Question about Dell Dimension 4100 (-JM0TB01) PC Desktop
Slow pc Hi, I had a power outage last tue. now my Dell pc locks up intermittently and makes funny whining abd clacking noises like its going to die. Can I fix this or do I have to put this horse down?
  • 133 Answers
The clacking noises are comming from the harddisk, so likely it was damaged during the power outsage, you need to backup your data b4 u loose it and change the harddisk. to backup to need Fix the hardsisk in onather PC as slave disk
Posted on Feb 28, 2008
Hi my c1 has started to make a whining sound (bit like a dog whine) the last couple of days. It tends to get louder and is intermittent, it starts when the engine is fired up (no probs starting engine)...
Have your drive belt replaced (sometimes called the auxiliary or serpentine belt) when it slips it creates a screeching noise and it's also a sign that it's going to fail (snap).
These can run the alternator and power steering so you should change it as a preventative measure.
Oct 17, 2013 | 2008 Citroen C1 1.0
My Dell XPS 210 makes a loud whining noise when powered up and lasts for minutes until turned off. Can you identify what the issue is and how to fix?
It sounds like a fan problem, it could be one on the case, the motherboard or in the powersupply. fans are generally inexpensive, but if it is the power supply it will be a couple more bucks to fix. There could even just be a buildup of dust on them. Compressed air can usually clean them out. HDD can also cause noises in some cases but hopefully thats not your problem.
Aug 26, 2011 | Dell XPS 210 PC Desktop
My kitchenaid prestige dryer is whining...literally. It was intermittent at the start but over the last week has become constant...a low, faint whine. Make sense?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 16, 2010 | KitchenAid Dryers
2003 Ford Focus 78,000 miles...clacking noise
soiunds like a wrist pin but more like a cracked piston,
May 11, 2010 | 2000 Ford Focus
I have a high pitched noise which appears to be coming from front right engine compartment (as you are looking at the engine) which sounds kind of like a belt that is squealing. It is intermittent. Just...
Could be several things. WHICH ENGINE?.. 4 cylinder (has three belts, power steering/water pump, alternator & A/C compressor, one tensioner pully A/C compressor), The V6 2.7 (has only one belt, 1 Idler pully and 1 tensioner pully), the V6 3.5 has two belts - A/C/alternator, and power steering - there are two tensioner pullys). Noises can be caused by the belt(s) themselves, pullys, bearings, pully bearings, water pump shaft bearings (or belts/pullys rubbing up against something). Let's not forget that there is also belt(s) behind the Timing Belt cover as well as pullys and bearings associated with the timing system. You could start by removing one accy drive belt at a time (alternator, water pump, compressor, power steering, etc) to see whether or not the noise goes away in each case. If after each case, you discover the noise is still there, it's probably behind the timing belt cover (idler/tensioner pully, water pump shaft bearing, crankshaft bearing, etc.). Good Luck
Jun 29, 2009 | 2004 Hyundai Santa Fe
Fan makes a lound noise and power button is orange
It sounds as if your power supply is cooked because the cooling fan has been running slow
Only way you can check is to take a panel off and hook a voltmeter into the 12v & 5V supplies on the Hard Drive and the Floppy Drive.
Jun 25, 2009 | Dell OptiPlex GX280 PC Desktop
Windows XP Locks Up
Your power supply might be almost dying.
May 05, 2009 | Dell Dimension 8400 PC Desktop
Funny noise
The hose may have been installed incorrectly or not clamped.
Jun 06, 2017 | 2000 Volkswagen Beetle
Laptop 'freezes' after about half an hour of operation
Is the hard drive making a clacking noise, and/or does the mouse freeze only once or freeze and unfreeze a few times before dying completely?
Nov 21, 2007 | Computers & Internet
Slow cycle making a loud CLACKING noise???
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Apr 08, 2007 | Kenmore 45981 Washer
Dell Dimension 4100 (-JM0TB01) PC Desktop Logo
50 people viewed this question
Alun Cox
