Question about IBM ThinkPad T30 2366 Notebook
One Dead Memory Slot
After using the old wedge paper trick for a while the faulty slot that came from the factory finally started giving me trouble. Question: Can the max supported memory on the machine be achieve through only one slot using 1 - 1 GB memory module?
  • Lause Oct 07, 2008
    Have the same problem, I guess. Some time ago, it ceased to boot, the fan went on and the HDD made noise, but it didn't go further, nothing on the screen an no sounds (beep). Disassembled it, but didn't find anything, so I assumed flexing of the motherboard and permanent damage. Tried to find spare motherboard, but didn't have the money and taught it wasn't worth it. Found a R40 instead in the bay, so I bought that on instead.
    By search I found some treads about this issue and had a closer look at the memory slots. The lid over them was quite damaged and scratched (it was used by my girlfriends daughter, quote: didn't drop it, always treated it well) and had a little sharp dent.
    Took the lid off, removed one of the RAMs and tried to start it, while pressing firmly on the memory slot, the ThinPad screen appears and gives choice between editing the BIOS or setting temporary boot device.
    When I've got the time, I'll try to solder the mem-slots and see, if it helped. And i'll try to remove the mentioned shock-absorber (allthough I'm not shure, what it is, the only shock-absorber, I know about, ist the rubber-thing in the bottom cabinet).
    If there are any other suggestions to solve the problems ot tips how to solder, I would appreciate any posts.
  • atlantesa Dec 06, 2008
    Yes I would like to know If I can put a 1gb ram into only one slot since the other is dead and what are the specs for it. Thanks
  • 3 Answers
I just repaired my ThinkPad T30 Memory Slot. I determined the slot area buy pushing on the end of the slot w/ my finger during boot-up.
With the RAM cover off and the ThinkPad upside down w/ the RAM slots to your bottom right, the bad pad on this was the one nearest the edge and closest to me. That will be bottom right by this perspective.
I used a Radio Shack Micronta microscope to check the end slot and noticed a hazy area around the contact indicating looseness.
The end contact pad is larger then the others and this may have cause a weak solder joint seeing that the big pad adsorbed more solder and created a thin joint.
I took a soldering iron and sharpened the point with a file and when hot I fluxed the tip and the joint area. Then added a very small bead solder to the iron and touched it to the end joint under a magnifying glass. It created a nice bead on the joint and fixed the problem. I then cleaned the slot with cotton swab and used a needle to check and make sure the pads weren't bridged, but the microscope was enough to validate my solder skill.
I now have 1G Memory! [2 x 512Mb]
Posted on Feb 10, 2010
*sigh*
Not true.
Maximum supported RAM even on 2366 is _2GB_ (read: 1GB per slot).
Cleaning contacts of SO-DIMMs with rubber erasers will most likely destroy the RAM due to isolated static discharge. DONT DO THINGS LIKE THAT ! - There are special solutions available for safely (!) cleaning contacts of ESD-sensitive devices.
ESD will not necessarily zap the devices (here: RAM) immediately, more frequent a gradual failure can also occur, which mostly cannot be directly connected with the "small" ESD of the cleaning actions.
Actual Problem (AFAI recall) is mainboard flexing, at least in the last couple of dozen cases I encountered.
Resolder the socket (non-trivial, consult an expert for that !) and all will be fine for the next year or two, then probably another resolder will be required. Additionally the whole machine can be disassembled and one (most likely) blue rubber shock-absorber can be removed. The resoldering will then last for (most probably) ages ...
More information concerning this specific issue on the t30s can be found via e.g. google.com or similar.
Good luck.
/dossi
Posted on Apr 01, 2008
    Scholar:
  • 94 Answers
Nope -
512 memory was the highest available at design time. So no additional address lines were made.
So, you must use 2-512 sticks
the wedge paper trick can be eliminated by using an inkpin eraser (gritty type) to clean the contacts on RAM chips.
Posted on Mar 01, 2008
Hp pavilion dv32332tx
First of all in this situation check the AC adapter. You can test the output voltage with a voltmeter. If you cannot do that, find a known good AC adapter and use it for testing the laptop. It is possible the laptop appears to be dead because the AC adapter is bad (and the battery is discharged). If you know that the AC adapter is working properly and it outputs correct voltage but the laptop is still dead, most likely you have a power issue on the motherboard (or power board on some laptops) and it has to be replaced.
