Question about Grundig Satellit 800 AM/FM/SW Radio
Repairing Grundig Radio receiver Satellit 3400
The amplifier section of my Grundig Radio Receiver Model Satellit 3400 is not working. Checking it I found two Transistors bad and replaced it with BD433 and BD434, However it still needs something etse and I cannot take out the amplifier section. It looks like a screw or clip holds it back in the middle of the right side. I am certain that in the original service manual shows how to take the amplifier section out.. Could you tell me how to release it without breaking the plastic casing? I am in Venezuela about 5000 miles and two borders away from any repair station therefore I have to fix the radio here..
Thank you for your kind help.
Thomas Koppel
YV5TK
email: thkoppel@gmail.com
GRUNDIG SATELLIT ST 1400 SL
Diodo Zener ST601 Volt ?? (SU ALIMENTAZIONE)
HELP Simon
Posted on Mar 09, 2008
Grundig Satellit 800 external antenna configurations
It looks like you have a real scientific project. It sounds fascinating and it seems to go well beyond the mere enjoyment of a simple Short Wave Radio. My suggestion: Put your hypotheses/questions to the test and you will form an informed opinion.
Apr 08, 2013 | Grundig Satellit 800 AM/FM/SW Radio
Satt 800 turns itself off and wont reset. I NEED IT REPAIRED! Am in Alabama
R.L. Drake in Ohio can and does repair the Grundig 800 Millennium receiver.
Contact John Kriner there, and advise him that I sent you.
See info below.
Joe Rotello
Knoxville, TN
John Kriner - Lead Tech. Knows Grundig 800 inside and out
jkriner@rldrake.com
USA
R.L. Drake
230 Industrial Drive
Franklin, Ohio 45005-4496
Phone Numbers:
Office & sales phone: 937-746-4556
Technical support and repair parts phone: 937-746-6990
Aug 21, 2011 | Grundig Satellit 800 AM/FM/SW Radio
Grundig satellit 800 antenna replacement
Assuming its broken outside the unit: most aerials are very similar to fit, serving the exact same function and not worth the cost of locating the exact same one used for your model due to time, and purchase costs.
Find an old transitor radio with similar sized aerial, ie length and diameter to fit your radio. Measure it and the replacement from an old radio you or a friend does not need.
Purchase a small screwdriver to remove and refit aerial to your grundig. Small sets of screwdrivers can be bought cheaply from discount stores, ebay etc.
Jul 13, 2011 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 800 LCD display doesn't work correctly
If the radio uses memory batteries, try changing these with new alkalines. The microprocessor needs this power to drive the display.
Jan 30, 2010 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 700 World Receiver. AM bands are dead.
Ist Local Oscillator (PLL) stops working. It's desiged with bare minimum feedback to keep it's output reasonably clean. Removing (De-soldering) the screening box reduces losses, but it's still marginal. Something in the osc. circuit is temperature sensitive, so squirting it with freezer spray - or putting the set in the 'frig will get it going again. Have one like this, "Repaired" - been going for about 5 years and just quit again! If I get any better luck next time, I'll re-post this!
Aug 15, 2009 | Grundig Audio Players & Recorders
Grundig Satellit 800 display problem
HI,
THAT IS COMMON WITH PLL TUNERS THAT THE SLIGHTESS
TWEAK ON THE TUNING KNOB WOULD MAKE THE DISPLAY MOVE .COMMON ON DIGTAL PLL TUNERS........
Nov 20, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Looking for manual
HI,
DOWNLOAD PDF FILE FOR 800 SATELITT
GO TO GOOGLE ENTER SAT 800 GRUNDIG PDF
YOU WILL GET A MANUAL FREE OF CHARGE....
Nov 13, 2008 | Grundig Satellit 800 AM/FM/SW Radio
I have a Grundig Satellit 500 "Radio Boy"
If you sent it in 3 times, then I would suggest getting a new one if you know for sure that other's work in that area. If other's don't work, then then you have some type of interception between the radio waves and your radio. There is nothing I can do about that, and probably nothing you can do.
Otherwise, you should get a new radio.
Mar 16, 2008 | Grundig Satellit 800 AM/FM/SW Radio
Grundig Satellit 800 AM/FM/SW Radio Logo
1,911 people viewed this question
Top Grundig Audio Players & Recorders Experts
k24674
xxxxxx xxx
Are you a Grundig Audio Player and Recorder Expert? Answer questions, earn points and help others
