Question about RCA HD61LPW165 61" Projection HDTV
RCA HD61LPW165 Ballast
I just replaced the color wheel and worked great for a week and now the Ballast has a diode that is buzzing and glowing is the diode bad or is this normal for this ballast??
  • Tazman62 Feb 27, 2008
    it just started doing this after i changed the color wheel a week ago and yes it does it on start up and then it runs about 1 to 2 minutes then buzzing and glow and shuts down then it will rest then front panel lights will flash and start all over again. so you think maybe i didn't pit i back together right after i replace the color wheel??
  • Tazman62 Feb 29, 2008
    Thanks, i think it is the Ballast because even with no lamp hooked to it. It will still buzz so i am shipping it out to be fixed i could not find the ceramic cap or diode anywhere. TSM www.tristatemodule.com they are great they rebuild my color wheel when no one had one in stock .
    Scholar:
  • 133 Answers
This is normal . It is telling me it is trying to turn on the lamp. But are you having a problem with the set now or is this something you've just noticed. If your set is not working check the the lamp or make sure it is seated correctly.
Posted on Feb 27, 2008
  • Louis faenzi Feb 28, 2008
    Is your lamp OK ? If it is your ballast may be bad . But it is only a guess . When you turn it on do you hear that whisp type sound like the color wheel is spining ? No i really didn't think you didn't put it back together correctly as you said it worked great for a week . I mean't the lamp sometimes is not properly seated in its housing correctly . Now if you don't hear that whisp sound as if the wheel is not spinning then you might to check the wheel again. I know this is not fun to work on let alone getting into the light engine assembly . Let me know
I have a hd61lpw165 big screen tv that makes a loud buzzing sound as soon a it goes on with no picture.
sounds like the lamp or ballast, check the lamp first to see if good, then if good, then probably the ballast is bad, but I think the sound or buzzing is coming from the ballast, so it's should be good.
Mar 04, 2011 | RCA Scenium HDLP61W151 61 in. HD-Ready...
How do I remove the color wheel for an RCA HD61LPW165? Needing to send it in to get it rebuilt.
if you are talking about the light engine, your best bet is to have a tech do it.  if you are really talking about the color wheel, in my experience they are replaced not repaired ..
Jul 29, 2010 | RCA HD61LPW165 61" Projection HDTV
Instructions on How to change an RCA Color Wheel
You can get help at;
http://servicemanuals.vstore.ca/
They will charge for manuals but they also give on-line tech support free!
Apr 06, 2009 | RCA HD61LPW165 61" Projection HDTV
Want to know if color wheel can be repaired?
Unfortunately, you can't replace just the bearing. You would have to replace the complete color wheel. Here's a link for a major parts distributor so you can get an idea on priceing:
RCA HD44LPW62 Replacement Part Color Wheel
Jan 23, 2009 | RCA HD61LPW165 61" Projection HDTV
Does any one make a replacement color wheel for my rca #hd50lpw62ayx2 projection tv? And if so, replacement procedure to replace. Thanks
You can find a replacement color wheel for a model # HD50LPW62AYX2 at this following link:
RCA HD50LPW62AYX2 Replacement Part Color Wheel
I'm not sure about how to correctly replace the part. Hopefully a tech whose dealt with this model will post an installation guide.
Dec 15, 2008 | RCA HD61LPW165 61" Projection HDTV
RCA HD50LPW62AYX2 50" - color wheel replacement procedure
REMOVE ALL SCREWS AROUND SCREEN AND REMOVE SCREEN. REMOVE 2 SCREWS HOLDING PLASTIC PIECE IN MIDDLE. GENTLY SLIDE OFF CIRCUIT BOARD (JUST GLUED FROM THE BACK). REMOVE PLASTIC PIECE TO EXPOSE OPTICAL CHASSIS. REMOVE THE LAST REMAINING SCREW FOR LIGHT FIXTURE. REMOVE 3 SCREWS HOLDNIN COLOR WHEEL. REMOVE RIBBON PLUGS AND REERSE THE PROCESS TO INSTALL. JERRY.(ROCKMANJV@COX.NET. LET ME KNOW HOW HAT GOES. i'M WAITING ON THE PART RIGHT NOW. WHERE DID YOU FIND YOUR PART? THEY ALL TELL ME THE PART IS ON BACKORDER. SEE YA!
Oct 23, 2008 | RCA HD61LPW165 61" Projection HDTV
How to replace the color wheel on a RCA DLP
RCA DLP color wheel replacment is most efficiently done from the behind the screen, not the back panels where the guts of the DLP are located.
From there you do not need to remove anything but the color wheel and disconnect the two wires.
If you want to see pictures, email me and I can send you pictures. email: graphguy@gmail.com
Jan 18, 2008 | RCA HD61LPW165 61" Projection HDTV
Loud buzzing sound
Hello Jack,
That buzzing might be two things. It could be the color wheel or the ballast for the bulb. To check this you will have to move the projection section of the TV out of the case and listen for the sound in the area of the color wheel and the ballast. Try removing the color wheel power to see if the buzzing stops if it does then it's the color wheel is not and the ballast is buzzing then It's the ballast, and it will need replacing or if you know electronics you could try fixing the old ballast (I would suggest getting a new ballast).
Better still if you are uncomfortable working on the set you could get a qualified TV repair person to repair your TV .
I hope this helps,
Thank you,
Shuttle83
Jan 07, 2008 | Televison & Video
RCA HD61LPW165 61" Projection HDTV Logo
234 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
