Question about Durabrand Portable DVD
Durabrand Dual 7 Dvd Player
I need a 7" screen for the Durabrand Dual 7 Dvd Player. The player works fine and plays dvd that can be watched on the 7" satalite screen. The screen on the player itself is cracked. Could you direct me to a supplier of this screen.
Thank you
davidb254@comcast.net
    Master:
  • 555 Answers
Here is the manufacturer support page for your DVD Player:
Durabrand Products DUAL-7 7" DVD Player
They do not offer replacement screens for purchase, only add-on accessories.
The only option I can see is to buy a dead unit from eBay that still has a working LCD display, like this one:
Durabrand Portable Dvd Player ***Repair/Parts Only!!***
Make sure to match the actual unit model numbers to make sure you are getting a compatible LCD screen display.
Posted on Feb 27, 2008
    President:
  • 1,944 Answers
  • Damen Wong
    Damen Wong Feb 27, 2008
    This seller is selling a unit for parts and the LCD is fully functional. You can probably get a good deal too.
  • Damen Wong
    I couldn't find any place that sells the LCD that you need.
Wont lode movies
Please check weather the DVD which your inserted i supported by the player.?
If someother movies plays then the problem is with the DVD which your inserted.The DVD might have not burnt in correct formatt.
Thanx
Jul 23, 2010 | Durabrand PDV-705 Portable DVD Player
Dual portable dvd player second screen not working
Sounds like it may be a bad linking cable or connection. Make sure you have cables inserted firmly and correctly. If possible, hook main unit to TV to be sure you are getting proper Video/Audio output.
Dec 23, 2008 | Durabrand PDV-705 Portable DVD Player
I need a new car adaptor for my Durabrand 7 inch screen double our dog torn ours up
I had the same problem, WalMart has an adapter with multipule ends & the yellow one fits! It was only $10 and can work for many different things.
Dec 21, 2008 | Durabrand Portable DVD
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
No Valid Disc
Try cleaning the laser lens if this don't repair it ,is the flat cable connector between the laser lens and the main board.Good luck
Jul 25, 2008 | Durabrand Portable DVD
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
Durabrand 7" Dual Screen Portable DVD player with game system
uneed a connectot bus for connecting u check how many pins are their say so many pin cable
Nov 07, 2007 | Durabrand DUR7 Portable DVD Player
Durabrand Portable DVD Logo
269 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
