Question about Hotpoint WMA46 Front Load Washer
Drain Pump Can someone tell me how to change the drain pump please
  • 156 Answers
Concidering its front loading remove bottom panel inside you see the pump remove the 2 screws holding the pump to bottom unplug the wire connecter remove both hoses reinstall back ward from what yo did takeing it out
Posted on Feb 28, 2008
My Hoover BOSS 2315l started having issues not finishing the spin cycle, now it just continues to turn off every few min, so I need to keep restarting it. Does anyone know whats wrong please.
Symptomatic of a blocked drain pipe, blocked filter, or a failed drain pump, drain pump with a broken impeller.
Remove the filter cover and check for obstructions. Attach a hose pipe to the drain hose, wrap it with a towel, hold the two hoses over a bucket and get someone to turn the hose on until you can't hold the pipes any longer, usually about 15 seconds. This clears obstructions in the pipe into the machine drum and filter. After checking the filter and behind it, put it on for a rinse and spin.
If the pump has failed, you can drain the machine by lowering the drain hose into a bucket or floor drain.
There are videos online on how to change out a faulty drain pump.
Jan 22, 2018 | Hoover Washing Machines
Water wont drain away when in its final spin,and i have have fitted a new drain pump
If you changed the drain pump I would check the following things:
1) Is the machine actually sending power to the pump to turn it on. You can check this by using a volt meter and with the machine open disconnect the power to the pump and place machine in drain and test to see if voltaqge is being sent to the pump
2) Check your lines and the drain itself. Any blockages could prevent draining.
May 27, 2012 | Hotpoint Washing Machines
I have a whirlpool a+a 6kg aw o/d 4606 type d 400 which is telling me to clean pump . my question is where is the pump ?
Hi mooneyorla,
Before the Spin Cycle should start, all water must be drained out of the machine. If it does not start, it could likely mean the Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 08, 2011 | Washing Machines
My maytag dishwasher won't drain. It is not clogged. It just won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Jan 31, 2011 | Maytag 24 in. DWU9202 Built-in Dishwasher
Will not drain the water and spin
this unit will not spin until the water is drained. your pump is jammed or faulty.if u r confident, remove and clean pump.please turn off power b4 u work on it do want any accidents . please reply if u need more help
Apr 08, 2010 | LG Washing Machines
Ld error code
It isn't whether the water drained out, it is how quickly the water drained out. Common causes of the LD or long drain fault code are a kinked drain hose or some article of clothing being caught in the pump suction hose and increasing the time that it takes for the water to drain. It has to do with the cycle timer. I would look for some sort of obstruction. Also check the pump impeller for broken/missing blades and that it spins freely. If not, the pump is defective. Hopefully it is just a clogged drain line or pump. Hope this helped and best wishes.
Aug 13, 2009 | Washing Machines
Nec front loader keep beeping with E2 on the screen
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 04, 2009 | Washing Machines
Water not draining
I had this same issue... most likely (and if you are lucky) it is the switch for the lid. If you don't hear a solid click sound when you shut your lid the swich is not connecting and on telling the machine to drain or move on to the spin cycle. You need to replace the part.
Mar 17, 2008 | GE WBSR3140DW Top Load Washer
Hotpoint WMA46 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
