Question about Dryers
Whirlpool Duet Dryer (GEW9200LL1) Runs but is not heating
GEW9200LL1 Runs but is not heating. What is the problem? How do I fix it? Thanking you in advance, Shelly
  • 156 Answers
Shelly makee sure both your electric breakers are on turn tham off then back on ck if you know how to ck 4 your 440 voltage if voltage is good the problem will be the heater element ck it are the thermo fuse eather one i founf thermo fuse more common problem
Posted on Feb 28, 2008
Duet. Why does it run but no heat and doesn't dry clothes?
You most likely have a bad heating element.
Try this video
Jun 10, 2015 | Whirlpool Dryers
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
I have a whirlpool Duet gas dryer, model ggw9200lw0. It will glow then heat up but switches off right away.
It sounds to me like your flame is not getting enough air. Make sure that ur screen is clean then clean your dryer vent. The easiest way to see if it is your dryer vent is to take the vent off the back of the dryer. If it runs good without it then you need to clean it. If the dryer heats up a couple times then wont heat up after that then you need to replace the coils
Aug 26, 2012 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool Duet: GGW9200lq0 Dryer Works, No HEAT runs fine but has no heat... vent is clear
This happened to me. Turned out it was a gas valve fracture which had to be replaced by the gas company. That's if you have a gas dryer
Apr 10, 2011 | Dryers
Whirlpool duet dryer Starts and runs a couple of
This website may help Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 19, 2010 | Whirlpool GEW9200L Electric Dryer
Dryer quit heating runs fine it is a gas dryer
Is the pilot light or "stricker" working when you start the unit.. Is it getting good supply of gas?
Mar 12, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
New Whirlpool Duet gas dryer (wgd9300vu) won't heat.
if its brand new,
anmd its gas, well then more than likely it was dropped, when it was dropped the graphite ignitor craked or broke due to shock impact,
i delivered units for 5 years and saw this numerous times.
I would tell you to fix it your self, but its brand new, if the company you bought it from has service they should give you a free service call and part
Oct 21, 2009 | Dryers
Whirlpool duet dryer runs but will not heat.
do you have 240 at the terminal block on the back of the dryer if so check for continuity on the thermostats , thermal fuse and heating element
Dec 29, 2008 | Whirlpool GEW9250 Electric Dryer
Dryer not working
Open dryer's rear panel and look for a broken belt and does the motor spins. Let me know with your results and we will see how could we assist you.
Aug 21, 2007 | Whirlpool LAB2700ML Pedestal Drawer for...
Dryers Logo
789 people viewed this question
Top Dryers Experts