If you have to replace the AC adapter, make sure you use a correct one. The output voltage must be exactly the same as on the original adapter. The output amperage has to be the same as on the original adapter or higher, but not lower.
Situation 2.
When you plug the AC adapter the power LED and the battery charge LED light up. When you press on the power button the laptop powers up but will not start. There is no video on LCD or external monitor.
If the power LED lights up it indicates that the laptop is getting power from the AC adapter. Most likely there is nothing wrong with the adapter but just in case test it with a voltmeter to make sure the output voltage is correct.
Also try this. Unplug the AC adapter, remove the battery and wait for 1-2 minutes. After that plug the AC adapter ans try starting the laptop again. Sometimes this trick helps.
It also could be a memory related problem. Try reseating the memory module, just remove it from the slot on the motherboard and install it back. Try installing the memory module into the other slot (if it's available). If you have two memory modules installed, try removing them one by one and start the laptop just with one memory module installed.
If the laptop starts fine with one memory module in both slots, but will not start with the second memory module in both slots, the second memory module is faulty. Replace the module.
If the laptop starts fine with both memory modules when they are installed in the slot A, but will not start with both memory modules installed in the slot B, the slot B is faulty and you'll have to replace the motherboard or use only one memory slot.
Situation 3.
When you press on the power button, the laptop makes a series or short and long beeps and will not start up. There is no video on the screen.
In this situation test the memory module as I described in the situation2. Try installing a known good memory module. Most likely you are getting a beep error because of a faulty memory.
Situation 4.
You start the laptop. It sounds like the laptop is booting normally (hard drive LED is flashing) but there is no video on the screen
In this situation test the laptop with an external monitor. If the external screen works fine but there is no video on the laptop LCD, most likely there is a problem inside the laptop display assembly. Go to my previous post witch covers laptop video problems in more details.
Situation 5.
You start the laptop and it starts making repetitive clicking noise or grinding noise.
Most likely you hear this noise because of a faulty hard drive. You can remove the hard drive and start the laptop without it. If the noise is gone, the hard drive is your problem. Replace it.
If the laptop makes clicking or grinding noises and you still have video on the screen, you can run a hard drive test utility. I usually use Hitachi's drive fitness test. This test is reliable and easy to use.
Situation 6.
The laptop boots into Windows ans works for a while, but after that it shuts down by itself without any reason or warning. You restart the laptop but the same problem appears again
Most likely it's a heat related issue. Listen for the cooling fan, make sure it works.
Also this problem might appear because of a faulty memory module, try some tips from the situation 2.
The laptop still boots ans you still can see the screen, so you can run the memory test. I usually use Memtest86+. Run the memory test and if it fails, replace the faulty module.
Mar 19, 2014 | Microsoft Computers & Internet
New memory, the board just beeps
First of all that board supports DDR400 (PC3200) so why did you get PC2100 chips?
Anyway, do a bare minimum test (only MB, CPU, RAM & PSU connected, nothing else). Remove all the RAM and test each one individually. Properly insert one into the first RAM slot and test by booting until the POST RAM test is finished. Shutdown and repeat the test with the same RAM module in slot 2 and keep repeating this for every slot. If successful in every slot, mark that module as working then try the other RAM modules using the same procedure.
  • As soon as you find one that doesn't fully pass the POST test, mark it as faulty.
  • If some pass in one slot but not another, then mark it as faulty.
  • If they all fail to pass on a specific slot, mark that slot as faulty and don't use it (you can use electrical tape to cover the slot for future reference).
Once you've finished the bare minimum test, try 2 RAM modules this time (use only the modules that you found to be working from the above tests). Mix and match the RAM modules & then try 3 together and even 4 (if you found all of them to be working fine).
Finally once you're satisfied you've found the modules that work properly, boot with memtest and test the RAM for any problems. If they all seem to work fine individually, boot them individually and test with memtest to determine which ones are actually faulty.
Jul 13, 2012 | HP Compaq Presario SR1610NX (ED865AA) PC...
