Question about Panasonic Lumix DMC-LZ2 Digital Camera
Memory stick it says that the memory stick has been locked
Easy.
Remove the memory stick from your camera and examine closely. There is a tiny switch on one edge, see picture, switch is ringed.. Push the switch into the UP position. This will unlock the card.
Posted on Mar 22, 2008
How to remove write protection from sony memory stick pro duo
There should be a small plastic catch on the side of the card which allows you to write protect the memory stick pro duo. It should have an image of a lock or say locked next to it, if it is locked you won't be able to write to it. Slide it to the unlocked position using a fingernail or a paperclip.
Apr 29, 2015 | Sony Electronics - Others
How do I add 8 GB RAM to MY 1 GB RAM Gateway 834GM system?
Sorry but your system will only upgrade to 2 gig of RAM
http://panam.gateway.com/s/PC/R/5293/5293sp3.shtml
but where your current memory is installed there are two locking levers on each socket one on top one on bottom press on those to release the memory and remove the current memory stick, now when installing the new memory make sure the little notch on the memory stick lines up with the one on the memory socket when your sure its correct just firmly press the new memory stick into the socket the two llever locks should lock automatically if not you can do it manually, take care not to put to much pressure on the memory stick. hope this helps
Oct 04, 2014 | Gateway Computers & Internet
Why do I see MEMORY STICK ERROR on my Sony camcorder?
Check the memory stick for a little slide lock on the side. Make sure that is not in the locked position. This feature is there to prevent people from recording over special memories, like weddings. But sometimes during handling (or just not knowing) people accidentally switch it to "lock"
Good luck
Oct 03, 2012 | Sony Handycam DCR-TRV350 Digital Camcorder
My sony cybershot 3.2pixel camera tells me that the memory stick is locked What can I do to fix it.
The lock switch is located on the bottom of the Memory Stick, next to the connectors (see picture below). Move the switch to the other end of the arrow to unlock the Memory Stick.
Sep 16, 2011 | Sony Cyber-Shot DSC-P72 Digital Camera
I am using window 7 enterprise my computer can recognize the sony memory stick pro duo adapter with 1 GB card but cannot open it neither can format it. please tell me any solution.
check the small lock switch on the adapter usually located on the edge of the adapter. check and see if in lock or open position. if its in lock position toggle the switch to open position and you should be able to read as well as write date to and fro from the sony memory stick pro duo adapter. good luck
Sep 08, 2011 | Sony 2GB Memory Stick PRO Duo Memory Card
I cant format my microsd because of write sector error
hi
make sure your card reader is not locked. Most card readers have facilities to lock a memory stick. If left in that position, they write protect the memory stick. Meaning you can neither transfer to it nor change and sometimes remove stuffs from the memory stick. Insert the memory stick into another card reader and try formating again or check the memory card itself if the write protect feature is part of its structure. Usually there's a hint of that in form of tiny diagrams and signs of how to lock and unlock the memory stick. hope this helps
Jul 04, 2011 | Computers & Internet
The memory stick cant even be reformatted or opened by the computer neither can the psp
If this is the case, and you appear to be savvy, then it is possible that the memory stick has failed. Also, check to see if there is a lock button on the stick. A lot of times, the memory stick will have a lock button on it.
If no lock button and no recognition, then Luke, the chip is bad.
Jan 23, 2011 | Video Game Consoles & Games
My memory stick does not have a lock or unlock position.
Do not use the computer to erase a memory stick. If your pics are safely on the computer and you want to completely erase the stick, use the format function in the camera.
Apr 25, 2010 | Sony Cyber-Shot DSC-P92 Digital Camera
Panasonic Lumix DMC-LZ2 Digital Camera Logo
29 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
