Question about Refrigerators
Refrigerator is depositing water in bottom of unit, under produce drawers.
  • SLVRBRD94 Feb 27, 2008
    where is the drain?
    Where is the drain located?
    Problem Solver:
  • 12 Answers
The drain is likely stopped up .or the door seal is bad,letting condensation occur.
Posted on Feb 27, 2008
  • ricky mack Feb 27, 2008
    look in the refridgerator at the top.it is eather located there ` or you have to take the freezer apart
Water under produce section
In addition to water under the crisper drawers, you might be getting water in the drawers too, look for any ice/frost in any of the air vent holes just above the drawers on the rear fan cover. This unit was made by Samsung for GE, these are notorious for this issue as the defrost drain tube wick heater is not long enough to work. You will need to turn the unit off for 24 hours, unplugged, doors open to ensure it's completely thawed both behind the cover and drain tube. Part# WR13X10573 (cover assembly complete) gets replaced, and part# 819043 will need to take the place of the existing Samsung one. Pleazer Appliance...
Apr 08, 2014 | GE Profile Pfsf6pkw 25.8 Cu. Ft....
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
Water collects under the produce drawers excessively and none in the drain pan under the unit. I have the ice maker off and water supply turned off. Water drips from vent in refrigerator portion.
. Pop cycle wrappers and other junk in the defrost drain can cause the drain to become plugged up.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 07, 2011 | Kenmore 64802 Top Freezer Refrigerator
We have a slow water leak in our fridge. The water pools under the bottom 2 produce drawers.
On most newer fridges, there is a very shallow 'V' shaped collection channel at the back of the fridge just above the bottom drawers, this is for condensate collection. In the middle of this channel there should be a hole, this quite often gets clogged, and over flows, hence the water at the bottom of the produce drawers, clear the hole and it should cure your leak, worth checking every couple of months.
Mar 22, 2011 | Samsung RM255LASH Side by Side...
The cheese/cold cut drawer area develops a sheet of ice under the door over a period of a few weeks. I have to remove the drawer and de ice the area. Sometimes the inside of the drawer itself is wet or...
hello. remove the lower front grate, at the floor level and clean the dust from under the unit. Also, check the interior bottom of the fridge and clean the "floor" being sure that the small drain hole is free of any debris. This will allow the water produced when the unit self-defrosts to travel through the fridge to the evaporation plate below and not stop in the cheese drawer. J.
Jun 11, 2010 | Jenn-Air JFC2089HE French Door...
Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Mar 08, 2010 | Frigidaire FRT21H8 Top Freezer...
Why is my refrigerator producing an oder?
CONTENTS OR OLD FOOD UNDER BOTTOM DRAWERS OR OUT OF SIGHT IF SMELL INSIDE REFRIG.
Feb 26, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kitchenaid refrigerator mdl KTRS22M has water under veggie drawer
Hi, water could be excessive moisture, check door gasket, or check drain at back above veggie drawers, could be block, make sure produce not blocking drain hole, clean, check carefully for drain.
Aug 02, 2009 | Refrigerators
Water is accumulating in bottom of fridge under produce drawers
Possibly your defrost drain found inside the freezer back wall is blocked. If you could send me the model number I could help you better. Thanks, Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 28, 2009 | Refrigerators
Refrigerators Logo
93 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
