look for something that would take out both channels. Such as an IC.
Aug 26, 2009 | Audio Players & Recorders
My deck DEH-P840MP will reset it self once in
because u r a **** a lick to much cocl sorry buy new radio ******
Jul 14, 2009 | Pioneer DEH-P840MP CD Player
Putting a new playback head into an audio cassette deck.
Hi PATRICK
What happened when you used the head demagnetiser tape? Did chew out the head? If you can give me the model of the deck I can make some enquiries to help you sort it out.
regards
robotek
Jun 22, 2008 | Audio Players & Recorders
The dvr is not interacting with my tv
:: Remote Control Overview
1 POWER Press to power the DVD+VCR on or off.
2 TRK+/- While a tape is playing, press to manually adjust tracking
(i.e., to remove white lines from the screen).
3 0-9 Use to select channels and set menu items.
4 SKIP/F.ADV Press to skip ahead in one-minute increments, up to 5
minutes, during VCR playback. Press to advance one frame at a time in
Pause mode.
5 SHUTTLE <</>> Press the 4 and 6 buttons to scan forward and
backward at variable speeds.
6 MODE/REPEAT Press to set the Play Mode to Random or Programmed
Play. Also press to set the Repeat Mode to Title, Chapter/
Track, or A/B Repeat (DVD only).
7 ZOOM Press to zoom in at 2 or 4 times normal magnification (DVD
only).
8 100+/3D SOUND Press to select cable channels 100 and above.
Also press to activate the 3D Sound feature, which creates the illusion of
surround sound with only two speakers (DVD only).
9 DVD Press to set the remote control to operate the DVD deck.
10 MUTE Press to turn audio on or off.
11 VOL +/- Press to adjust the volume.
12 STOP J Press to stop playback.
13 REW AA In DVD mode, press to skip to the previous track. In VCR
mode, press to rewind the tape. Press and hold to scan backward during
playback.
14 REC F Press once to start recording in the VCR deck. Press repeatedly
to add recording time in 30-minute increments.
15 ARROW KEYS Y/B/A/" Press to navigate in the menu system, see
page 15.
16 SETUP/ENTER Press to display the DVD+VCR menu system and
confirm menu settings.
17 SP/SLP/TITLE Press to set the VCR record speed to SP (Standard
Play) or SLP (Super Long Play). SLP is three times longer than SP. Also
press to display DVD title menus (for discs with multiple titles only)
May 29, 2008 | GoVideo DVR4300 DVD Player/VCR
Stanton C.304 Logo
290 people viewed this question
Top Stanton Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Stanton Audio Player and Recorder Expert? Answer questions, earn points and help others