My toshiba satellite l305d laptop does not boot,screen is blank,fan spins,hdd led does not blink,wlan led does not display,dvd rom light blinks,power led is on
hopeyour problem solved
if you find this is helpful for you so please rate me this will encourage me todo more free work..
regards'
sandy
Sep 05, 2011 | Computers & Internet
My 2nd memory slot for ram is not working can this be repaired?
Beforeyouassume the 2nd RAM slot is faulty check the following.
When instaling RAM in the 2nd memory slot this RAM may not be compatible with the RAM in the 1st memory slot or the RAM may be faulty.
Try and use the same make, speed and size RAM modules.
If the RAM slot is faulty, chances are it cannot be repaired.
Aug 27, 2011 | Computers & Internet
PC will not boot up, tried replacing the psu, unpluging the hard drive & 7-1 card reader. The pc then makes a 8 beep sound before repeating itself. Mother board is a pc chips m848a
Beep codes are vary depends on the BIOS manufacturer, when ever your computer beep more than once this mean it has an hardware problem. To determine the problem you need to check the memory, if these is another empty memory slot take the memory from its present slot and put it in the empty slot always make sure the memory fit firmly in the slot .If you still hear the beep you can replace the memory,you can replace the video card if the problem still exist you should try another CPU because the present one may be faulty and finally if the problem still exist this mean the memory slot is faulty and the only way to fix this is to replace the motherboard.
May 18, 2010 | Computers & Internet
Problem with r4 and ds lite
Try the paper shim trick first. It could be that the older NDSL's slot one contacts have become "sprung" and aren't making good contact.
Cut a piece of paper slightly narrower but longer than the R4. Put it on the non-contact side of the R4 and insert the R4 (with the paper on the back) into slot 1. It may increase the thickness of the R4 such that the slot 1 fingers now make contact.
Jan 12, 2009 | Nintendo DS Lite Console
Sony Cyber-Shot DSC-T5 "C:13:01 Format Error"
I had the same problem, you can solve this by:
1. Push the card multiple times in/out the slot or
2. Use a little bit of contact spray on a small piece of tissue, rap this in the length around the memory card just 1 time. Be carefull not to make it to thick that it get stuck in the slot. Then push the card multiple times in/out the slot or
3. Cut a small strip of waterproof sanding paper (grain: 400 or more - the surface feels just like paper, and is just a thin as paper) just as wide as the card or slot. Cut a strip of plastic (eg.old credit card) also just as wide as the card or slot. Rap the sanding paper in the length of the strip and insert this in and out the slot. But!! ... make sure you stay at the upper side of the contacts, don't worry just do it carefully, don't use force and sand the contacts a couple of times. This way work for me, finally!!
Oct 31, 2008 | Sony Cyber-Shot DSC-T5 Digital Camera
PAPER FEED
Assuming that you know where the paper gets feed in, I usually use this trick to start a new roll of paper.
First, tear off the end of the new roll so that there isn't any glue stuck on the paper.
Then, fold the tip of the paper like an arrow. (Fold one side to the middle and the other side to the middle so both sides meet in the middle.
Then, place the paper into the slot where the paper feeds in.. (Usually goes under the printer assembly) and then hit the PAPER FEED button at the same time. If the paper is in the correct slot, the paper should start feeding the paper all the way through.
Hope this helps.
Have a good day.
M =)
Jan 16, 2008 | Canon P1-DHV Calculator
Ram
Maybe one of the memory slot on your motherboard is faulty. Try testing each slot by placing one memory module on a slot and start your pc. If your pc made beeping sounds, that slot might be faulty. Do this on the other slots.
Dec 17, 2007 | Foxconn 6150BK8MC-KRSH Motherboard
Have a Canon EOS SLR
Reformat the card in the camera then try Also use the menu system with help from the manual to establish the file size/ file type The higher the resolution the few the images able to be stored/ RAW and Tiff give but few SHQ give more HQ give even more but each with declining quality. Which is only 2 month old Card or Camera or Both? Either way having tried the alternatives if still in trouble return the 2 month old item for replacement.
Oct 06, 2007 | Canon PowerShot A550 Digital Camera
IBM ThinkPad T30 2366 Notebook Logo
1,251 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
