Question about Kenmore 16602 / 16604 / 16609 Built-in Dishwasher
Maytag Quiet Plus 2 cloths washer - aggitator drain plugged up
I have Maytag Quiet Plus 2 cloths washer, good unit. However, the drain in the aggitator for the fabric softenr keeps getting plugged up with lint, then it cloggs up with the fabric softer and lint, so the softener won't drain properly during the spin cycle. Is there a way to open up the plastic aggitator so I can get to the clog? Have tried a bent-straight clothes hanger, but the metal is too big to get in the grooves, or to grab the smaller pieces of lint. Any suggestions?
  • 868 Answers
Ok grab hold of the top of agitator about 4 inches from the top and just pull that top right off.Hit it at an angle and it will pop right off .Dont be shy ,its just plastic that is snapped onto plastic.To put it back on just line it up on top and Smack It back on.Easy Ha???Youll be able to clean it alot easier now.If you dont use fabric softener your problem will be gone for ever .Try using less and mix water in it first.I'll help you if you need further help..
Posted on May 21, 2008
There is cloth stuck under the aggitator on my Capacity plus Admiral washing machine. Model #lnc6766B71 how do I remove the aggitator
As a general rule Admiral is a VERY inexpensive machine, so you may be better off with a new one if the parts prove expensive. MAKE SURE TO UNPLUG MACHINE.. Be careful the agitator doesn't come loose suddenly when you are removing it, I have seen more than one bruise on the face from this.. hold your head to the side when pulling it off. http://www.rakerappliancerepair.com/NephewClub/Diagnostics/Washers/Maytag/Maytag%20TL%20Bulletin%20TDL-0086-B.pdf
Jul 06, 2015 | Admiral Washing Machines
Where is the model number on maytag quiet plus ii washer
Posted on November 16, 2012 M/F FREE VIDEOS, RESOURCES & RECOMMENDATIONS *NEW* Search Parts For Your Maytag Washer On RepairClinic Every Maytag appliance, including Oversize Capacity Plus and Quiet Plus appliances such as washers and dryers, is manufactured with a product label that displays details about the appliance such as its model and serial numbers. The model number is typically located on the top left corner of the label. Although the location of the product labels varies by appliance type and model, finding the model number for your Oversize Capacity Plus and Quiet Plus appliance shouldn't take long. Maytag only attaches the product label to certain areas of an appliance. *Open the lid on your Oversize Capacity Plus or Quiet Plus washer and look for the product label on the inside bottom right corner of the lid. *Check for the label behind the control panel on the top back of your washer. *Look on the back main portion of your washer, also known as the base frame, on the left.
Jun 13, 2013 | Washing Machines
My washer is 7-8yrs old it will fill with water but then will not aggitate,spin or drain
the lid switch is defective underneath the lid,disassemble the unit and replace this switch under the top and reassemble the unit
Sep 11, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Top loading washer that won't aggitate, or rinse.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
Dec 04, 2009 | Maytag Washing Machines
Maytag turns on but won't aggitate
ahh sounds like the maytag drain pump, it seizes up and over heats the motor. look for belt under unit, pump is front right or rear right. buy the pump asm. They sell a pump by itself but you want the assembly at the same price, its a newer design
Jul 19, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Maytag quiet Plus 2 cloths washer
machines not on and water continuing to enter machine????youll need to replace the machines water valve(its not shutting properly). in meantime turn off water supply when not using machine.
Feb 26, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Washer will not spin or aggitate
1. unplug for ten minutes.
2. plug back in.
3. open/close lid 5 times.
4. wash clothes!
Sep 18, 2007 | GE WWSE5240G
Kenmore 16602 / 16604 / 16609 Built-in Dishwasher Logo
470 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
