Question about Dryers
Whirlpool electric dryer
Thermal fuse blew. Cleaned all exhaust ducts and replaced fuse with new. 1 week later same thermal fuse blew, why?
Heating Element is not working
  • ShellySP Mar 04, 2008
    I needed to replace my heating element. Now my dryer is working again!
    Problem Solver:
  • 12 Answers
Either you are pushing the dryer back to far and crushing the exhaust vent hose .your exhaust vent going outside is stopped up , or your low temp thermo will not let the dryer cycle and it is over heating.
Posted on Feb 28, 2008
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    Kenmore 63932101 dryer will not heat. New heating element has been installed. Where do I go from here?
    There is a heating element thermal cut- off (thermal fuse) 360 degrees. and high limit thermostat that you should check. Also there is a thermal Fuse on the exhaust duct that could cause your problem.
    Sep 06, 2010 | Kenmore 63932 Electric Dryer
    Dyer wouldn't run. Thermal fuse was replaced. Ran one cycle and stopped. Thermal fuse is again gone. ???????????
    If your thermal fuse keeps popping, you may want to ensure you have the vent cleaned out, you may have some sort of restriction somewhere in either the duct,
    or the machine. As you know the thermal fuse, protects the machine from over heating.
    Check that you have the proper voltage to the machine,
    Ohm out the heating element to ensure you have voltage right there, then ohm out your Cycle t-stat, it may not be working right either.
    Oct 20, 2009 | Whirlpool LER4634J Electric Dryer
    Dryer blows only cold air.
    If it's an electric dryer, then unplug the machine and check for a blown thermal fuse or a faulty heating element. The thermal fuse is about an inch long and is located inside the rear of the dryer, usually attached to or near the exhaust duct. The thermal fuse and heating element can be tested for continuity using a multimeter or ohmmeter. A lack of continuity will indicate a bad component. Sorry for your trouble and I hope this helped. Best wishes.
    Oct 07, 2009 | Whirlpool Dryers
    Dryer turns on but will not heat up.It has not been used for two weeks. It worked perfectly then. Is there a fuse or a reset button? Electricity was off periodically,
    Check for a blown thermal fuse. It is located just inside the rear of the dryer and is usually attached to the exhaust duct. It can be tested for continuity using a multimeter or ohmmeter. A lack of continuity indicates a blown thermal fuse. Another cause of not heating would be a faulty heating element, but with the electricity issues you mentioned, it is most likely the thermal fuse. Hope this helped and best wishes.
    Aug 11, 2009 | Dryers
    Maytag Atlantis electric dryer Model
    Check the following to address this issue.
    1. No power to the dryer
    Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
    2. Heating element
    A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
    3. Thermal fuse
    Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
    Aug 08, 2009 | Dryers
    Dryer wont get hot
    Did you replace the Thermal FUSE? Or, the Thermal CUT-OUT? If the thermal fuse blew, the dryer would not run at all. If the thermal cut-out blew the dryer would run, but would not heat. The following link explains how to troubleshoot a dryer no heat problem:
    http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
    Its great that you've cleaned all the duct work. That's usually the number one reason why dryer's fail. Poor ventilation causes the dryer to overheat to the point of failure. Now....before you go tearing the dryer apart again, did you verify the voltage at the wall receptacle? If you are missing a portion of the input voltage, the dryer will still run, but the heating circuits won't work. That's because the drive motor only requires 110-120VAC to run, while the heating circuits require 220-240VAC. If you have confirmed your input voltage is good all the way to the terminal block at the back of the dryer (read across the RED and BLACK leads), then the problem is your heating circuits. If the voltage is good at the receptacle, but bad at the terminal block, you have a bad power cord.
    As far as what you have attempted so far, I'm not trying to undermind your abilties, I just want to confirm we're talking about the same components. Many people confuse the Thermal Fuse and Thermal Cut-Out. Although they perform similar in function, they are located in different locations in the dryer electrical circuits. Please read through the info I provided and let me know if you have any questions. All the readings you should get are provided. I hope this helps you isolate your problem.
    May 04, 2009 | Whirlpool Dryers
    sounds like something getting to hot, perhaps clclyng thermo not regulating temp properly, although cleaned vent, when you pushed it back ito place did you crush or hkink line? peek over top and check
    Feb 27, 2008 | Whirlpool GEW9250 Electric Dryer
    Blown thermal fuses
    I would think not. The MAIN cause of that fuse blowing is lint build up. Turn the dryer on and put your hand on the outside of the vent duct. Is the air blowing hard? If so, you will probaly be ok, if not maybe your blower wheel needs to be replaced...
    Dec 15, 2007 | Whirlpool LER5636P Electric Dryer
    Dryers Logo
    198 people viewed this question
    Top Dryers Experts
