Question about Refrigerators
Fridge not getting chilled - Refrigerators
    Problem Solver:
  • 12 Answers
Several possibilities.compressor not running,fan in freezer not running. may have a defrost problem, low on refridgerant. air flow may be restricted.defrost timer may be bad
Posted on Feb 27, 2008
Water dispenser does not dispence water
need to replace the water inlet valve. the part number for this model is 4389178
Jun 18, 2010 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker is on but is not producing ice
The ice maker is probably not getting water. Have you heard the water valve click on and off to allow water to flow to the ice maker? If you get chilled water from the fridge, the ice maker's water valve will probably sound very similar to when you dispense chilled water. Try the water to listen for it. Then, listen for it over the course of an hour or so to determine if the ice maker is doing the same thing. If you hear it - then there may be a blockage in the line or filter.
If you don't have provisions to get chilled water from your fridge (ice only) or notice that you can't get water from your fridge any more: Make sure the water supply is on and.. that supply line isn't kinked or got crushed when the fridge was pushed back into position. This is a pretty common occurrence. If you don't hear any water valve clicking, the valve itself may have failed or there may be a problem with the electrical circuit. Hopefully, you won't have to got beyond this, but if so - let us know.
May 24, 2010 | GE GSS25LGM Side by Side Refrigerator
I have a samsung side by side fridge, and the fridge side is not staying cool, but the chill drawers are keeping the right temp??? The Model# is RS267LABP
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
The chill drawers are probably staying cold because there is a vent to the freezer in the wall for the cold air to seep through.
Nov 03, 2009 | Coffee Makers & Espresso Machines
Bot the fridge & freezer have quit chilling..
sounds like something pocked a hole in the refrigerant line ether inside or out side leak needs to be found and repaired with epoxy and coolant refilled
Oct 28, 2009 | Samsung Refrigerators
Hotpiont ffm90 fridge not chilling
hi if the freezer appears to work and the fridge if warm,the problem is that the freezer is over frozen and blocking the vents which send cold air into the fridge when required,and the noise is the fan hitting the the ice build up,defrost (switch off)your applinace for at least 36 hours then switch back on,you will then find after the freezer reaches -12 the fridge will then start to go cold.
Mar 09, 2009 | Hotpoint FFM90 Bottom Freezer Refrigerator
Amana refrigerator will not chill
That model number does not come up for me.
Click on and enter model number
http://www.searspartsdirect.com/partsdirect/index.action
Jan 10, 2009 | Amana BC21V1W Bottom Freezer Refrigerator
Over Chilling Refridgeration set on 7C still goes to 0C Digital thermostat
sounds like a bad thermostat,you can check it with a meter by putting the meter on omes,thermostat in closed position no reading turn thermostat all the way on you should get a reading if not replace,let me know-mike
Sep 29, 2008 | Westinghouse WRS6R3EW 36" 25.8 Cu. Ft....
Fridge not chilling
check the temperature setting recommended by the mfg. you will find all the info. in the use & care guide.
is it just the fridge or is the freezer acting up as well?
Apr 05, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
The fridge is making ice
I agree in the fridge there should be a chill controller check that it isn't turned up too hi.
Thanks J
Feb 08, 2008 | Freezers
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
