Question about Microwave Ovens
Panasonic dimenion 4/ nna772sbbpq
to robotek
the microwave seems to work but then after about 25 seconds it stops and the time resets and goes back to the clock & the food inside it has not heated it at all  you said that it could be magnotron, diodes, or power supply i have changed the magnotron but it hasn't made any difference could you tell if the diodes are on the inverter board & the supply is on the first board
ps    ill be carefull around the high voltage im a electrican i deal with 500volts every day
thanks dom
  • 1 more comment
  • Dominic Dance Feb 28, 2008
    n how best to check all of this
    the grill and oven all still work was normal without cutting out does this mean the inverter board has gone
    the oven & grill work fine it just seems to be on the microwave side it cuts out & resets it self back to the time
    Brigadier General:
  • Microwave Ovens Master
  • 3,614 Answers
This can happen due to a bad door switch.
When you are decided to fix it and work on it, there's *critical* safety, disassembly, and troubleshooting info site (as well as a text file which helps in diagnosing and repairing door switch problems) click here.
Some helpful exploded view diagrams and order parts by entering your model number here: Kindly regards
Posted on Feb 28, 2008
    Genius:
  • 3,587 Answers
Sounds to me like the electronics are off, not the innards. do any of the presets work any differently than the timer? Try the popcorn setting
I need a user manual for a panasonic dimenion 4
Do you have a model number (It will look something like NN-C803) .....if you do, you might find what you need at http://kitchen.manualsonline.com/manuals/mfg/panasonic/panasonic_microwave_oven_product_list.html
Jun 04, 2010 | Panasonic Microwave Ovens
you will have a failed magnatron, rectifier diodes to same, or a power supply fault.
Feb 14, 2008 | GE JES1851 Microwave Oven
Microwave runs for 3 seconds and stops
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
May 31, 2010 | Panasonic Microwave Ovens
Microwave shutts off after 2 seconds/
If so, see
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
If yours is not a Panasonic, please reply back with your brand and model number so we can help you.
May 22, 2010 | Panasonic NN-S592 Microwave Oven
My sharp microwave just stopped working. It
IT IS POSIBLE TO HAVE A BURNED FUSE ON THEI Main boARD OF THE OVEN
Feb 14, 2010 | Sharp R-1480 Microwave Oven
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Dec 30, 2009 | Panasonic Microwave Ovens
Microwave turns off by itself after being on for 3 seconds
If so, see http://www.microwavedisplay.com/safety.txt and
http://www.microwavedisplay.com/disassembly.txt
Mar 03, 2009 | Panasonic NN-S532 1200 Watts Microwave...
Panasonic Model No. NN-S933BF Microwave Oven
could it be that i didn't follow the manuel because i got it second hand or is it because something is wrong with it,and i have to get it fixed.
Oct 04, 2008 | Panasonic NN-T990SA Microwave Oven
Panasonic NN-CS596S Convection Combi Steam Oven
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
Let us know if the hard reset does not fix it.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
If you do indeed have a problem, Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
I would recommend that you contact your nearest Panasonic-authorized servicer.
Aug 16, 2008 | Panasonic NN-SN657S Microwave Oven
Microwave Ovens Logo
62 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
