Question about Alba DVD-108 DVD Player
Remote I have an ALBA DVVD70 dvd player and lately the remote control has stopped working The functionsdo not work on it, almost every button comes up as a number on screen when it is pressed, bar a few that turn the volume down or freeze the picture. Any functions that it does do(as listed) are on completely the wrong keys and dont happen on the right keys. Any ideas??
  • wolftoneire Nov 28, 2008
    my remote just does not worl at all!! i have changed the batterys any idea? many thanks alan
  • 185 Answers
The most likely cause is the remote itself.
To give them a soft feel, the contacts inside the remote are conductive rubber pressed on a printed contact on a small circuit board.
There are three possible problems:
1) The conductive rubber have become high resistant and has simply worn out, in which case the remote is best placed in your trash can, unless you want to paint each contact with silver conductive paint.
2) The contacts are tarnished or dirty. If you can carefully open the unit and clean everthing thoroughly you may get more life from it
3) It has become contaminated by liquid.
Babies love chewing em, as do dogs. Tea, coffee and beer always look for remotes to spill on too. If you think something like this may have happened, again you may be able to open it and clean everything.
Failing that, consider buying a one for all remote as a replacement. These can be programmed for specific equipment with a code.
Posted on Feb 27, 2008
Hi. We have an alba tv at work. To control it we have a total control universal remote. When playing dvds the alternate camera angle icon appears on screen and we can't work out how to get rid of it.
Since Alternate Angle is a DVD function, you probably need to turn it off somewhere in the blu-Ray/DVD player.
You may need to use the blu-Ray's remote, since all the buttons may not have been included in the Total Control remote.
Mike
May 31, 2016 | Universal Televison & Video
Hi can anyone tell me the region free code for a alba CDVD2251N dvd player
Switch on the DVD Player and go to next step
Press Setup button on remote to show the Setup menu
Next key in code 1389, a different menu should show
Scroll down to where it says Region 2 and change this by keying in 0
Press Setup button again on the remote to exit Setup menu
That's it, you should now be able to watch any DVD
Jun 21, 2015 | Alba Televison & Video
Alba code help
hey...Ben eye just hit ebay & there are alot of alba remotes w/codes/manuals
Feb 18, 2014 | Philips Televison & Video
Alba dvd manual
Manufacturers often stick to the same remote frequencies, so give it a try. The old remote may work again, if you carefully clean the battery contacts. The reason it's not working now is probably because the batteries are not making food electrical contact.
Jan 07, 2014 | Televison & Video
I need to get a new remote control for my alba dvd player. model DS-5711.
you can try contacting the manufacture of the remote control and model and order one online or you can take your old one if it is still repairable and get it fixed at a tv or a electrical outlet but you will be able to get one online if you have a problem locating then try google or ebay and if that dont work you can often get a multi function remote control from many electrical outlets and reprogram the new one to set up with your dvd player some supermarkets even sell these multi function remote controls
Jul 06, 2011 | Alba Televison & Video
Phillips Portable DVD Player DCP750/37 says "Wrong Region"
To change the region on the Philips dcp750
1. Press the Open button on your remote control to open the drive tray
2. Press the Setup button on your remote control
3. Press the Right button on your remote control
4. Press the Right button on your remote control
5. Press the Right button on your remote control
6. Press the 9 button on your remote control
7. Press the 6 button on your remote control
8. Press the 5 button on your remote control
9. Press the 3 button on your remote control
10. Using the Up and Down buttons on your remote control, change the region to 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
11. Press the Setup button on your remote control
Mar 13, 2010 | Philips Televison & Video
Alba tv remote has stopped working
hi had the same problem with alba 42" (l42m1) spoke to customer services at argos who suggested holding down menu button for 10 seconds then pressing menu again, which aparantly resets remote with tv. Has worked for me, hope it works for you.
Feb 20, 2010 | Televison & Video
Alba 3406 tvd
Connect pin 1 & 5 together (momentarily with a small switch), on the remote control handset. with the tv already switched on, This will put the set into the engineering set up mode. You can step between the various options by using the -/-- button. the Mute button invites you to save your changes which I believe is saved when you next press the -/-- button. there are 18 different service pages in all, be very careful not to change things which should be left alone, as this menu controls the way this set operates. The menu button exits the service menu. I believe menu 13 should be the AV-SND options menu, you can select either DK-I-BG or M sound systems. only set one system to "on"at any one time. You may also need to check 14, the C- SYSTEM options Menu. Good Luck, A D.
May 05, 2007 | Alba DVD-513 DVD Player
Alba DVD-108 DVD Player Logo
186 people viewed this question
Top Alba Televison & Video Experts
Demonic-2011
Demonic-2011
Michael Galve
Michael Galve
Are you an Alba Televison and Video Expert? Answer questions, earn points and help others
