Can you see a spark from the piezo starter? Also you have to hold the start valve until the temp gets up. Also make sure that the spark is jumping across the gas orifice. You can get parts at www.reddyheater.com They also have tips on how to troubleshoot you're unit. Let me know if you need more help.
hardrocko
Thanks for using FixYa
SOURCE: Reddy Heater Doesn't fully ignite
First thing I would do is clean all of your air and fuel filters and check your lines for breaks. A lot of times they will do that if your not getting enough air to fuel mix. If it continues after that it's the CAD/ flame sensor which you can get from MR. Heater for 3 bucks they are all basically the same and I know reddy heater wants 18 for the same thing.
SOURCE: Reddy Heater 50'000 BTU - Puffs Smoke and Leaks Out The End
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
heatman101
heater...
Reddy
Torpedo
heatman101
heater...
Reddy
Torpedo
heatman101
heatman101
