Question about Refrigerators
Refrig stop freezing. Change board and capicator on compressor. A small amount of ice feezing at top of evap coils. M FRS6LR5EW3 Model 486381436
Dryer filter is stopped up. or you have a refridgerant leak .low on refridgerant.
Posted on Feb 27, 2008
I have got a gree 60000btu under ceiling unit, the suction pipe is icing up back to compressor its running on 360kPa suction and if I top up the refrigerant it does not change
major causes of evap.freezing dirty coil,evap fan motor or capacitor low on freon.moisture in system. first turn off cooling run fan to completely thaw unit. if possible clean coils and blower wheel. any unit running efficiently the evap coil will be at freezing or below. the key is to have enough airflow across the coil to remove the heat and humidity.its very easy to introduce air and moisture into the system. i have seen alot of techs. over the years make the same mistakes over and over again. when hooking up guages they dont purge the lines back; worst case is only to evacuate freon pull a vacume and recharge
May 22, 2012 | Heating & Cooling
Evaporator coils icing up
The only possible source of water to freeze on the coils in such a short time is from the outside atmosphere. Check the door seals.
Oct 25, 2007 | Amana ABB1927DE Bottom Freezer...
I have a GE refrig. model GTS22ZCMARCC. The evaporator fan has been pulsing up and down forever. Then the freezer stopped getting cold and the refrig. part was not as cold. I check the evaporator fan...
it's the board,also change out the sensor that's on top of the coil,it looks like a white bullet,the part number for the temp. sensor is wr55x10025 and the board is WR55X10942.everything runs through the board,i've seen when you call for water the compressor stops or the water doesn't dispense,or the fan pulsates like you have.let me know how you make out
Oct 21, 2010 | GE GTS18SHPBS Top Freezer Refrigerator
GE GSH25JSTASS doesn't freeze or cool
Ok, first off, replace all thermistors, freezer (2) & refrig (2). Then check that evap fan is working properly. This is a DC volt fan, not ac volt. There have been some issues with these, I would replace if problem continues.
How this box works, main control board monitors everything from how many times doors are open, how long they are open, how and when I/M drops ice, etc.... Every so many hours, depending on how many times the doors are open, you got ice thru the door, etc... it will shut down and go into defrost mode. When it is time for defrost mode it will run refrig into a "sub zero" state, shut down evap fan, run deeper into sub zero effect, shut down compressor when the thermistors say it's cold enough, turn on defrost heater that melts any frost in evap, then turn compressor back on for a few minutes, then turn evap fan back on. Most techs think that the mother board is defective when in fact the thermistors are not measuring temps correctly within the whole unit. If the thermistor say, hey mother board I'm only 60 degrees in the freezer, then it will keep running the compressor trying to get to zero or -1 or till the darn thing freezes up and stops moving air.
Find another tech to work on your unit, one that has some electronics background and/or computer knowledge. It takes a electronics & computer degree to work on these units and understand how they function.
Doors, some of the new frigs have magnetic door gaskets, if it is not staying shut, replace door gaskets. If door stay open or is leaking air (especially around ice shoot) it can cause some really weird stuff to occur, like thermistors saying I'm cold at the inlet to evap but not at the top of evap and mother board will try to correct it's self by running longer. One other thing about door gaskets, if the drain plug in the evap area is frozen or plugged up, doors won't shut properly and stay shut.
For one thousand dollars, I'll come to Florida and fix for you, 200 to fix refrig and the rest for a good time at Disney World (LOL). Good luck. Contact GE for repair on this unit if you can't get good results from your repairman. Their people, like me, go thru extensive training on these boxes. You can thank our goverment for the energy codes that have gone into effect over the years requiring mfgs to have to keep the cost of running these refrigs down as low as possible, the only way to do this was to computerize these boxes. Good luck
Sep 30, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
The refrigrator sution line keep's freezing and wont cool lower than 44 degee's. what should i do to get my temp down and keep the line from freezing? Also what should the high side pressure and low side...
