Question about Mag Innovision 19" LCD Flat-Panel Monitor LT916S
Still "No Joy" with MAG Innovision 19" LCD
Replaced all 470mf caps still "No Joy" !
Question: There is a very large Capacitor rating 400V that has brown stuff on its side where it was folded down onto the board!
Is this some type of adhesive or has this capacitor blown!
Might sound like a really stupid question , but never took electronics courses just learned a few things from my best friends dad when we were teenagers, but back then the Whisper Writer was the latest thing and a company called Atarii came out with a little game called PONG!!
Thanks in advance for any advice, especially whether I should replace this 400V capacitor !
  • Oscar Brigman
    Oscar Brigman Mar 02, 2008
    don't see a solution only reposts of my own questions!
    Scholar:
  • 198 Answers
Posted on Mar 02, 2008
My problem is, how can i know the value of a damage capacitor which is exploded, innovision mag crt monitor..
For your information there is no value of a damage capacitor. It may damage transistor. So there is a complicated network of caps and coils with relay switch. You have to removed each cap and checked it for short,open, and correct capacitance. Replace the capacitor soon. Purchase a compatible capacitor and solder it.
Mar 29, 2011 | Mag Innovision InnoVision 800 Monitor
How to download a owners manual for MAG Innovision LT717s LCD Computer Manual
I solved the problem myself by going to the homepage of MAG Innovision and i downloaded the manual i needed from there...Thank you.
Oct 29, 2009 | Mag Innovision LT982s 19" Flat Panel LCD...
MAG innovision 900w 19" LCD flat panel
Hi..there,
Well, you need replaced a new backlight inverter. if you got a AC Adapter with this monitor. The backlight inverter it to your left a small rectangle piece. Monitor without AC Adapter, the inverter it to your right... it's a large piece of power supply w/ buit-in inverter. OK! Wanna repaired it yourself...
First of all, inspecting the inverter closely...if you're lucky you can see a over-heated capicators with a bulged caps on top. Those caps need to be replaced. if you're not sure....just replaced all the caps.
Good lucks! Have a nice day!
Oct 08, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
David8 - Capacitor change was perfect solution
I'm not a 100% sure on how long it will last you, but I doubt your monitor will go over 185F degrees even while running all day and since it's a higher voltage it wont get blown as easily. I only changed mine a few weeks ago, but some other guy who did the same said he's has been working for like a year now without any problems. I think they'll last longer than the originals.
Jul 09, 2008 | Mag Innovision LT976S 19" Flat Panel LCD...
Mag 19" LT916s
This is a common problem due to capacitors in the inverter circuit going bad. The inverter provides the voltage to light the backlight, so the lamp is usually not the problem.
If you open the case on the monitor (sometimes that's a challenge all by itself) and follow the wires from the backlight to the circuit board, you'll find the inverter circuit. There are normally a couple of transformers (they may be small square cases or round coils of wire on black or gray forms), some transistors, and the infamous capacitors. The caps are small cylinders with printed values on them, like 4.7uf, and also a voltage rating. Most of these are values you can find at Radio Shack, so if you or someone you know has soldering experience, you can try changing them. Stick with the original capacitance value (the uf number), but try to get a slightly higher voltage rating if you can. The voltage ratings come in standard values, like 16 volts, 25 volts, etc. The higher voltage parts will be a little bigger but should still fit. They go bad because the rating wasn't high enough to begin with. But it saves the manufacturer a little money on each unit. Make sure you observe the polarity of the capacitor (plus and minus, with some kind of marking on the circuit board to show you) when you put in the new ones.
Jun 08, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag problem
Hi..there,
The lamps has nothing to do with it... what you need a new backlight inverter or repaired it by replaced a couples of bad capacitors... Sound easy... right! Not so... It's not always the caps problems.
Apr 14, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Yes if you have soldering tool, you can do it by yourself. Check other components as well such as lamps.
Feb 26, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Monitor went Blank / Black (MAG Inov...lt916s)
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 19, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
MONITOR MAG LT916S
Good Luck!
Feb 12, 2008 | Mag Innovision 19" LCD Flat-Panel Monitor...
Monitor problem
my monitor is 17'' lcd...... mag innovision model: LT716s..before was working well but now the lcd monitor don't to turn or either the led doesn't turn or make any sign.... no matter whta the lcd stay blak,,,,,do not want to turn on....
Dec 31, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
Computers & Internet Logo
149 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
