Question about Edirol UA-25 External Sound System
Edirol ua-25 not detecting midi but audio works fine
My edirol ua25 has stopped working properly. When i plug into my laptop it doesn't detect it, yet all the lights come on and i can use the audio channels in garageband, however it will not detect any midi ports? when i go to the driver it says, device not connected?
any help
  • 2 more comments
  • Llennett Mar 17, 2008
    I have the same problem, the audio side of things is working fine, I can hear things with my headphones, and I can input audio, but nothing seems to detect the MIDI at all.
  • oilpipe Mar 21, 2008
    I experience the same symptoms.
    It began after a windows system update, and it seems that windows automatically installs a default driver for my edirol ua 25 overriding the original drivers....
  • AMozart Apr 19, 2008
    same problem here. Works good as a soundcard but suddenly the midi stopped working after 6 months. I use Logic and Macbook.
  • Anonymous Jun 13, 2008
    i am having the same exact problem. i guess it's time to buy a different product.
**** THIS IS THE SOLUTION ****
On the back of the UA25 there's a switch called "Advance" - this needs to be set to ON for the device to work as a MIDI interface.
LC (UK).
Posted on Sep 08, 2008
  • negitoro Aug 30, 2011
    Also, be sure when you switch the advance button on that you disconnect the UA 25 from your computer and than plug it back in. If you don't do this it won't work
  • 49 Answers
Well I think that you should go to start, control panel, system, device manager and uninstall the default driver or roll back driver. Restart your computer. When you get into windows wait for everything to load and then plug in your audio device. If you have it plugged in when windows starts then it will install a driver. In automatic updates you can select to notify of updates, but lets you install the ones you want.
Posted on Jun 08, 2008
I was hoping it was only mine
Posted on May 19, 2008
Me too ..sucks
Posted on Apr 18, 2008
Do not get MIDI signal via EDIROL UA25
Midi is data only, there is no actual sound to the midi tracks themselves. They need to be assigned to either a software synth or an external synth to actually make the sounds you want to hear.
For instance if you load a demo of a midi sequance you will need to add a software synth such as the TTS-1 or Roland sound canvas which are general midi compatable and will play the instruments sounds assigned to the demo's midi channels. Use the Synth Rack feature in Sonar to open one of them. Then you will need to assign the output of each of the midi tracks to that particular synth and you will get sound. Make sure to assing the synth's audio track to you UA-25 as its audio output.
I would suggest reading in the manual and following the tutorials included in the manual to get yourself familier with how this is all done. spacer.gif
May 25, 2008 | Edirol UA-25 External Sound System
Crackle/static during audio playback.
hi,
download Realtek high definition sound manager software, this will filter your noise and give u a good result.. all the best..
thanks
ehsanullah. md_ehsan_1@yahoo.co.in
Jun 16, 2009 | Edirol UA-25 External Sound System
Edirol not able to record on Cubase essentials
This interface works fine with other hosts but with cubase is more tricky. But you can fix it.
You need to disable the onboard sound card, also use the UA25 Asio drivers, go to programs/Steinberg cubase/ ASIO multimedia setup and you should see the UA25 outports are active and that the sync ref "YES" also that the UA25 Input ports are active. the next bit is a bit of fun select the Advanced options and select Detect buffer size, when thats finished select Check Buffers and Sync, press the start button and the test will run,if everything is ok you should have zero "Sync lost" and zero "Buffer lost"
Depending on how lower you want to get your latency , you may have to tweek the UA25 driver settings and re-run the setup above.
Jan 25, 2009 | Edirol UA-25 External Sound System
Edirol UA-25 not working on Mac OS X
I had the same problem. When I installed the Edirol software it prompted to 'reboot' and when it restarted all the lights on the Edirol came on.
Why don't you try it like that.
Hook up the Edirol Install the software Reboot
Best of luck Victoria
Nov 19, 2008 | Edirol UA-4FX External Sound System
No midi sound
In sonar go to the options menu and select: Audio -->advance. and from the list select the "Asio" driver, then you'll have a new midi output (synthe sw...) select it to have a sound while playing MIDI files.
Sep 21, 2008 | Edirol UA-25 External Sound System
My Edirol UA-25 suddenly is not working with Nuendo
Hey, if you're in the UK you can ring tech support on 0208 747 5949 - they're really good.
Have you got the advance switch set to ON on the back of the device?
LC (UK)
Jun 10, 2008 | Edirol UA-25 External Sound System
Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Jan 23, 2008 | Edirol UA-25 External Sound System
Cannot record
some driver has been installed by your device...to go back, do you have "system Restore" turned on? if so, try restoring XP to a time before your device
May 27, 2007 | Edirol UA-25 External Sound System
Edirol UA-25 External Sound System Logo
2,455 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