Im taking it that you have recently had work done on your fridge. What you are telling me is the system is overcharged by a fair amount. Decant by removing small amounts of gas from the service port which in effect "should still be on."Depress and Remove in 5 second intervals then stop and wait for approx 10 min. If ice is still there carry on that way untill ice is no longer on the suction line. If the evap. is flooded, cooling is lost. On the small compressors, do not worry about the high side pressure, you normally charge to -15 deg. celcius. at your ambiant temp. .
Sep 23, 2009 | Traulsen Refrigerators
Freezer section not freezing
If you only had ice buildup in one section of the evaporator you have a weak/inefficient compressor.
You need a new compressor or a new refrigerator.
Sep 21, 2009 | Kenmore Refrigerators
Our 4 year old GE side by side frig suddenly warmed to 64 degrees. Freezer stopped freezing and is at 43. Motor is running.
Really need to know what motor(s) are running (compressor, evap fan inside freezer compartment, condenser fan under fridge)?? Of course, check your temperature (thermostat) settings. Side-by-sides usually have 2 of them. They should be labled for refridgerator and freezer. The freezer control usually only opens a baffle from the freezer compartment to the refridge compartment. The refrigerator temp control is the one that controls the compressor on-off cycles and the temp of refrig compartment (this keeps the refrig compartment from freezing the milk and cokes) If the freezer control/baffle is set too far open, this will cause the refrig temp control to shut off too soon for the freezer temp to get low enough. These controls can get bumped out of the correct setting accidently from time to time.
To check the following, the fridge has to be running, or in a condition where it "should be" running: If compressor is running (condenser fan should be too), check if evaporator fan (inside freezer) is running. Open (freezer) door and hold door light switch in when you check evaporator fan operation (some fans stop when door is open) If it is not running you may have a bad evaporator fan motor. It could also be a bad defrost timer, causing the evaporator (also inside back of freezer) to ice-up. This blocks the air flow over evap. Also, there is a defrost terminator switch on the evaporator coil that stops the defrost cycle when coil is clear of ice/frost (but timer hasn't ended defrost cycle). If it is defective, that could also keep the fridge from going into the defrost cycle, or taking it out too soon. If it is the timer, change the defrost terminator as well. Depending on how handy you are, you may be able to check/change any of these parts yourself. If you don't know much about elecrical stuff, you should leave it to a repair tech. Hope this helps.
Jun 25, 2009 | GE Refrigerators
Refrig & freezer not cold enough; ice forming; low air volume
If ice/frost is building up on the back wall of the freezer then you have a defrost system failure.
Defrost system; Evap Fan, Heater, Thermo disk, Timer.
Evap Fan - this should be running all the time except when it goes into defrost mode.
Defrost Timer - This part is hard to locate on some models, a call to a parts place with the model number can help you find it and tell you if this is the type you can mannualy turn to put in the defrost mode. If you can do this, take the back panel off in the freezer so you can see the cooling coils. The heater should be red hot and melting the ice. If so, replace the timer. If not, you need an OHM meter to check the heater and therma disk.
Un plug the Ref, locate the heater, usually looks like a heating element in an oven and runs across the bottom of the coils. Touch the meter leads to each end of the heater. If no reading, replace.
Therma Disk - located close to where the coils enter the freezer, small round disk clipped to the coils. Check the same as the heater but, you won't get a good reading unless the temp is below freezing. Any doubt, just replace, it's not that expensive.
This is a lot to do, hope this helps.
Jan 23, 2009 | Refrigerators
My U-line under counter refigerator ice maker evap fan failed
Depends, for the newer models, you can change the evap fan motor thru the front, but if you have the older model, then you have to remove the freezer housing, ice maker assy then the cover to change the evap fan motor.
Nov 13, 2008 | U-Line COMBO29FF Origin Series...
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
